Likes Likes:  13
Results 1 to 20 of 20
Thread: Noise from gas tank and lots of air pressure
    10+ Posts
    Apr 2016
    Farmers Branch
    Question Noise from gas tank and lots of air pressure
    I rode in mid 80's weather for about 26 miles to get home Saturday. When I pulled in the garage and got off the bike I heard a weird sound and after getting closer realized it was coming from the gas tank. I slightly unscrewed the cap and could hear the air hissing from the tank. I loosened a bit at a time until it stopped. I put the cap back on and got a few things from the bike and uncrewed the cap just a bit again and even more air pressure. What the heck is going on? Most of my riding will be in much warmer weather and longer distances when I get moved to Midland in June, so I want to figure out what the problem may be and if it is even a problem or me just fretting.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Is your gas cap OEM? Your right side gas cap should be the vented type. Possibly there is something wrong with yours.
    If it was venting properly, the pressure would not build up.
    Dec 2014
    Grand Junction, Co. USA
    You might check the tank vents. Have you or anyone else removed the tank? If so, there's a chance the vents got crimped, although it seems unlikely.
    When you put the cap on, do you tighten it until it clicks at least once?
    Oct 2017
    St. Louis, MO USA
    Is this a Freewheeler trike? I noticed you said you got off the bike.
    I have a knife addiction..
    Gone2Three's Avatar
    Aug 2016
    Pflugerville, Tx
    Hello neighbor
    I've had this happen to me before well, especially when the tank is low on fuel.The gas tank sits right on top of a hot engine, so as long as there's air moving over the engine and the bottom of the tank, you are removing the heat as it builds up. When you stop moving, you have heat build up in the gas tank which is probably the hissing you are hearing. The gasoline is actually expanding inside the tank resulting in air being expelled possibly at the cap through a relief.If you are worried I'd run it by the dealer and have them check it out.
    Safe travels friend....
  6. #6
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Quote Originally Posted by LinDIVA View Post
    Hey Linda....let me know when you get here. We can meet up for a coffee if you like. Carla
  7. #7
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    # 4 and 5 is your vent line, it runs from the tank under the seat down the left side and exists below by your belt
    It may be plugged up
  8. #8
    Oct 2017
    St. Louis, MO USA
    Hey Jack, Do you know for sure that this is a Harley? It says GL1800 in the Sig.
  9. #9
    10+ Posts
    Apr 2016
    Farmers Branch
    Quote Originally Posted by paws View Post
    Most definitely!!! Are you involved with a riders group in the area?
  10. #10
    10+ Posts
    Apr 2016
    Farmers Branch
    I will get it checked...thanks!
  11. #11
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    I do belong to one club at the present but they aren't very active with riding.
    I did belong to another group but their few rides consisted of inviting the "chosen" one, then riding hard and fast to the next bar. If this wasn't your style then you were only good to them for buying "chance" tickets at the meetings and bringing food.
    There are a number of independent riders out here - you catch them at the gas stations or restaurants.
    There is the Harley Owners Group - but I don't have a Harley...got a Gold Wing.
  12. #12
    10+ Posts
    Apr 2016
    Farmers Branch
    Quote Originally Posted by Gone2Three View Post
    Hello neighbor
    I was low on fuel, so I think I NEED to take it and fill it up and ride to see if it does it again. That along with checking to make sure the cap clicked, and trying it with the original (not as cute) cap that is still in the trunk. I knew I needed to hold on the original cap, just didn't know why...LOL!
  13. #13
    10+ Posts
    Apr 2016
    Farmers Branch
    Quote Originally Posted by MDO View Post
    Old habits, I have always called it a bike from the two wheel days (Boulevard and Heritage).....so I guess I will continue to call it a bike although it's a trike.
  14. #14
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Like you say, Old habits........Besides Bike rolls off the lips easier then Trike....
    2019 Tri-Glide.......
  15. #15
    Oct 2017
    St. Louis, MO USA
    So is the replacement cap vented? You can order them both ways, unvented & vented.
  16. #16
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Dunno Michael, it was posted under the Freewheelers
  17. #17
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Under her profile ;About me.....She says Current ride 2015 Freewheeler....
  18. #18
    10+ Posts
    Apr 2016
    Farmers Branch
    It's a Harley Freewheeler. There was something screwed up with my signature. I had a signature and a graphic...the graphic no longer appears to exist, but GL1800 the name of the missing graphic was printed. I just took down the dang signature. Too much to deal with...but at least I now know why the question. thanks!
  19. #19
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Linda, for what its worth
    My 2015 and my 2017 Freewheeler have both gushed when my tank was low on fuel
    I cleaned out my vent hose on both trikes problem solved
  20. #20
    Dec 2014
    Since I had the tank off again (This time to route PV wire), I took a pic showing the vents, probably a little different on a free, but, you get the idea.
    Name:  Gas Vents.jpg
  1. Air pressure VS. Tire wear
    By Thomas L in forum Harley Tri Glide
    Last Post: 03-13-2018, 06:01 AM
  2. Air pressure in shocks - how long does it last
    Last Post: 03-07-2018, 08:34 AM
  3. Bigger gas tank
    By Grumpy7760 in forum Harley Tri Glide
    Last Post: 03-04-2018, 08:41 PM
  4. What gas mileage should I expect
    By dsctr in forum Harley Trike Conversions
    Last Post: 02-25-2018, 08:22 PM
