SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Likes Likes:  1
Results 1 to 4 of 4
Thread: rear shock
    30+ Posts justlucky's Avatar
    Feb 2018
    northridgeville, OHIO, USA
    Default rear shock
    I was trying to wire in running lights on my vn900c and notice that the rear shock was at the top peg? it does ride stiff and was wondering if thier is a reason for this before I try to adjust it? thank you in advance Lucky :-)
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by justlucky View Post
    Having purchased it used, the previous owner may have adjusted it to maximum pre-load. Your trike should also have an airbag mounted between the rear axle and the body too. The air valve is located under the seat and should be set at 20 psi (hand pump only). For the coil-over-shock I suggest the middle setting (there are 5 settings I think) and try it there, if it is still too harsh, put it in the lowest setting. It is easier to do this if the back wheels are suspended too.
    Jim Murphy
    Iron Butt Rider 2001
    Feb 2018
    Thumbs up rear shock
    that is what i thought . but was wondering about the exchaust. if that was the reason .but it should flex a little ?
    Martinsburg, WV
    If the exhaust was changed after the conversion by the previous owner, it could interfere but that would be noticeable when you ride the trike also.
    Jim Murphy
  1. Rear Shock Adjustment
    By zrturbo in forum Roadsmith Trikes
    Owners Forum
    Last Post: 04-15-2018, 06:46 PM
  2. rear shock quandary
    By Trikesyke in forum Harley Tri Glide
    Last Post: 07-29-2017, 03:14 PM
  3. Rear Shock
    By manxnorton in forum Can Am Spyder Trikes
    Last Post: 07-05-2017, 05:54 PM
  4. Tr-Glide rear shock options with shock lift mount.
    By rick1201 in forum Harley Tri Glide
    Last Post: 02-12-2016, 01:50 AM
  5. Rear Shock
    By rgc in forum Harley Trike Conversions
    Last Post: 09-06-2012, 10:09 AM
