Likes Likes:  1
Results 1 to 10 of 10
Thread: Is this the same as Oberon?
    60+ Posts
    Jan 2018
    Milton Mills NH
    Yes, And thats what i'm using, It makes it easer to engage the clutches friction point ...Some find that the lever could be a little longer and that on the #1 position you can't start in gear, I have no problems with either, I only use the #2 position...And the length of the lever works for me,
    60+ Posts
    Jan 2018
    Milton Mills NH
    Yes, And thats what i'm using, ...
    Thank you
    200+ Posts Kristie's Avatar
    Aug 2016
    Center, ND
    I also use the Oberon, both clutch and brake. I don’t think my hands are that small but with the stock clutch I could hardly reach. I have it set to 1 and have no problems starting it. I only got the brake lever so they’d match.
    Jim (Gunnar on this site) and Kristie Buschta
    2017 Harley Triglide Ultra, Bonneville Blue/Fathom Blue, too many extras to list!!!
    100+ Posts
    Jul 2017
    Blacksburg, Virginia
    I have a set waiting to be installed. Looking forward to trying them out.
    60+ Posts
    Jan 2018
    Milton Mills NH
    Got one on the way. I will put it on as soon as I get it.
    250+ Posts
    Nov 2012
    Bradenton, FL.
    I bought the clutch only and as I have Get a Grip magnum grips installed the lever will only work right in position 3 it will not start in gear in position 2 and will also stall for some reason. I will be taking it of to see if it is possible to remove some material from the lever to let the neutral switch come out further so I can keep the lever at the 2 position which I like. I also like the Get A Grip grips.
    2019 Red and Silver Tri Glide
    60+ Posts
    Jan 2018
    Milton Mills NH
    Quote Originally Posted by hddocfl View Post
    I installed the clutch lever today, got it on with no issues, problem is no start in gear.
    The switch button is coming all the way out as far as I can see. Possibly the switch is defective?
    Nice have the clutch grab somewhat close to the grip like it should.
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    $153 for a lever! Are you kidding me? You can do 4 shocks on a classic Chevy for that.
  11. #10
    550+ Posts
    520fd's Avatar
    Aug 2010
    Davenport, Iowa USA
    Now you have Large Grips if that's what I'm led to believe. I have Large grips also, and having trouble starting in gear. I have stock levers. So if I changed to smaller grips, the starting in gear might get better? I've heard something like that before. Thanks.
    Jerry
    2022 Tri-Glide Black.
  1. Replies: 5
    Last Post: 07-08-2017, 05:54 PM
  2. Replies: 12
    Last Post: 05-14-2017, 03:57 AM
  3. 3 Honda Trike Problems in same week
    By skibridg in forum Honda Trikes
    Last Post: 09-09-2013, 06:53 PM
  4. Are Lehman Exhaust same as original
    By ProudTexson in forum Lehman Trike
    Last Post: 12-03-2012, 11:33 PM
  5. same filter?
    By shiney b. in forum Honda Trikes
    Last Post: 06-25-2009, 07:36 PM
