Likes Likes:  5
Results 1 to 19 of 19
Thread: Looking for a Flanged Yoke
    80+ Posts Red Wing One's Avatar
    May 2015
    Komoka Ontario Canada
    Default Looking for a Flanged Yoke
    I removed the driveshaft from my 2013 Lehman Monarch LLS-ll for inspection and found that the eyes in the flanged yoke that bolts to the differential we’re streched, the caps we’re moving in the yoke.
    I called Champion (who now own Lehman) and they informed me that they only sell complete drive shafts.
    I understand that they are not in the driveline business, but it’s senseless to replace the whole driveshaft when you only need a yoke.
    Has anyone on the board run into this? We’re you able to find a Yoke?
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    I don't know the dimensions of the yoke or the size of the u-joint.
    You have everything you need to find it.
    If this doesn't help, give me the dimensions and I will find it.
    If this is the correct one, let me know so I can keep one in stock......
    Name:  2-2-899 flange yoke.jpg
    http://www.northerndrivetrain.com/pr...I-2-2-899.html
    Jim Murphy
    Iron Butt Rider 2001
    May 2015
    Thanks Jim.....I was corresponding with Bill Swift at Champion......he told me the driveshaft cost is $740 plus shipping.....
    I will measure my yoke and see if we have a match. When I do get a match, I will post it here.
    Do you think it would be ok to use a yoke that doesn’t have a raised face?
    Most yokes do not have one. I assume it’s there to keep the yoke centered with the matting flange on the dif.
    Martinsburg, WV
    The raised face is part of the alignment to the pinion flange. Without that it is really free to move wherever it wants.
    Jim Murphy
    May 2015
    Thanks Jim, I haven’t checked the dimensions yet because I went to the Toronto MC Show to see the new Goldwing today.....I’m in love......
    The problem is I’m now retired on a fixed income and probably shouldn’t buy one....
    I will keep you posted on the yoke issue!
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    That almost looks like a ford yoke. Does it use a ford rear end? Maybe take it to a junk yard and match it up.
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    I know some folks were using the front joint from 98 f 150 on there home brew units and it would be close and definitely worth a look.Now you've give me something else to check on mine.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    May 2015
    I asked the Champion rep if it was an automotive differential, and he unconvincingly told me it was designed specifically for them!
    I will get some dimensions today and post them here.
    I never thought about going to a junk yard.....I have good friend in that business......I will get in touch with him!
    Thanks for your replies....I’ll keep you posted!
    Martinsburg, WV
    Marcel, We have already concluded that the rear differential is a Toyota.
    It only makes sense that the pinion flange and rear driveshaft flange are also Toyota.
    I do believe the shaft is made special for their application but not made from special parts.
    I am only interested in the bolt hole center dimension and the u-joint dimensions.
    Name:  U-JOINT DIMENSIONS.jpg
Size:  28.7 KBName:  2-2-899 flange yoke 01.jpg
    I don't think the cost of the flange or u-joint would be prohibitively expensive but using a junkyard recycled part when a new one is available for roughly the same price kinda defies logic. JMHO
    Jim Murphy
    May 2015
Size:  541.0 KBName:  5585A075-42D3-4C1C-B7DE-F4D43F27F4C7.jpg
    Jim, my intention was to have my friend at the junk yard possibly identify my yoke....I don’t plan on buying a used yoke!
    I took the dimensions of the yoke as follows
    end to end dimension of cross.....2-7/16” Cap to Cap
    OD of Caps......1-1/16”
    Bolt Circle......3-1/16”
    Spacing of bolts.......2-3/16” in both directions
    Bore of Raised Face......1-7/16”
    OD of Raised Face......1-13/16”
    Height of Raised Face....3/32”
    Outside width of eyes....2-11/16”
    center of cap to face of flange...1-1/2”
    How did you land on the Toyota components?
    Thanks again for your help!
    Martinsburg, WV
    They were using Suzuki until they stopped importing them ... they now use Toyota gears. It is not a factory made assembly, it is specifically made for Champion using a RAV4 gear set (2.92:1 ratio) in a 8" small truck gear assembly. They use the same part in their straight axle and IRS trikes.
    Jim Murphy
    May 2015
    I’ve been searching on the net for info based on the dimensions I took......so far I’m leaning towards a Suzuki component.
    I’m looking for a Spicer Flanged Yoke 1310 for Suzuki
    Are you saying the Champion flanged yoke is proprietary?
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    I know this is late in the game here,but have you gone to a driveline shop to see if they can fix you up? Or possibly determine what you have?
    Happy TRAils/NSD
    Paul
    May 2015
    I just took the assembly apart today (Sunday) so I haven’t contacted any driveline folks yet!
    Now that I have the dimensions, I will be in touch with them.
    Martinsburg, WV
    Quote Originally Posted by Red Wing One View Post
    The dimensions you gave for the u-joint make it a 1210 type.
    https://www.ebay.com/itm/NEAPCO-N2-2...NZvRVi&vxp=mtr
    GOOGLE SEARCH " NEAPCO N2-2-2323 flange yoke".
    https://www.ebay.com/itm/437-Univers...FZsE9T&vxp=mtr
    Some on eBay...... look at the dimensions.
    Jim Murphy
    May 2015
    Way to go Jim, I believe you nailed it.......I will contact Neapco tomorrow and make sure it has the raised face......when looking at the specs....it has a Pilot Diameter of 1.81M........I think they are saying 1-13/16” Male.
    That is the OD of the Raised face.
    I will let you know how I make out!
    ​Thanks a bunch.....Marcel
    May 2015
    FYI....I received my Neapco N2-2-2323 Flanged Yoke, and it’s a perfect match.....it has a raised face just like the original.
    $38 on EBay.....thanks again Jim!
    Martinsburg, WV
    What about the 1210 u-joint ????
    Jim Murphy
  19. #19
    May 2015
    The U-joint is a 1210 series.....I bought a Spicer 5-443x locally.......it has a Zurk fitting in one of the end caps!
    $27 cdn
  1. Drive Shaft with Front Clamping Yoke Removal
    By Trike Dude in forum General Discussion
    Last Post: 09-06-2020, 09:06 PM
  2. Yoke removal
    By howardg in forum Honda Trikes
    Last Post: 07-16-2016, 08:42 AM
  3. 81GL1100I Driveshaft Yoke
    By Charlie in nc in forum General Discussion
    Last Post: 11-13-2015, 04:43 PM
  4. Front yoke assembly with U-Joint
    By Jimsjinx in forum Honda Trikes
    Last Post: 04-21-2011, 08:30 PM
