Results 1 to 8 of 8
Thread: 2013 Stallion won’t start and starter is good
    Apr 2016
    Akron,OH,Summit
    Default 2013 Stallion won’t start and starter is good
    I think I might have a corroded wire between the fuse box and the starter. Does anyone know what color wire this might be so I can trace it down.
    Already put a new battery in.
    Quote Originally Posted by Rocky330down View Post
    More info might be needed....IE; Starter cranks but engine wont start, Or you just hear a clicking sound, Or you turn the key and nothing happens at all..ECT...
    Apr 2016
    Akron,OH,Summit
    Just hear a clicking sound when key is turned.
    Manually jumped the starter and it is good.
    Checked all the relays and they appear to be good.
    Im confused....If you jumped the starter then the engine should have started, How or what did you use to jump the starter..Because usually when you turn the key on and all you hear is clicking it means that the battery bad..But you say you have a new battery...Then again sometimes even new battery's go bad...
    250+ Posts Dean H's Avatar
    Oct 2010
    Tampa, FL
    Did you possibly leave something on when you parked it . . . that could drain the battery. (Yup, I have)
    Dean - 480.734.7161
    Tampa, FL
    dean.hauser3@gmail.com
    '09 Stallion #643
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    If it cranks but won't start, first try to push the red button under the seat as it may have tripped and shut off your fuel supply.
    Tomg
    Check battery voltage @ the starter
    Make sure your battery is full charged @ 12.7 volts
    If your seeing less than that @ the starter you will need to figure out where the drop is
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Be sure to check the voltage @ the solenoid wire when you turn the key. If the ignition isn't providing proper voltage to that wire the issue will be somewhere in the wiring or ignition switch. Jumping the starter only provides power to the solenoid forcing the starter to engage, it's a good test for the starter itself, but doesn't do much for checking everything else.
    If you don't have it, I would suggest getting the Ford Ranger (08-10) wiring diagrams service manual at a minimum. If you need to dig into the wiring side of things it'll be worth every penny to have a copy of it.
  1. Starter won't stop running
    By NC Triker in forum Honda Trikes
    Last Post: 01-22-2017, 02:37 PM
  2. Trike won't start
    By rwhgme in forum Harley Trike Conversions
    Last Post: 11-05-2012, 02:53 PM
  3. Trike Won't Start??
    By BinIdaho in forum Harley Tri Glide
    Last Post: 09-08-2012, 11:17 AM
  4. Trike won't start
    By clo in forum Honda Trikes
    Last Post: 08-14-2012, 08:25 PM
  5. Won't start?
    By Big Dog in forum Stallion Trikes
    Last Post: 10-05-2009, 07:48 PM
