Results 1 to 2 of 2
Thread: Is there a forward U Joint Zerk on 03/04 Champ trike ?
    100+ Posts wingit's Avatar
    Jul 2015
    Richmond Mn.
    Default Is there a forward U Joint Zerk on 03/04 Champ trike ?
    Hi guys, Its hard to see without taking the rear down to pull the D shaft.
    Is there a forward U Joint Zerk on 03/04 Champ trike solid axle ?
    Maybe the rubber boot covers the front U joint zerk ?
    thanks
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    If front joint is stock honda part I don’t think it can be greased
  1. zerk on differential?
    By bikerbill in forum Harley Trike Conversions
    Last Post: 04-14-2024, 06:19 PM
  2. Motor Trike 3rd Generation Driveshaft zerk fitting
    By tndragonrider in forum Honda Trikes
    Last Post: 05-22-2016, 02:19 PM
  3. Wheels forward trike vs standard wheels back trike
    By RTwing in forum Other Brands Trikes
    Last Post: 08-26-2014, 08:42 AM
  4. VW trike,forward mounted motor
    By BIBS in forum VW Powered Trikes
    Last Post: 07-13-2014, 01:37 PM
