Likes Likes:  4
Results 1 to 11 of 11
Thread: heel and toe shifter lever?
    30+ Posts justlucky's Avatar
    Feb 2018
    northridgeville, OHIO, USA
    Red face heel and toe shifter lever?
    Hello, I'm looking for heel and toe lever foot control lever? for kawasaki 2008 vulcan 900 custom, If some one has a used one for sale ?
    200+ Posts
    Feb 2017
    Arp, TX - USA
    It shows listed for a different model (likely because it was factory equipped), but there's one on ebay for less than $50 that may be worth checking out.
    https://www.ebay.com/itm/08-KAWASAKI...RaXnxS&vxp=mtr
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    William, better jump on it !!!!
    Jim Murphy
    Iron Butt Rider 2001
    Feb 2018
    Default Heel and toe lever
    yep did that. And thank you for the tip.
    Feb 2018
    Default heel and toe shifter?
    well got the one I thought would work but nope . still looking - kawasaki vulcan 900 "2008" anybody out thier might have one?
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Quote Originally Posted by justlucky View Post
    If the one you got off ebay was for a VN900 Classic it will fit your Custom because the frame, engine & transmission are the same on the Classic, Classic LT and the Custom but you will need you the whole assembly, including the spline shaft which activates the transmission because that part is different lengths between the Custom and both the Classics.
    Martinsburg, WV
    Quote Originally Posted by ol' school View Post
    The Custom has footpegs not floorboards ..... the bracket for the floorboard has the shift pivot location. I guess you need to either look for floorboard brackets which may also affect the brake pedal location ... or use the heel-toe and weld the heel to your existing toe shifter.
    Jim Murphy
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Yeah, I was including that in my "need the whole assembly" without saying that. I figured he would be changing over to floorboards because a heel toe shifter would be weird to use with pegs I would think.
    Feb 2018
    Default Heel to toe shifter
    yes , looking at whole assembly for floor boards, for both sides. or just weld one on found a freind who is willing to do it.- mabie?
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I went the other way. I have a 2000 vulcan, took the floorboards off, rather have pegs. I couldn't get comfortable l broke my ankle twice and the angle was wrong for me. Got pegs for an 800 off ebay. They were'nt a bolt on but a block of steel and a welder took care of it.
    200+ Posts
    Feb 2017
    Arp, TX - USA
    You'll want to modify your method of searching if you need everything. The Custom as others mentioned only came with pegs. If you want floorboards, full linkages, brake pedal, etc; you'll want to look for parts from a Classic or Classic LT since they both came with floorboards & I THINK they both came with heel toe shifter.
    There are a few on Ebay & prices seem to vary wildly. Might also try calling OZ Powersports in Ottawa Kansas, they have a few salvage ones they're parting out.
  1. Want to install Heel Toe Shifter
    By robval87 in forum Honda Trikes
    Last Post: 03-27-2023, 03:12 PM
  2. Heel shifter?
    By hardwickbv in forum Harley Tri Glide
    Last Post: 09-18-2017, 11:50 PM
  3. Heel Toe shifter Not for Me!!
    By Lone Wolf Top in forum Honda Trikes
    Last Post: 12-29-2013, 08:46 PM
  4. toe/heel shifter
    By electricjaws in forum Honda Trikes
    Last Post: 10-28-2013, 05:41 AM
