Likes Likes:  5
Results 1 to 20 of 20
Thread: How long is your dipstick
    30+ Posts
    Aug 2016
    Fort Mill, South Carolina, United States
    Default How long is your dipstick
    Made you look! LOL I need to know the length of a stock type 1 dipstick tube from the block to the end where the stick goes in.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Robert, no answer for you but this thread could go downhill fast!!!
    I could send you pictures, But i'm unable to since the FBI has confiscated my camera equipment.............
    30+ Posts
    Aug 2016
    I knew this could get out of hand but it looks like someone may have trimmed some off the dipstick tube in my motor. I noticed a jagged edge at the opening this after noon. If this is the case it may explain my oil issues.
    Meme Master
    Jan 2014
    Farmington, NH USA
    So you're looking for how much of the tube sticks up out of the block, Robert?
    Odd that someone cut has it. Not sure why that would be done???
    30+ Posts
    Aug 2016
    Yes I am. I do not know why it would be cut but is does not look like the top of any dipstick I have seen.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Not in the shop right now, so I'll get back tomorrow.
    Maybe another member can pipe in sooner with the answer, (pun intended)...
    Probably an any port in a storm dipstick , And the previous owner just cut it back to make it fit/plug on the tube....
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Stone stock 68 beetle 38mm
    450+ Posts
    Mar 2018
    Fernley
    A odd question, but a worthy one. I ran across an article about aftermarket dip sticks and how accurate they may not be.
    I have this chromed one, it is impossible to see fresh oil on it, but it is what the engine has on it.
    I guess one might have cut on it, but they dipstick head can cause a lot of abuse when sliding it down, some like to push and cram it down. This type of abuse can damage it for sure.
    Hope you can get this issue resolved.
    Sep 2016
    Springfield, Mass. USA
    What kind of motorcycle are you talking about?????????
    I can tell you the length on a Goldwing, BUT not Harley
    Ronnie.......Its a VW........
    Meme Master
    Jan 2014
    Farmington, NH USA
    On my 1973 Type 1 engine, with dipstick removed, the tube sticks up 1-1/2" from the deck of the block. (+ or - a mm or 2)
    I'm running with an aftermarket dipstick & when placed next to the tube on the deck flat where the tube comes up from, the tube height measures a little bit lower than halfway between the high/low marks on the stick.
    Hope that helps...
    Apr 2015
    Batesville, AR. 72501
    Here's what I've got. generic Type 1 mutt engine.
    30+ Posts
    Aug 2016
    looking at it my dipstick is the proper length and I think I have the proper amount of oil. When I start my motor cold or hot I have 20 lbs of oil pressure at idle however when I am driving and come to a stop it goes to 0 and light comes on. I am going to check the oil pressure valves tomorrow.
    400+ Posts
    Feb 2015
    Sussex nj usa
    20 lbs hot idle is more than most. I'd be lucky to see 5 lbs hot idle. When you look at the back of the gauge does it have a tiny hole for the oil. They usually have a restriction just so it won't do what you describe. My first thought is throw the gauge away. If the pickup tubes correct you may be trying to fix something thats not broke. What was the problem that made you install a gauge in the first place.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    It is odd.
    I jostle mine around pretty hard and no problems.
    A baja bounces around a good bit.
    I am fairly certain that some thing like autocross would do it. Sticky tires and as much G as you can pull for extended time....not just a jostle about.
    There is usually something going on with the pick up tube that causes this in not extreme situations.
    Sep 2016
    Oppppp's I'm bad............. thank you!
  19. #19
    Remember 'Ronnie people that don't make mistakes 'Are people who do nothing 😜📞
  20. #20
    80+ Posts Gator Monroe's Avatar
    Aug 2017
    Oak Run Ca. USA
    One of the first little chrome bits I got was an aftermarket ( Empi ) chrome dipstick ( Along with a chrome oilcap ) at Wolfgang international .
  1. Oil level reads high on LCD Dipstick
    By DaveHigdon in forum Harley Tri Glide
    Last Post: 10-22-2014, 02:58 PM
  2. reading dipstick
    By rchinjohnson in forum Harley Trike Conversions
    Last Post: 06-25-2013, 09:34 PM
  3. What a Dipstick. Fact or Fiction
    By Mr.Wizard in forum Harley Trike Conversions
    Last Post: 02-19-2013, 10:04 AM
  4. dipstick level
    By geraldlanc in forum Honda Trikes
    Last Post: 04-06-2012, 08:04 PM
  5. Oil temp dipstick.
    By sage city harley in forum Accessories
    Last Post: 08-15-2010, 04:50 PM
