Results 1 to 3 of 3
Thread: Missing Two Wheels
    60+ Posts
    Jun 2016
    Windham, NH
    Default Missing Two Wheels
    I had my '04 Gold wing converted to a Motor trike IRS nearly 2 years ago. While I mostly feel safe on the trike, I do miss the two wheels. As I aged I have become more vertically challenged.(shrinkage!) I sometimes think I should have purchased and installed the Low-Wing bracket (www.lowerwingproducts.com) before converting. Does anybody have experience/thoughts with this product? I will appreciate your inputs.
    Don - New Hampshire
    2004 Gold Wing 2016 Motor Trike Razor
    Apr 2010
    Shenandoah Valley of Virginia
    Not sure what you want. You have converted your bike to a trike with IRS... but that bracket is for lowering a stock GoldWing, your trike likely doesn't even use OEM rear spring now. What you think you maybe passed up as an option 2 years ago is kind of mute now.
    On a trike, you don't use feet to hold it up anyway. I rarely ever drop feet to ground when on the trike, but I do on the '85 GL1200 bike I kept.
    60+ Posts
    Jun 2016
    Windham, NH
    Thank you for your consideration to my question. I guess my post wasn't clear. You are correct that this would be for a stock Gold Wing, not a trike Gold Wing. I would consider purchasing another GW (2 wheels) if the lowering bracket is a safe modification.
    Don - New Hampshire
  1. Advantage of Three Wheels Over Two Wheels
    By mgwtrike in forum Honda Trikes
    Last Post: 01-03-2020, 01:32 PM
  2. Back On Two Wheels
    By Hot Rod 1 in forum General Discussion
    Last Post: 05-21-2014, 10:15 AM
  3. Two wheels to three suggestions
    By Chief1 in forum New Member Introductions
    Last Post: 01-08-2014, 09:04 PM
  4. Looking for comparison of two front vs two rear wheel trikes
    By Big_Blue in forum General Discussion
    Last Post: 07-21-2013, 03:01 PM
  5. Rode on two wheels this weekend...
    By denviola in forum General Discussion
    Last Post: 09-09-2010, 08:01 AM
