SSpoon5trike ladyNew Member Introduct...Hello from VA
gfaltersack1gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon5SullyNew Member Introduct...Hello from VA
SSpoon5Jack KlarichNew Member Introduct...Hello from VA
SSpoon5GorillaNew Member Introduct...Hello from VA
SSpoon5SSpoonNew Member Introduct...Hello from VA
Likes Likes:  4
Results 1 to 10 of 10
Thread: $150.00 bucks for a piece of screen?
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Default $150.00 bucks for a piece of screen?
    No thanks H.D. So I wanted to cover my oilcooler because my luck sucks and it'll be just a matter of time before something hits it.So I had some old fireplace screen laying around and I cut and bent it to fit inside the plastic cooler cover and used 2 part epoxy to hold it.Works and the price was right.I don't think a direct hit with a 2 inch rock will even put much of a dent in it.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Old Road Dog View Post
    You just voided your warranty by useing an Un- authorized screen 🙄📞😁
    2019 Tri-Glide.......
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    I did the same with some outdoor grill materia
    I cut it and notched it so no glue is needed
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Uh-oh.Maybe I should get the SE tuner so its 50 state compliant so it will be set to the factory lean condition.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Hey Jack just curious nothing more than that but !. Have you ever taken The oil temperature before you put on the screen and then Taken it after you put the screen on! Me Being an old woodsman I found if you put a screen in front of a fireplace it will trap the heat in the fireplace just wondering if a screen will trap the heat in the oil cooler And in turn cause the engine to run hotter 😱 Just something to think about 😱📞
  6. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Yup, it did not change any
    I was surprised it still flows that much air, tho it does have a fan on it also
  7. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    And without the fan.....
  8. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Unknown, mine is oil cooled not twin cooled
    The fan comes on @195 degrees and stays on
    I also run Mighty Mites on the heads
  9. #9
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    If the mesh cover leads to overheating then H.D. wouldn't sell their overpriced version-at least I would think.
  10. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Yes but theirs are engineered to perfection and guarantee to last for many carefree miles of happy motoring through hill And Dale🙄😁
  1. New Roadsmith Goldwing Trike Broke within 150 miles
    By 802MARK in forum Honda Trikes
    Last Post: 02-07-2024, 08:56 PM
  2. ***Limited Time*** Savings Code on over 150 Winter Mods
    By DK Custom Products in forum DK Custom Products
    Last Post: 01-11-2017, 05:49 PM
  3. 150 Year Old Steamboat-Part One
    By David357 in forum General Discussion
    Last Post: 03-20-2016, 12:45 PM
  4. Valkyrie Front Bias in 150/80-17???
    By abcdleines in forum Honda Trikes
    Last Post: 03-20-2014, 07:41 PM
