Likes Likes:  4
Results 1 to 7 of 7
Thread: Wise me up... Light's
    May 2018
    spottsville, ky, usa
    Default Wise me up... Light's
    1998 GL1500 with RoadSmith trike kit... The lower (fog/running) lights are constantly on...High beam or low beam, doesn't mater, always on....Seems unnecessary alternator drain having 3 lights burning constantly. Am I missing something?? Is there no provision to have on/off only when needed???
    I got my first trike when I was 3 years old, and now at 83 I back on a trike again. Just got it 2 days ago and will no doubt, need some future advice.
  2. Roadsmith banner
  3. #2
    Quote Originally Posted by KyLobo View Post
    I don't think it'll hurt any, Besides some people pay extra for that feature..
  4. #3
    Mar 2011
    mountain home,ar. USA
    There's probably a switch some where to turn them off. However, several guys in our club leave their on full time because it gives the trike a unique light signature that catches people's attention. When I'm leading a ride I can spot those guys with the fog lights very quickly.
    If it were mine I would leave them on.
  5. #4
    4750+ Posts
    Mar 2015
    Texas
    Don't have a trike but do have fog lights or passing lights or flood lights, heard them called all three, but I leave mine on even though there is a switch to turn them on/off. I get fewer people pulling out in front of me. I've tested it several times before deciding they really do help in that regard. The heck with the electrical drain. If working correctly they are not a problem. Bad battery or voltage regulator or stator if they do cause an issue. So those items would need fixed anyway.
    American Legion Rider
  6. #5
    Sep 2016
    Springfield, Mass. USA
    I ride with my HIGH BEAMS on all the time (day time only) and my bottom lights on all the time also....Never any battery problems... and wear a very HI Viz jacket and helmet... The more on coming cars see me the better........
    3250+ Posts Hot Rod 1's Avatar
    Jun 2012
    Saratoga County, New York
    I think those lights are on all the time. I had a 2000 SE with a CSC conversion . My lights were on on all the time unlike the GL1800 which has a switch. My 1989 GL1500 has the lower lights but they are cornering lights that only come on when using the turn signals.
    10+ Posts Wind Therapy's Avatar
    Jul 2018
    Fredericksburg, VA, USA
    Default Install a Comp-u-Fire Alternator and never worry about electrical drain again!
    1998 GL1500 with RoadSmith trike kit... The lower (fog/running) lights are constantly on...High beam or low beam, doesn't mater, always on....Seems unnecessary alternator drain having 3 lights burning constantly. Am I missing something?? Is there no provision to have on/off only when needed??? I got my first trike when I was 3 years old, and now at 83 I back on a trike again. Just got it 2 days ago and will no doubt, need some future advice.
    KyLobo;
    If you are truly worried about the electrical drain, have a Comp-u-Fire Alternator installed on your GL-1500, and you can run whatever your wiring can handle. I put one on my '88 GL1500 and put 185,000 on her. Changed brushes just twice. Then swapped it onto an '89 GL1500, and proceeded to put another 135,000 miles and 2 more brush changes on it. I ran high beams, fog lights and aftermarket driving lights, plus rings o' fire up front, and saddlebag, trunk, spoiler, hyper lights and mud flap lights in the rear.
    In case anyone is wondering why . . . I ride 120 mile round trip every day, tear 'round between Fredericksburg, VA and Washington, DC on the infamous I-95, where you MUST be seen!
    Ride SMART . . . Ride SAFE . . . but RIDE !
    Dave Calahan
  1. A Word To The Wise
    By FRR in forum General Discussion
    Last Post: 09-26-2017, 04:19 PM
  2. Replies: 14
    Last Post: 02-25-2017, 07:23 AM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
