Likes Likes:  8
Results 1 to 18 of 18
Thread: Extend a trailer
    1000+ Posts dannymax's Avatar
    Jan 2018
    Upper Hudson Valley, NY
    Default Extend a trailer
    Was thinking of a new 6' x 10' utility trailer to haul my Freewheeler but thought I'd have a go at this....seems like it should work just fine.
    Sorry, no photo!
    2017 Freewheeler
    Billet Silver
    Compassion for animals is intimately connected with goodness of character....and it
    may be confidently asserted that he who is cruel to animals,cannot be a good man.
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Work for me
    900+ Posts
    Apr 2011
    Bellville, Texas, USA
    So what is it?
    Sunman
    Jan 2018
    I used a standard 5' x 8' Carry On Tractor Supply utility trailer....the Freewheeler will fit width wise but overhangs in the rear about 10". Tipping the loading ramp/tailgate back about 45deg. will allow enough room and a couple pieces of 1/4" x 3' x 4' strap steel bolted to the side rails and upper corners of the ramp will keep it solidly in place. Some ratchet straps on all 4 corners and you have a light, fairly inexpensive way to transport your Freewheeler.
    I'm sure my description sux....will try pic again.....
    You can copy/paste the following in your browser....best I can do.
    [IMG]file:///C:/Users/Dan%20Unwin/Desktop/IMG_2125.JPG[/IMG]
    2017 Freewheeler
    Billet Silver
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Quote Originally Posted by dannymax View Post
    Have you actually loaded the trike and tried driving at highway speeds yet?
    Just curious if it had any sway to it. We had a trailer that was just a little too short for the trike and could not get over about 40mph without experiencing severe sway. It was a very frightening experience. Had to take it home, unload, and drive the trike to Kerrville. Then found the Aluma TK1, almost brand-new, and no more problems with trailer sway. Be careful and good luck with it.
  6. #6
    Jan 2018
    Quote Originally Posted by paws View Post
    No, I haven't had it out on the road yet, it seems to have adequate tongue weight to prevent sway but as you say, proof is out on the highway. I'm towing with a 5500# Toyota Tundra....what was your tow vehicle?
    2017 Freewheeler
    Billet Silver
  7. #7
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    We were driving a Ford Escape. It was rated to tow the weight of the trike and trailer ok but the weight hanging on the very back-end of the trailer was the problem. The same vehicle pulled the Aluma TK1 with the same trike without any problem whatsoever.
  8. #8
    Dec 2014
    Grand Junction, Co. USA
    You could probably move the axel back some to get a better distribution. Might mean grinding and welding. The trailer I use to haul bikes, trikes etc, is an old boat trailer that you can move the axel forward or back. Gettin about 2/3 of the weight in front made it handle much better.
    Name:  2015-03-13 14.22.34.jpg
    You might be able to see the adjustment u bolts
  9. #9
    Jan 2018
    That's a nice set up you have. I like the sliding axle! It's basically what I have with a little smaller trailer. I totally agree on the weight distribution....my axle is 60" from the front of the bed to axle center on a 96" trailer which puts the majority of the Freewheeler weight forward of the axle. I'm expecting it will draw fine, if not I'll weld a tool box to the tongue and fill it full of rocks!
    2017 Freewheeler
    Billet Silver
  10. #10
    Dec 2014
    I put my axle right about where the tranny was. most of the engine weight was on the tongue.
    Name:  2015-04-09 12.43.22.jpg
    It pulled really well and when the Trike/Bike was not on it, I can move it fairly easily by just pulling it with my hands. The ramp weight really helped with that.
  11. #11
    Jan 2018
    Nice set up! I'll be getting to the painting phase soon but don't think it'll come out as nice as yours.
    I'm having trouble posting pics, it works once in awhile but mostly not but if you copy/past the link below in your browser you should be able to look at mine....the trannie is maybe just an inch or 2 in front of the axle so I'm thinking tongue weight should be fine. I dragged a cargo trailer behind me for 15 years with all my underground tank testing equipment so got a bit of experience on how to balance these things.
    2017 Freewheeler
    Billet Silver
  12. #12
    Jan 2018
    See if this works? By golly, it did!
    Obviously the Kubota is only a yard bird....not the official OTR tow vehicle.
    2017 Freewheeler
    Billet Silver
  13. #13
    Jan 2018
    One more view. And a good excuse to see if I remember the sequence.....
    The Freewheeler hangs over the end of the trailer about 10"....this modification makes up for that plus a couple more inches for some cushion material between the bike & ramp....just in case.
    Also, the ramp is bolted down with grade 8 socket cap 3/8" bolts making the whole unit much more rigid.
    And 'Stow Mode' with the braces bolted to the trailer side rails.
    2017 Freewheeler
    Billet Silver
  14. #14
    Jan 2018
    A few sheets of aluminum, couple angle braces, some POR-15 paint and we're done.
    2017 Freewheeler
    Billet Silver
  15. #15
    Dec 2014
    Nice Job. Really nice.
    I think next winter I may make my ramp hinge in the middle, so it is not like pulling a billboard. Even with the expanded metal, you can "feel" the drag when pulling it.
  16. #16
    Jan 2018
    Thanx! Fer sure those little bars on the tailgate block a bunch of wind, I'm looking at a 20 mile or less haul so not too concerned about it.
    2017 Freewheeler
    Billet Silver
  17. #17
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Its not so much the wind, its the weight if the ramp hanging off the rear end...''Leverage''..
    I have a 10 by 6 1/2 Aluma...And when i trailer when empty i fold the ramp flat into the bed, The weight of the ramp sitting at the very end will lighten up the tongue weight...
    And its very noticeable at highway speeds..
    2019 Tri-Glide.......
  18. #18
    Jan 2018
    I bolted down a sheet of 3/4" pressure treated plywood to beef up the bed....maybe the wind coming off the truck creates enough down force on the plywood to counteract the leveraging cuz I've never noticed it.
    2017 Freewheeler
    Billet Silver
  1. Replies: 5
    Last Post: 10-09-2017, 07:14 AM
  2. Need help finding a small trailer front jack for my motorcycle trailer
    By Urlawyer in forum Harley Trike Conversions
    Last Post: 07-23-2014, 07:53 PM
