ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  505
Thanks Thanks:  39
Page 18 of 26 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 341 to 360 of 504
Thread: Rebel RT
  1. #341
    450+ Posts
    Mar 2018
    Fernley
    So I need to ask, kinda would like to know your design idea, anyhow on the sides the cardboard looks flat against the wind flow, the area past the handle bars.Is this going to disappear when finish out the front cone, like mold into the front with some curvature ?I see what you have, is air vents going to be in that area so air pass and does not create a drag, if that is the right word.Not even a curve, just a plater piece coming of the front narrower piece, on a angle, to meet and blend into the outer (wider) side panels. If the design was for fastening to frame, could you still not blend in such a piece so you get a smooth air flow over the ride ? just hit me, your project, more wondering what and how you do this, like I said " very interesting to me " and I enjoy it all.Happy Holidays to All
  2. #342
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Happy TurkeyDay
    Happy Turkey Day everyone, Name:  Happy TurkeyDay.jpg
    and thank you again for all your help with my project RebelRouser.
    JakeJacobsen@Pinterest.com
  3. #343
    May 2016
    Hemet, Ca. USA
    Default Reply
    Quote Originally Posted by grandpanystrom61 View Post
    Thank You Andy, I am not good at drawing or CAD so I have to see what's in my head, I use graph paper to show me 2D, sides and ends, but the real life look is 3D (look at Shenanigan's I had to build the plastic model to scale, to see if I really liked it, and I really love that design and the 2 side X side version) RebelRouser nose and side panels will improve the looks, hiding the frame I did not really want to do but I can not make this frame look clean and simple, (Shenanigan's yes) And this design is rough and most of you like it as me but remember the exhaust, large sides of engine, foot controls need to be address with the body sides. So I will see when final welding and pre paint assembly is complete, Then I will go back to body panels, fiber glassing, paint...
  4. #344
    450+ Posts
    Mar 2018
    Fernley
    That is all very true TomyJ, it is a long process with a lot to it, something you surely do not want to just " jump in feet first" with, LOL.I got a bit ahead of you and did not mean to do that, and I see what you mean about it all. My wife says I get "tunnel vision" to much, thinking she maybe on to something, but it is awesome to watch and learn and see it all happen.Hope all had a good Turkey Day and all can enjoy the Holidays.
  5. #345
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    I was wondering,when you get to the fiber glass, if you ever saw this way of making a mold. I found it looking at how the guys put big speakers in the back of their car. They build a fiber glass base for them.
    I've used it on a couple of things. You make a shape you want then pull cloth over it. I used a fleece material but an old T shirt would work. The fleece stretches in both directions so it's easier to get the shape you want. After it's shaped you put a coating of fiber glass resin on it. When it drys you have a mold to build fiber glass on.
    You can transition from round to square easily and you can make complex curves. I pulled the cloth tight to show what is possible. Hope this helps.
  6. #346
    May 2016
    Hemet, Ca. USA
    Default Rear brake
    Name:  1-RT Brake system.JPG
Size:  938.2 KBName:  M-C Caliper Bracket Mount For Harley FXSTS-l1600.jpg
Size:  165.2 KBName:  M-C Caliper Polished Ultima 4 Piston Caliper w-Pads for Harley 0..jpg
Size:  23.1 KB(Bracket is showing opposite side)
    Damn $280, then the master cylinder and hose, Ohhh yes!!! It is going to look so KOOOL!
  7. #347
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    yep...that back wheel is begging for bling!....looking good!
  8. #348
    May 2016
    Hemet, Ca. USA
    Default Up date
Size:  769.9 KBChain Gard to clear seat, Name:  TomyJ-ride heigth.JPG
Size:  851.8 KBOK, OK, OK!!! Here I am in all my glory at ride height, Name:  Dual front brakes and 2 wire.JPG
Size:  821.3 KBDual front brakes and 2 wire, cables seem to reach OK?
  9. #349
    May 2016
    Hemet, Ca. USA
    Default Mrs RebelRouser
    Now remember she is 5FT tall and maybe 98 Lbs. so look at her reach, Name:  HPIM4021.JPG
  10. #350
    May 2016
    Hemet, Ca. USA
    Default Dual HeadLights
    Have to have headlight @ 22"+ with lo-hi beam and hi beam indicator, The upper light is from the Honda Rebel (bottom mount and after market I think) and smaller than the 7" light from my custom gScooter side mounts.Name:  Dual Headlights.JPG
Size:  960.6 KB Horn bracket next...
  11. #351
    May 2016
    Hemet, Ca. USA
    Dual headlights and the swing arm ends fit for a little dressy chrome...Name:  One headlight.JPG
Size:  887.0 KBName:  Duals.JPG
Size:  781.5 KBName:  Swing Arm chrome ends.JPG
  12. #352
    May 2016
    Hemet, Ca. USA
    Default OMG Brake pedal assembly
    OMG! Name:  HPIM4043.jpg
Size:  805.6 KBYou just got to love eBay day
    OMG Brake pedal assembly fits so close to frame I do not believe it, Name:  HPIM4044.jpg
Size:  732.6 KBName:  HPIM4045.JPG
Size:  827.7 KBName:  HPIM4046.jpg
Size:  675.6 KBName:  HPIM4047.jpg
Size:  664.6 KBName:  HPIM4048.jpg
Size:  700.4 KB And then, tired of the trike and the table taken up so much room,Name:  RT hop on top.jpg
Size:  661.2 KB so PiggyBack,
  13. #353
    150+ Posts
    Jan 2011
    Wow, It looks like someone was watching you and made that brake assembly just for your trike.
  14. #354
    450+ Posts
    Mar 2018
    Fernley
    That is just great, always a pleasure when parts go into place as we imagined. All is getting so much closer to that final day. Love to see it happening.
  15. #355
    May 2016
    Hemet, Ca. USA
    Default Work Table
    Work Table set for engine reinstall and more floor space.Name:  Engine re-install.jpg
Size:  693.7 KBLeveled table and made drawings for the brake pedal bracket.
  16. #356
    May 2016
    Hemet, Ca. USA
    Default Snail Mail
    Must be shipping them in SNAIL MAIL?Name:  RT Caliper & Bracket.jpg
Size:  497.7 KBOrdered them together,
  17. #357
    May 2016
    Hemet, Ca. USA
    Default OMG-Snail Mail
    Can you believe this shit? Caliper and bracket due in Hemet Ca. 12-24-2019, They (USPS) sent it to Hawaii, eBay and RiverCityCycleParts "NOT MY FAULT", I hate doing business with ass holes...
  18. #358
    May 2016
    Hemet, Ca. USA
    Default Caliper and Bracket
    Well they arrived this morning with 2 letters for a neighbor who lives on the side street so it was a differant street name and a 4 diget address, WTF! No more USPS shipping for me F--- THEM, Name:  Caliper & Bracket (2).JPG
Size:  894.9 KBNeed to align the axle a little more and then weld a 1/2" bung into place. What do you think guy's??? Love to hear your opinions...
  19. #359
    May 2016
    Hemet, Ca. USA
    Default Pedal & M/C Brackets
    I was ready to re install the engine and am really glad I did not. I can not believe how hard it is to take the measurements for the M/C, DAMN! Name:  M-C measurements.jpg
  20. #360
    May 2016
    Hemet, Ca. USA
    Default HappyNewYear
    HappyNewYear and this M-C templet is the last of year 2019, Name:  HPIM4070.JPG
Size:  937.8 KBName:  HPIM4071.JPG
Size:  738.1 KBName:  HPIM4073.JPG
Size:  567.0 KBName:  HPIM4074.JPG
