Likes Likes:  17
Results 1 to 16 of 16
Thread: charging Air conditioner
    Jul 2014
    Tyler, Texas
    Default charging Air conditioner
    On a recent Texas Hill Country ride I had to replace the bearing on my wife's 2013 Stallion's air conditioner. Removing the air conditioner I had to release the freon. After assembly of the bearing and air conditioner itself we made it home. Now I need to recharge with freon. Where is the refill valve and how do I go about the recharge.
    Welcome to Trike-Talk....Mr 46.....
    300+ Posts
    Signal Mountain Tn
    Quote Originally Posted by Jeep46 View Post
    Welcome to Trike Talk. You will need to put the Stallion on some ramps or a rack to access the service ports. They are located underneath inboard of the right wheel. Just service it the same as you would a car ac. Since you opened the system, you will need to pull a vacuum on the system. Hope this helps. Good luck!!
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Hey there Jeep46! Welcome to TrikeTalk from west Texas!
    We’re having a TrikeTalk meet and greet at Kerrville the first week in October. Hopefully you two will be able to attend. No registration fees, no prizes, just meet, ride, eat, and kick tires! We have a lot of fun.
    Jul 2014
    Tyler, Texas
    Greatly appreciated to both replies. I have to admit looking underneath inboard of the rear wheel was one of the last places I would look. Thank you.
    I appreciate the Welcome
    Jul 2014
    Tyler, Texas
    Quote Originally Posted by paws View Post
    Hey Paws thanks for the invite but the first of September we will take off for the Florida Keys via Upper Michigan only to return to east Texas early November. Please do keep me informed of next years meet or sooner if scheduled. Drive safe and enjoy the Twisted Sisters!!
    The vacuum is important for 3 reasons
    1 Removes moisture
    2 Removes debris
    3 If it does not hold a steady vacuum you will have a leak in the system
    Good Luck
    Jul 2014
    Tyler, Texas
    1 Removes moisture
    2 Removes debris
    Good Luck
    Thank you very much Mr Jack; I'll give it a try.
    Jul 2014
    Tyler, Texas
    A follow up question: is both the high side port valve and low side port valve located in the same general area. The Stallion is at home and I'm in Galveston so I'm struggling with a mental picture until I get home Thursday.
    I am not familiar with the Stallion trike AC plumbing
    I would guess it is not the same as any Ford car or truck I have seen
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Yes, both ports are almost next to each other. As previously mentioned, be sure to pull a good vacuum on the system prior to filling. I'm afraid I can't give the amount of oil used in the system (a/c compressors are pre-filled with oil from Ford), but the 134 capacity is 1.3 lbs.
    Quote Originally Posted by trike tech View Post
    If you cannot measure what you pull out during vacuum, 2-3 ounces should do it for oil
    Official Mascot Trail Blazer's Avatar
    Nov 2012
    huntington , texas
    +1`
    Jul 2014
    Tyler, Texas
    Good morning
    Thank you very much, I now have the beast in front of me and ready to go to work.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Whatever happened to just going to a local a/c auto repair shop and after they pull the vacuum, they put in the refrigerant needed according to their gauges? If you don't have the proper equipment and expertise, take it to someone who does! Just my thoughts. Tomg
    Jul 2014
    Tyler, Texas
    Quote Originally Posted by tomg View Post
    Thanks for the slap upside my head, seems like a great idea
  1. Battery charging prob.
    By lboos in forum Harley Tri Glide
    Last Post: 12-17-2014, 06:00 PM
  2. up date on battery charging prob.
    Last Post: 11-08-2014, 06:45 PM
  3. Batt. charging prob. update
    Last Post: 10-27-2014, 12:59 PM
  4. Roadhawk Charging Problem ?
    By 2blackbelts in forum VW Powered Trikes
    Last Post: 05-09-2012, 11:14 PM
  5. my t/g battery charging fix
    By eagle1 in forum Harley Tri Glide
    Last Post: 03-07-2012, 11:52 AM
