Likes Likes:  6
Results 1 to 13 of 13
Thread: Fuel Shut Off Valve
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Fuel Shut Off Valve
    https://photos.app.goo.gl/cQ4N4ZIqhsp3l0Yf2
    I don't know if the picture made it, the last time I put in a picture it worked different. That's what happens for the computer stupid. BUT, if it worked, this is my present in line gas shut off valve and it is leaking a little. I want to change it out, but I've had a hell of a time finding one. The best I've come up with is for a lawn mower, plastic with a red valve handle. Pretty cheesy even for a spare parts rat bike. Any one have any ideas on where to get a replacement or another type of well made valve.
    If the picture didn't make it, oh well. Any ideas on an in line valve will be appreciated.
    Thanks for your time,
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply
    picture made it fine...maybe marine or aircraft....old tractors had sediment bulb shutoff valves, they are low quality also. Have you considered rebuilding your old valve.....maybe o-rings or packings or relapping sealing area?
    Check Lowes or Home Depot
    Apr 2015
    Batesville, AR. 72501
    https://www.homedepot.com/p/Everbilt...4-EB/205817885
    You might be able to reuse your existing hose barbs. Any hardware store should have brass ball valves in the plumbing dept. Use a little yellow teflon tape on the threads.
    I don't see what's wrong with the plastic valves they been using them for years but I wouldn't get anything that is strictly for water' ie plumbing ! Any any garden center that has sells garden tractors and such will have them even some marine places will have them Also ��
    Ya have to watch out with plastic
    Too much alcohol in the gas destroys it
    Take a look at the plastic lines found on most lawn mowers and weed trimmers
    They get destroyed and crack then leak JMO
    Thats with the bargain basement mowers and 99 dollar trimmers who by the way don't have fuel cutoff valves... Lines and Valves are too different animals... With the weed trimmers its the 2 cycle mix that causes them over time to get brittle and crack...
    Plastic valves [Petcocks] are in my Snowblower, Log Splitter' Snowmobile' Generator' Power washer and my ATV's For years now....
    Apr 2015
    I've used the brass ball valve I listed for about 6 years on my lawn tractor with excellent results. It has a brass body, stainless steel ball, and teflon seals. These valves are rated for water, air, gas, diesel, fuel gases, and most chemicals. As long as it won't attack the brass, stainless, or teflon I'd guess it's OK.
    Not 100 percent true
    They have plastic fuel lines that deteriorate from the alcohol also the floats, and needle valves in the carbs suffer
    In most cases a replacement carb will solve most problems, tho they are not cheap
    The cure is to completely drain old gas each season and if you can find it use alcohol free gas
    Modern gas has a limited shelf life now, not like our older leaded fuels
    The latest and better plastic looking lines and associated fuel delivery parts are made of a newer PTF type resin similar to teflon
    IMO , steel line or braided stainless would serve us well, any ball cock type valve would IMO work for a shut off
    Keeping in mind alcohol gas is VERY corrosive and will over time dry out rubber and gaskets. Also the corrosion loves to plug up needle valve seats and eat up fuel tanks inside out JMO
    Oct 2014
    Thanks for the info folks. Our local Home Depot had Toms ball valve. They either didn't have or couldn't find Jacks. But they only sent me to 3 wiz bang experts to look. I'm gonna change it out this weekend.
    Apr 2015
    Sonny,
    The hose barbs and other brass fittings are usually in plastic drawers located near the vinyl and plastic tubing reels in the plumbing dept. I think that's also near the PEX tubing. That's where they are at my HD.
    Quote Originally Posted by sonny8l3 View Post
    Good deal, let us know how it turns out
  1. fuel shut down switch
    By Johnny Michael in forum Stallion Trikes
    Last Post: 05-26-2015, 08:17 PM
  2. A/C shut off
    By Doc7402 in forum Stallion Trikes
    Last Post: 07-17-2014, 08:10 AM
  3. rear cly. shut down
    By lboos in forum Harley Trike Conversions
    Last Post: 02-12-2013, 04:17 PM
  4. Stallion's Fuel Line Shut Off
    By Jerry126 in forum Stallion Trikes
    Last Post: 10-11-2012, 11:05 AM
  5. Oil Valve: Quik Valve
    By Konrad in forum Honda Trikes
    Last Post: 08-05-2011, 07:34 PM
