BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  6
Results 1 to 11 of 11
Thread: Primary Chain Tensioner
    40+ Posts DamnYankee's Avatar
    Apr 2016
    Lucedale, MS, USA
    Default Primary Chain Tensioner
    At what point do you know it needs to be replaced? Mileage? Noise? Poor shifting? I ask because I'm at 52K miles and there seems to be a clicking noise from that area when I go backwards. Shifts a bit sluggish too.
    Part II...... If it needs to be replaced, stock or after market?
    Part III..... warranty covered?
    Thanks in advance.
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    Quote Originally Posted by DamnYankee View Post
    Thanks in advance.
    Baker makes a self adjuster type of tensioner. It may not be for everyone
    Shifting issues could also be related to other things like,clutch,oil etc.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Is this an automatic tensioner?
    Some get lazy and don't ratchet up
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    There is an independent service shop online that has done the 20,000 mile service on 10 M8's & he says 8 of them he has found the stock automatic chain tensioner has not moved up at all.
    He thinks it's from people not getting on the new engine enough/babying them.
    Jack, Have you heard any noise from yours or checked it yet? I was going to wait until the 20,000 mile service, unless I hear noise sooner.
    I will try to find the post & put up a link to it.
    Here is a link:
    https://www.youtube.com/watch?v=Aw4QVmldQKI
    Oct 2017
    St. Louis, MO USA
    Jack
  6. DKCustoms postbit
  7. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by MDO View Post
    Jack
    Mine is fine so far
    No noise
    I have dogged mine in 4th gear almost til the engine gags, like I did my Streetbob
    This is suppose to speed up the hydraulic tensioner
    I do believe it works
    If not I will pull my primary @ 20k and check it
    I have seen the video you talked about The guy is pretty thorough in my opinion
  8. #7
    Oct 2017
    St. Louis, MO USA
    Mine is fine so far
    No noise
    I agree. His camera work stinks, but when 75% of the 2017's he see's have the same problem, it's a little concerning. He actually had 1 2017 that the screw backed out of the tensioner.
    Thanks for your input Jack.
  9. #8
    Apr 2016
    Lucedale, MS, USA
    Yes, stock 2014 103CI
  10. #9
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    If your adjuster gets too tight the chain will whine Hard on tranny bearings and seals
    Too loose it can slap inside the cover, it may jerk in low gear
    Shifting and finding neutral can be difficult with a chain too loose
  11. #10
    200+ Posts
    Nov 2015
    palm bay
    I agree. His camera work stinks, but when 75% of the 2017's he see's have the same problem, it's a little concerning. He actually had 1 2017 that the screw backed out of the tensioner. .
    Having the screw back out may be problematic but I have to wonder if the 75% isn't just normal wear, or rather the lack of it. My 1990 FLH has some 200,000 miles on the original primary chain. So it's very likely that 75% of 2017s haven't worn enough to move the tensioner. I only have 6000 miles on mine.
  12. #11
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by vito View Post
    These problems were on bikes he was doing a 10 or 20,000 mile service on. The adjuster was not moving at all & the chain had enough slack to cause noise from it slapping the case.
    Watch the video & you can see it in the state he found it & see it after he adjusted it to proper tension.
    This is something to keep an eye on & listen for.
  1. Want to Install a Hayden Chain Tensioner
    By Side by side in forum Harley Tri Glide
    Last Post: 04-18-2016, 01:45 PM
  2. Safety Chain
    By wehrme in forum Trailers / Campers
    Last Post: 07-29-2014, 06:48 AM
  3. Hayden M6 Tensioner- Triglide
    By RLanning in forum Harley Trike Conversions
    Last Post: 08-26-2013, 06:14 AM
  4. primary chain adjustment
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 03:03 PM
