SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Likes Likes:  7
Thanks Thanks:  1
Results 1 to 7 of 7
Thread: Throttle by Wire High Idle Reset For Harleys
    Default Throttle by Wire High Idle Reset For Harleys
    if your Harley throttle by wire acts up and high idles when cold starting, dont panic
    Try This
    To reset your idle setting back turn the ignition switch on for 10 seconds off for 10 seconds (do not start the engine), repeat a total of 4 times. That should reset your original throttle position.
    The throttle by wire will remember throttle position each time the bike is shut down
    That said, some are having problems rolling the throttle a bit when using the kill switch
    This can cause this type of problem
    There is just a bit of roll on with this set up compared to cable type throttles
    The little extra roll on can = higher RPM when starting This does work, I tried it on mine when I first got it
    Try This
    I don't know about that... The M8 Is supposed to idle when Cold 1000 to 1100 hundred RPM's plus and then when it warms up...It settles down to the annoying 850/900 lope...After about a mile of riding...
    What the above info is for if your idle is lets say high @2000, then use the method
    It can and does happen withTBW
    My 15 Freewheeler did the same thing twice
    Your M8 only idles cold @1000 to 1100? When you cold start it?
    Give or take a few hundred RPM's..Yes, Thats the function of the enricher...
    Closed Loop?
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Try This
    Learn something new every day - exactly why I enjoy coming here.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    What Jack said is confirmed by a Harley Store manager, previously a Service Manager, in this video.
    It is in the 2nd half of the video-
    www.DKCustom.com
  1. Harley Throttle By Wire Tech Info
    By Jack Klarich in forum General Harley Chat
    Last Post: 11-03-2020, 01:00 PM
  2. Boom box reset
    By lightnin in forum Harley Tri Glide
    Last Post: 04-12-2020, 11:19 AM
  3. Throttle by wire
    By Grumpy7760 in forum Harley Tri Glide
    Last Post: 07-18-2017, 10:54 AM
  4. NEW THROTTLE AND iDLE CABLES
    By pcombe in forum Harley Trike Conversions
    Last Post: 05-06-2015, 08:30 PM
  5. High Idle
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 10-26-2009, 07:49 AM
