Likes Likes:  2
Results 1 to 15 of 15
Thread: Blown Fork Seals - Anti-Dive Mechanisum
    50+ Posts
    Apr 2018
    Calgary, Alberta
    Default Blown Fork Seals - Anti-Dive Mechanisum
    I am just about ready to change out a blown fork seal on the right side.
    In reading what I have been able to find, it appears that the anti dive mechanism that is mounted on the left side of the slider has been an issue and was wondering if there is a fix. I have read somewhere that by putting a spacer in between the bottom housing and the top plunger can sort this out.
    Came across this link as a possible fiX! https://www.ebay.com/itm/GL1800-GOLD...item41acc02415
    Then again, I have read that one shouldn't put a spacer in place..
    Any comments?
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    Quote Originally Posted by B25bsaboy View Post
    Any comments?
    Honda's poor front suspension design has caused plenty of grief since day one. I have heard of guys putting a slug inside the anti-dive actuator and also the spacer you show. I did try that one but it didn't seem to totally kill the action. When I converted my 2015 with the Roadsmith HTS1800 kit part of that process was to install a short strap to defeat the anti-dive. It seems to work so you might want to investigate that direction.
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
    3250+ Posts bikerbillone's Avatar
    Sep 2012
    Lakeland, FL
    Ditto what Jerry GoldRush said. I was plagued with blown fork seal untils I did the 'fix'. No problem since and that's been a couple years, I guess it works.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I got so tired of trying to correct my front suspension on my current Wing I gave up and had a Traxxion installed. Big improvement.
    50+ Posts
    Apr 2018
    Calgary, Alberta
    Quote Originally Posted by bikerbillone View Post
    And what was the fix?
  6. #6
    May 2011
    San Angelo
    I am no engineer so will not tell anyone it is OK to modify their brakes the way Roadsmith HTS1800 kit instructions told me to when I converted my '15 GL1800 in December 2015. They have changed how that portion is done so I expect there may be other changes as well. Give Roadsmith tech guys a call at 1-800-331-0705 and ask the questions.
  7. #7
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    There is a spacer for sale that will keep the antidive plunger from working. HOWEVER, it is recommended that you change to stronger springs so the front end doesn't dive excessively in hard braking.
    A good mechanic can service both forks with new bushings and seals, install new springs. That is the cheapest way to improve the front end. Personally, I would use linear springs and not progressively wound springs.
    I have the Traxxion AK-20 cartridges, Traxxion 1.1 springs (heavy load), and Traxxion fork brace. It's expensive but if you're going to keep the trike a long time it is worth it to me.
    Wing with Roadsmith kit, Traxxion Ak20 cartridges and Accuride System.
    07 ST 1300 for two-wheeled fun!
  8. #8
    Sep 2012
    Lakeland, FL
    For me it was the spacer, and that was before I had the Road Smith conversion done.
  9. #9
    150+ Posts Rowdy's Avatar
    Dec 2008
    Western Kentucky
    I made a spacer out of pvc pipe and bought a couple longer bolts. I rode my 1800 DFT many miles with the spacer and stock springs with no problems. Some people use a nickel with a hole drilled in it for the spacer
  10. #10
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by Rowdy View Post
    So .... what would be the currency difference between a nickel in the US and the Canadian equivalent ?
    Jim Murphy
    Iron Butt Rider 2001
  11. #11
    50+ Posts
    Apr 2018
    Calgary, Alberta
    Quote Originally Posted by Lee H. Mann View Post
    That’s Easy. US Nicole is worth 5 cents, while the Canadian nickel is worth 3.5cents. This may sound funny, but the Canadian Nicole is 99.9% Nicole while the US nickel is nickel and copper.
  12. #12
    200+ Posts lgjhn's Avatar
    Jun 2013
    SW Louisiana
    I also totally agree with Gold Rush.
    I've also used the drilled hole in the nickel trick, but apparently,, it wasn't t soon enough and I ended up with a small leak. Early in the year, I went ahead and pulled both forks down and completely rebuilt them with all new parts; sliders, seals, fluid, etc. Per Zook's suggestion, I used a brand new pair of stock GW springs rather than Progressives. The ride quality is amazing compared to what it was. And Zook was right: for a trike application, the stock springs work better than progressives. Thanks, Randy.
  13. #13
    Sep 2012
    Lakeland, FL
    lgjhn, your comment, yes, that was my experience as well, except I had the Traction stiff springs, they were way too stiff and high sprung. My friend and I tore it all down to ensure we had done the proper install, everything was as the instructions called for. Traction is a very good product I'm sure, just didn't work for me, so I installed new Honda OEM springs. That was 5 years ago, no problems with the OEM springs and spacer.
  14. #14
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by lgjhn View Post
    IMHO, fresh OEM springs are better than most after market, for 2 wheelers and trikes!!!!
    Also, IMO, servicing the ADV, to insure it works properly, is better than disabling it. It's there for a reason.
    Do you mean Traxxion????
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  15. #15
    Sep 2012
    Lakeland, FL
    Whoops, yes, Traxxion.
  1. Fork Seals
    By FRR in forum Honda Trikes
    Last Post: 05-26-2013, 09:31 PM
  2. Fork seals 2010/1800gw
    By JACK RANDALL (SHORTY) in forum Honda Trikes
    Last Post: 01-06-2013, 07:32 PM
  3. How to disable Anti Dive on 97 1500
    By xfireman in forum Honda Trikes
    Last Post: 12-01-2011, 04:54 PM
  4. Harsh ride, leaking seals & anti-dive
    By Muleskinner in forum Honda Trikes
    Last Post: 11-01-2011, 11:24 PM
  5. frt fork seals
    By glennbo59 in forum General Discussion
    Last Post: 04-17-2011, 05:41 AM
