14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  1
Results 1 to 10 of 10
Thread: Roadsmith HTS Rear Tires
    3250+ Posts Hot Rod 1's Avatar
    Jun 2012
    Saratoga County, New York
    Default Roadsmith HTS Rear Tires
    What are good replacement rear tires for a Roadsmith HTS and what is the best way to balance them ?
  2. Roadsmith banner
  3. #2
    Sep 2012
    Lakeland, FL
    Good question, I'm following this thread. Balance and protection, I use Ride-On, you can read about it here an get comments as well, there's also an official Ride-On link.
    https://www.amazon.com/Ride-Tire-Bal...ews/B00DX8BTUG
  4. #3
    Mar 2011
    mountain home,ar. USA
    My current replacements are Michelin MXW4 or something like that. They are no longer made. Personally, whenever I change these I will look for an all season touring tire that has an "open" style tread to better channel water away.
    As far as balancing I take my wheels to my local Chevy dealer and have them Road Force balanced. Has worked well so far. I'm not a fan of liquid anything in my tires. Beads can be used as supplemental balancing material but tires must be weight balanced also because they require lateral balancing. Check out this link:
    http://www.innovativebalancing.com/
  5. #4
    May 2011
    San Angelo
    Quote Originally Posted by mhgoldwing View Post
    I could not have said it better!! Discovered Road Force Balancing while trying to solve major vibration issues with my '06. Problem Solved!!!
    2015 GL1800/Roadsmith HTS1800
  6. #5
    Jun 2012
    Thanks for the responses. I’m Thinking about Michelin Premiers . I have them on my wife’s CRV and they seem to be a good tire. Anyone have any thoughts on that tire ?
    Sep 2012
    Lakeland, FL
    You might pose this question over on the 'other forum', the more 'eyes' the more answers you might get. Having said that, I'm not a fan over there, jus sayin.....
    250+ Posts poppajim's Avatar
    Aug 2013
    Felton DE, USA
    Since you have automoblile wheels and tires there is no reason not to have them properly balanced. Road Force is the best
    200+ Posts lgjhn's Avatar
    Jun 2013
    SW Louisiana
    Quote Originally Posted by Hot Rod 1 View Post
    I recently put em on and they seem to be doing fine. I've been caught in the rain a couple of times and they seem to channel the water pretty good. I run 22 in em when I'm solo and 24 when 2-up w/trailer. As others have stated, force balance is the way to go. I used dyna-beads and originally had a balance issue when I first mounted em. I broke back em down and moved from the yellow dot to the red dot mark at the valve stem, then added another 1/2 oz of beads. All was good from there on out. A force balance would have easily handled that and saved me time and work.
  10. Roadsmith banner
  11. #9
    Ortonville, MI, USA
    Default Cooper tires
    I just put new tires on my RoadSmith, and went to Cooper tires, balanced were purchased.
  12. #10
    Sep 2012
    Lakeland, FL
    Good to know you can to a regular tire store, buy the tires and get it done.
  1. Roadsmith HTS or CSC Viper?
    By parfam_al in forum Honda Trikes
    Last Post: 11-21-2017, 07:47 PM
  2. Motor trike razor or Roadsmith HTS
    By toothfairy1948 in forum Honda Trikes
    Last Post: 04-04-2017, 02:50 PM
  3. SOLD - 2008 Level3 / 2015 HTS RoadSmith Trike
    By Haste Maker in forum Honda Trikes
    Last Post: 11-23-2016, 06:26 PM
  4. Roadsmith HTS Battery Removal
    By jayhawkokie in forum Honda Trikes
    Last Post: 10-27-2014, 05:17 PM
  5. Roadsmith HTS Suspension Settings
    Last Post: 08-23-2014, 08:18 AM
