14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Results 1 to 11 of 11
Thread: Just replaced new front wheel/What's better??
    Sep 2016
    Springfield, Mass. USA
    Default Just replaced new front wheel/What's better??
    Ok I just purchased a new front tire,
    What is the better way to balance this tire??
    A) The old way with a weight glued on to the rim
    B) Those beads in the tire
    C) Cemetric (spelling??) thingy on the wheel
    D) Any other idea's
  2. Roadsmith banner
  3. #2
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    All mine get the Marc Parns ballance beam treatment. Takes time and patience. 100% accurate using sticky weights.
  4. #3
    Moonshine Mike
    Oct 2015
    st. albans
    I used centramatic balancers, balances wheel regardless of tire ware.
  5. #4
    I'll be watching this thread closely. I've been looking into Ride On. Here in western Colorado, we have lots of wide open spaces. You get a flat out here ... it's just you and the desert critters ... LOL.
    I've read lots about Ride On and apparently the product does a decent job on sealing tire punctures and balancing tires. I'm sure the people using it in their wheels will be chiming in shortly.
  6. #5
    Jun 2010
    Indianapolis, In.
    Been using RideOn for years. Good stuff for all vehicles.
    The only negative is the Honda TPMS senors are not coated, RideOn can't be used with this system!!!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Sep 2016
    Quote Originally Posted by mwebster View Post
    Ok question here: What exactly is the centramatic balancer?? I know that I mentioned it in my first post (heck I couldn't even spell it correctly) But I have only heard of it, on this board... I've seen the beads, I've seen the weights, but confused to what exactly that centramatic 'thingy" is
    Thank you!
    Moonshine Mike
    Oct 2015
    st. albans
    Go to Wingstuff trike accessories, there's a couple of videos
    Mar 2011
    mountain home,ar. USA
    Thank you!
    http://wingstuff.com/products/34645-...?from_search=1
    I use the Centramatic balancers on the front wheel because I have to install new tire every 11 - 13,000 miles due to riding in the twisties on chip/seal road most of the time. By using the Centramatic balancers, which keep the wheel balanced regardless of wear, debris in the tire, etc., I don't have to worry with beads (which I use in my ST1300) or Ride ON with the frequent tire changes. One and done!
  10. Roadsmith banner
  11. #9
    Sep 2016
    Quote Originally Posted by mhgoldwing View Post
    WOW! After reading/hearing all the speeches about this product, I guess you can't go wrong with this product!
    Question here again: (thanks you all) I just replaced my front tire with old fashion lead weights.. (as Of now I have ZERO miles on my new tire/ way too cold/ too ride)... If I purchase this centramatic balancer,[A] do I remove the lead weights all ready added? [B]Can I ride this tire and then replace with the centramatic balancer after I have ridden it with a 1000 miles on the tire. [C] Once this has been added to wheel I will never have to replace, balancer with another ..Correct??
    Thanks guys
  12. #10
    Mar 2011
    Thanks guys
    You can add the Centramatic any time. While it might not hurt to leave the lead weights on I would remove them simply because they are not needed and are literally "dead weight".
    Correct: if you install the Centramatic balancers on the front wheel you will never have to do anything else to balance tire. If the Centramatic balancers cannot balance the tire then you've got a serious problem with the tire/wheel which needs further attention.
  13. #11
    Sep 2016
    Thank you Mike!
  1. 16x5.5 inch rear wheel converted to dual dics front wheel
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2022, 08:29 PM
  2. Front Wheel--Rear Wheel
    Last Post: 08-06-2015, 12:45 PM
  3. Replies: 5
    Last Post: 12-08-2014, 01:03 AM
  4. replaced front tire
    By meredog in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-05-2012, 09:37 PM
  5. Who has replaced their REAR tires??
    By cjmitch in forum Honda Trikes
    Last Post: 01-19-2011, 08:41 AM
