ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  24
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 43
Thread: Where to put front wheel? In center of lane, little left? Little right?
    80+ Posts tbird71's Avatar
    Feb 2018
    Lake Placid, FL (winter) Ramsey, IL (summer)
    Default Where to put front wheel? In center of lane, little left? Little right?
    Where's the best place to put your front wheel when riding down the hi way?
    Squarely in the Middle? A little to the right of center? A ltttle left?
    I was concerned about oil slicks in the middle...
    100+ Posts
    Sep 2013
    Excelsior Springs, Mo
    I stay in the middle if possible. Have not had a problem with oil slicks.
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by tbird71 View Post
    A little to the right...
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    A little to the left of center for me.
    800+ Posts Motorcycle Mike's Avatar
    Jul 2014
    Lawrenceville, Ga
    I stay a little left of center most the time.
    You don't quit riding because you get old.
    You get old because you quit riding.
    Mike & Shirley
    Depending upon on coming traffic, [On a two lane] A Little to the right , Or a little to the left...On multi lanes that depends on the traffic to the left or right of you..., You really don't want to ride dead center in a lane, Junk on the road, And also the front tire will try to move off the the crown in most roads and give the handle bars a jigging sensation...
    Left of center a skosh
    60+ Posts firefighter4634's Avatar
    Dec 2016
    Moville Iowa USA
    Don't know if its right or wrong but, I run with the front tire just left of center lane and will move over a bit for on coming traffic on two lanes and for people passing on four lane highways.
    80+ Posts 3FOR2's Avatar
    Jun 2013
    Moyock, NC. USA
    I'm all over the place - trying to dodge potholes!!!
    Quote Originally Posted by 3FOR2 View Post
    Pot-Holes in Pennsylvania,
    I thought all the Pot-Holes were moved to New Jersey..
    Sep 2016
    There now you have your answer(s)
    I bet now your 100% sure of where your front wheel should be! OR are you 100% more confused!
    Feb 2008
    Anderson, Missouri
    Ride where you're most comfortable.
    That said, I ride with the front tire just to the left of the lane center line. Most roads, if they are well used, have 2 slight valleys or wheel ruts where 4 wheelers wear or compress the road surface. If you ride a bit to the left of the center line of the lane your front tire is running on the side of the left wheel rut, being pulled slightly back to the left against the crown of the road, cancelling out the pull to the right. Again, as roads vary, how much off the center will depend on the original crown of the road and how much the road is worn by cars and trucks.
    You'll have plenty of room - you needn't ride much off center and your trike won't be too close to the middle of the road, though I generally like to ride with the outside of my fender just a few inches from the center line stripes. Riding to the left also gives me somewhere to go if an oncoming vehicle strays into my lane, and may let me see a few more feet around a curve. Seeing that few feet can make a big difference in getting hit or missed by an inch.
    Just don't get too far one way or the other ... it encourages cages to "Share" your lane.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I'm in the slightly left of center school of thought on most roads.
    Riding back to Missouri from CA, on a clear highway with the cruise control set, the center was fine. All my years on 2 wheels, I avoided it like the plague, but on the trike, it's fine.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    I just keep adjusting until the ride feels ok.
    The roads vary so much - even the same road can vary.
    I don’t think oil slicks would be that big of concern on a trike - unless you can see it is really a mess...if it was visibly bad then I’d have to think about changing to another road if possible.
    And no... I won’t do staggered formation riding like some of the 2-wheeler groups will do..I like my own space.
    550+ Posts
    TwoBye's Avatar
    Feb 2014
    Washington C. H.
    I will always allow the road to dictate where I ride (to a point). But I will ride in a staggered formation with multiple trikes BUT with at least (at the VERY LEAST) a car length or two behind the guy in front of me and that distance between myself and the rider following behind me. Trikes need a lot of room to move around to negotiate potholes/trash/animals etc... If riding solo then I'm all about letting the road set the pace and position. It is never the same for any two trikes OR and two trike riders.
    ... Made the journey (from 2 to 3 wheels) now enjoying the ride ...
    Brad [TwoBye]
    250+ Posts 2Paps's Avatar
    Jan 2016
    W FL Panhandle
    By now I'm sure you've got the idea that there is no rule other than ride safe and know that you're a slave to your environment.
    If you're like most of us you'll find yourself favoring the left half of the lane simply because that's where you've always ridden (except in groups) when you were on 2 wheels.
    Never forget, your trike has a fat rear end!
    Ride on!
    Tryke Flyer!
    2010 GW 1800 with 2010 CSC Cobra kit
    2010 Kawasaki Voyager ABS with 2016 CSC Kruze Kit - Gone but definitely not forgotten.
    4750+ Posts
    Mar 2015
    Texas
    Just left of center until a 18 wheeler comes along. Then it's full right and a dive back to center as it whizzes by. But even that depends on just how much cross wind there is. So like everyone, just ride your own ride and what you are comfortable with. I just like to try not to get really blown around with 18 wheelers so I try to hit that gust of wind as square as possible. Two trucks and I look like a drunk but so what.
    American Legion Rider
  19. #19
    paws's Avatar
    Kerrville, TX U.S.A
    Sorry, double-post somehow this morning....
  20. #20
    paws's Avatar
    Kerrville, TX U.S.A
    Re: Truck wind blast...
    For me.... I learned a long time ago when riding a 2-wheeler to lean forward as much as possible over the tank. (Yes - your elbows will be sticking up in the air) At the same time keep your eyes on the road and a firm grip on those handlebars. Putting a squeeze on the tank with the knees helps further keep you seated. It has always worked pretty slick. There is not near the “shake, rattle, and roll” from those trucks. Also, the passenger on your bike or trike needs to lean forward with you. Had lots of practice out here in the wilds of west Texas on the 2-lane state highways.
  1. Looking to put trike behind our 5th wheel any suggestions
    By Retfireman in forum General Discussion
    Last Post: 09-14-2023, 06:50 AM
  2. Rear Wheel Center Cover
    By moonstar in forum Harley Freewheeler / Road Glide 3
    Last Post: 09-25-2019, 11:09 AM
  3. Replacement Wheel Center Cap
    Last Post: 04-16-2015, 11:58 AM
  4. Looking to put trike behind our 5th wheel any suggestions
    By Retfireman in forum Trailers / Campers
    Last Post: 03-24-2014, 04:06 PM
  5. Tri Glide rear wheel center emblem
    By meredog in forum Harley Tri Glide
    Last Post: 12-25-2012, 12:50 PM
