Likes Likes:  15
Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: Miles Between Oil Changes
  1. #21
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Burnerboy View Post
    Changing oil is so easy and simple (talking Goldwing here) if you do it yourself, I usually replace every 3,000ish miles (if yea have your dealer do it for you, then that's another story, very expensive then..Always replace BOTH filter & oil at the same time...
    A couple of years ago, I had cut open a oil filter on one of my service trucks, I was just curious to see what it looked like after 5,000 mile...Well there was so much gunk in there that it would be hard to flow , all plugged up! That turned me into a true believer to replace oil/filter at the same time, and at a 3,000ish interval...
    I purchase oil and filter(s) when I happen to see it on sale, I have approx. 8 to10 filters left (for my wing) unopened in my garage along with a case of mobile one synth, oil just ready to be used.....
    PS: I just changed my plugs along with oil/filter last week on my bike getting her ready for this spring rides..(if it will ever get here)
    Ronnie
    You bring up a really good point. If I was still using paper filters, I would probably still be changing oil and filter every 2500-3000 miles.
    I've been using the Stainless Steel cleanable filter so long, I forgot about that...I just clean them out every time I change the oil...in fact, sometimes I'll skip cleaning the filter til the 2nd oil change. They flow that much better!
    www.DKCustom.com
  2. #22
    450+ Posts TonkaDriver's Avatar
    Feb 2018
    Bagdad, AZ, USA
    Quote Originally Posted by GARYD View Post
    Syn = 5K~6K
    Dino = No more then 3K
    Filter each time.
    Amsoil 20-50 (preferably) but will use any brand name oil that's on sale = engine
    Amsoil 75-140 Gear oil = trans
    HD Formula+ = primary
    If the engine oil is clear at time of change = it's NOT working.
    I am new to Harleys and am going to do my own oil changes because
    I got a quote of $300 for a 3 hole change. I watched a few youtube videos and it looks pretty simple to do. The manual calls for 20-50 in the trans. What is the benefit of Amsoil 75-140? Does the thicker oil affect power at all?
  3. #23
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by TonkaDriver View Post
    I’m old school, as gears need gear oil. Redline shock proof is what dealers are using. What ever you choose, use synthetic as it has a longer run life.
  4. #24
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    I can't feel and power issue....but I can say My trike loves the 75-140. Smooths a lot of those clunk shifts and all thru the RPM curve shifts...IMO only
  5. #25
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    There are SO many good answers here, IMO gear lube in the tranny is your best bet
    It can cushion the gears better and stay put at higher temps than oil
    It is your ride YOU decide what is right
    I have ALWAYS run gear oil in ALL my bikes, and never had any tranny issues
  6. DKCustoms postbit
  7. #26
    Dec 2014
    Grand Junction, Co. USA
    I do the engine at 2500 miles and all three at 5K.
  8. #27
    2500+ Posts GARYD's Avatar
    Oct 2011
    GLEN ELLYN, IL. USA
    Quote Originally Posted by 1dn5up View Post
    What dealers are using Redline instead of Syn 3? All the dealers in my area( 7 - owned by the same people) use H-D Syn3.
    Although, I do remember my dealer using Bel-Ray gear oil back in 03 when I had a 6 speed put in my 03 Ultra.
    IBA#61162
    PATRIOT GUARD
    USMC
  9. #28
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    My dealer uses HD Formula + Trans oil Syn.....
    2019 Tri-Glide.......
  10. #29
    Oct 2011
    GLEN ELLYN, IL. USA
    I cannot believe a single product can do the best job of protecting three different functions. For the miniscule cost difference, I will use the best product for each application knowing I'm getting the BEST protection possible.
    You have to be out of your mind to pay $300 for a 3 hole fluid change.
    With all the complexities of a new motorcycle, changing the oil is one of the last simple things an owner can do themselves - if they have the right tools, time and place to do so. Good luck
    IBA#61162
    PATRIOT GUARD
    USMC
  1. Anyone else using the SS recleanable oil filter on TG?
    By Rooster57 in forum Harley Tri Glide
    Last Post: 03-28-2018, 01:37 PM
  2. Oil Change
    By rocket1lf in forum Stallion Trikes
    Last Post: 03-05-2018, 06:19 PM
  3. motor oil
    By sanfoz in forum Harley Tri Glide
    Last Post: 02-20-2018, 04:22 PM
  4. Freewheeler M8 Oil Temp
    By Jack Klarich in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-18-2018, 10:29 PM
  5. Changing oil
    By JerryC in forum Stallion Trikes
    Last Post: 01-20-2018, 11:17 PM
