Likes Likes:  7
Page 2 of 2 FirstFirst 1 2
Results 21 to 28 of 28
Thread: Avon Cobra Trike Front Tire Pressure
  1. #21
    150+ Posts jredman's Avatar
    Jan 2014
    Leander, Texas, USA
    Quote Originally Posted by rhino65 View Post
    Got a little over 12,000 miles with my Cobra and that was running 38-39 cold. Only about 1600 miles of that was in twisties
    I am at 17,500 right now and just ordered a new one. Down to the wear bars. I think I got about 20K on my first one. Not sure why this one did not get as many. I run 40 lbs cold. Will give 38 lbs cold a shot. Probably there anyway.
    Jim's Motor Trike (YouTube)
    http://www.youtube.com/c/JimMotorTrikeRazor
  2. #22
    Apr 2010
    Shenandoah Valley of Virginia
    I run 41 lbs cold usually, but 38-39 seems reasonable enough.
  3. #23
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    38psi with summer air that expands 2 lbs more than winter air.
  4. #24
    250+ Posts 2Paps's Avatar
    Jan 2016
    W FL Panhandle
    Quote Originally Posted by mhgoldwing View Post
    I also have the Traxxion AK-20 cartridges and Traxxion springs. At 41 psi the sharp bumps are rough so I've thought about dropping the pressure to 38 psi. I may give it a try.
    Thanks for the info.
    Is there a way to tell if Traxxion cartridges and springs have been installed without disassembly? We bought my bride's 2010 GW w/ CSC kit last year. It was on consignment and we got very little info from the previous owner. Thanks.
    Tryke Flyer!
    2010 GW 1800 with 2010 CSC Cobra kit
    2010 Kawasaki Voyager ABS with 2016 CSC Kruze Kit - Gone but definitely not forgotten.
  5. #25
    250+ Posts
    Jan 2012
    oz
    what's a good pressure with the Honda springs? I'm at 36 psi and it still feel like the forks are to hard/stiff
  6. #26
    Jan 2017
    Montoursville,PA.USA
    Default Avon Trike Tire
    I just had to replace my Avon Trike Tire with 6000 miles on it because of bubbles on the side of the tread.Went with another Avon Trike Tire,hope i am able to get better mileage out of the this one.
  7. #27
    250+ Posts
    Jan 2012
    oz
    Did Avon replace it for you?
  8. #28
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Quote Originally Posted by tourman View Post
    You may want to investigate your ADV valve then on left fork. It's possible that it could be stuck in the active position and that would explain a harsh stiff feeling.
  1. Update Avon Cobra Trike tire
    By Hocky in forum Honda Trikes
    Last Post: 12-03-2016, 11:44 AM
  2. First impression of new Avon Cobra Trike front tire
    By mhgoldwing in forum Honda Trikes
    Last Post: 08-19-2016, 06:31 AM
  3. Avon Cobra Trike tire update
    Last Post: 01-21-2016, 08:46 PM
  4. Avon cobra front tire.
    By felixpirozzi in forum Honda Trikes
    Last Post: 09-12-2015, 11:27 AM
  5. Avon Cobra Trike front tire #2
    Last Post: 12-04-2014, 08:02 AM
