Likes Likes:  7
Results 1 to 20 of 28
Thread: Avon Cobra Trike Front Tire Pressure
    Mar 2011
    mountain home,ar. USA
    Default Avon Cobra Trike Front Tire Pressure
    What pressure are you guys using in your Avon Cobra Trike front tires?
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    I run 40 - 41 per Avon's recommendations...
    http://www.avonmoto.com/tech/
    250+ Posts 2Paps's Avatar
    Jan 2016
    W FL Panhandle
    ol' school has the right info. 41# here too. Same on the brides GW.
    Tryke Flyer!
    2010 GW 1800 with 2010 CSC Cobra kit
    2010 Kawasaki Voyager ABS with 2016 CSC Kruze Kit - Gone but definitely not forgotten.
    Moonshine Mike
    Oct 2015
    st. albans
    41# here to.
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Just had mine put on 2 days ago, set on 40# right now, I only have 100 miles on it and so far I'm a happy camper.
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    I run 38 cold. I end up at 42 to 43 psi at operating temps.
    The 38 psi cold works best with the Traxxion Dynamics front suspension for either highway riding or mountain twisties. Tire wear is normal at this psi.
    Mar 2011
    Quote Originally Posted by David357 View Post
    I also have the Traxxion AK-20 cartridges and Traxxion springs. At 41 psi the sharp bumps are rough so I've thought about dropping the pressure to 38 psi. I may give it a try.
    Thanks for the info.
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Quote Originally Posted by mhgoldwing View Post
    If you have the Traxxion adjustable fork caps, you may want to experiment a little with those settings for your riding style and loads. I finally settled on an a cap screw adjustment of about 1.75 turns counterclockwise from full closure.
    I know you will notice a difference. Experimenting with the settings and riding on different terrains is the key.
    Enjoy.
    Mar 2011
    Enjoy.
    I don't have the adjustable caps. Other than the sharp, shallow bumps my Traxxion front end handles the road extremely well. Just thought the tire is not absorbing those sharp bumps the forks can't respond to.
    BTW, how does a guy from Florida know about twisties?
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Good question.
    The trike is pushed hard through mountainous terrain in both North Carolina and Tennessee for a couple of months each summer. The suspension systems,with properly inflated tires, pass the test.
    You will eventually find that "sweet spot" tire pressure that gives a smoother front end ride and fantastic steering control.
    Ride Safe
    Sep 2012
    Lakeland, FL
    I run 41 cold, most always two up. Do you ride two up and 38 cold? I thought many times abut giving it a try but concerned about the wear.
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    I ride 90% of the time solo. When I do ride two up, I will increase front tire pressure to 39 psi.
    Keep in mind, I do not have a stock front fork suspension system. I have the CSC rake kit and the Traxxion AK-20 front fork suspension systems that function best at about 37 to 39 psi. The front end ride will become harsh if front cold tire pressures are above that range.
    If you have a stock fork front suspension system, then you should probably stick with the recommended 41 psi cold pressures.
    Tire wear is even and consistent without scalloping.
    3250+ Posts Hot Rod 1's Avatar
    Jun 2012
    Saratoga County, New York
    I have a Roadsmith with a rake kit and stock forks. I am on my second Avon Trike Tire. I have always run mine at 41 psi cold. The first tire was replaced with a little over 15k on it. The tire wore evenly with no cupping.
    Update :
    I put new rear tires on the Trike this morning and we found a bulge in my front tire. I have an appointment with the dealer tomorrow get another tire. They told me it would take up to 5 weeks to process a warranty claim with Avon. 😡
    Jun 2012
    Here’s an update on my Avon Trike Tire . My second tire failed with only about 4K miles on it . The tire had 3 bubbles and a small slit in the sidewall. My dealer told me Avon would warranty the tire but might take up to 6 weeks to get reimbursed. My dealer told me it was just a bad tire. I’m curious, has anyone else had an issue with that tire ? I did choose to replace it with another Avon Trike Tire & will continue running it ai 41psi.
    Mar 2011
    Quote Originally Posted by Hot Rod 1 View Post
    I'm either number 3 or 4 and have not had any problem. Several of friends are also running the Avon Cobra Trike and have not reported any problems.
    Just on the wild chance, have you compared your pressure gauge with another person's gauge. Might want to do that just to insure you're not overinflating it.
    Mar 2011
    Dropped mine to 39 psi and did 200 mile club ride yesterday. Difference was night and day! Will continue with 39 psi.
    Sep 2012
    Lakeland, FL
    I'm curious too, dropping mine from 41 to 39 for a while, then to 38, see how that feels. Hard for me realize how dropping the pressure 2 or 3 lbs would make a difference, but I'm gonna give it a shot.
    250+ Posts rhino65's Avatar
    Aug 2016
    Atwood, Illinois United States
    Got a little over 12,000 miles with my Cobra and that was running 38-39 cold. Only about 1600 miles of that was in twisties
    2002 GL1800 with CSC trike kit
  19. #19
    Jun 2012
    This was my second Avon Trike Tire. I got just over 15k with the first one. I ran it with 41psi cold. The tire wore evenly with no issues. I used Michelin Pilot Activ On My 1500 Trike. I probably got better mileage but the tires were noisy and cupped. As far as my tire gauge, I had an issue with a gauge I used up until 3 years ago. It read about 3 pounds high when comparing it to two other friends gauges. I then went out and bought two new gauges , one digital and the other is a dial gauge. Both read the same.
  20. #20
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    I am glad to hear that you noticed a "night and day" difference with 39psi.
    As you are now experiencing, the Traxxion AK-20 front suspension systems respond much better at that tire pressure.
    Enjoy!!
  1. Update Avon Cobra Trike tire
    By Hocky in forum Honda Trikes
    Last Post: 12-03-2016, 11:44 AM
  2. First impression of new Avon Cobra Trike front tire
    By mhgoldwing in forum Honda Trikes
    Last Post: 08-19-2016, 06:31 AM
  3. Avon Cobra Trike tire update
    Last Post: 01-21-2016, 08:46 PM
  4. Avon cobra front tire.
    By felixpirozzi in forum Honda Trikes
    Last Post: 09-12-2015, 11:27 AM
  5. Avon Cobra Trike front tire #2
    Last Post: 12-04-2014, 08:02 AM
