LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  7
Results 1 to 18 of 18
Thread: Help with ride quality; new triker
    10+ Posts Ron60's Avatar
    May 2018
    Byron,Georgia,USA
    Default Help with ride quality; new triker
    I just got a 2005 H.D. softail deluxe with Lehman Renegade kit(17k miles). I've been told there's no way to improve ride quality as I have the wide, wire rims and tires. Anyone have any info on replacement /better shocks for the straight axle,belt drive kit possibly from '05?? I've enjoyed the ride and price of J&P shocks by Progressive on other rides. Had to switch to three wheels due to medical issues and am shocked at how hard it is to get any help from Lehman or Champion.
    Welcome to Trike-Talk.....Ron... I'm sure someone will chime in soon with the help you need...
    Welcome to Trike Talk
    Apr 2010
    Shenandoah Valley of Virginia
    1) Welcome
    2) Many have gone to a trike only to be disappointed with ride. A bike pretty much stays verticle and leaves one track, a car only leaves 2, but a trike leaves THREE. Finally you just try to minimize the jolt as you can't ride between pot holes like on a bike. If you have really big wheels with little tire sidewall, they only make it worse as short tire sidewalls absorb less bump.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Ron, welcome to Trike Talk!
    One of our members on here, Lee H. Mann is the resident Lehman guru on here. If anyone can answer your questions it would be him.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by Ron60 View Post
    What rear tire pressure are you running Ron? Lowering it to the 20-22 lb range helps a lot and changing out the shocks can also help.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    A profile picture is worth a thousand words. As stated above, wide wheels look great but ruin the ride !
    It is presumed that you have adjusted the air pressure in the rear tires and checked the spring setting on the rear shocks and none of these corrected or changed the ride. I have installed Harley-Davidson air shocks on a few Renegade Softails.
    Name:  my trike 29.JPG
    Jim Murphy
    Iron Butt Rider 2001
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Hello Ron, welcome to the forums.
    welcome aboard Ron
    Sep 2016
    Springfield, Mass. USA
    I ride a Goldwing so I can't help you but I do have to say::: Any body with a name of Ron, has to be good guy! Welcome!
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I found it’s a weight thing , solo ridingis a basketball , when 2up it smoothins out quite a bit. Have progressive coil overs w/lift kit. 22psi in rear tires. Don’t want to add 100lb weight in trunk to improve ride.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Hey Ron! Welcome to TrikeTalk from west Texas!
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Welcome aboard, Ron!
    '86 E-Glide with a "vintage" Lehman Tour conversion. I run 15-20 psi in the rear shocks (stock HD's), 25 psi in the rear tires, 36 in the front. She rides like a Cadillac. Keep at it, you'll get it worked out! And as previously stated, Jim is the guy for all things Lehman.
    PEACE and ride safe!
    P.S. I forgot to mention, I'm also running 50 series tires on spokes.
    May 2018
    Byron,Georgia,USA
    Thanks everyone for the "welcomes".Jim, yes I have @ 20 psi in rear tires and have added preload to shocks. The shocks were on lowest setting and I've got up to middle setting in my trials. I plan on trying more but am expriencing a lot of bounce now.The tires are not low-profile and have plenty of side wall. I agree trikes are very sensitive to both tire pressure and shock settings but I feel the shocks were not up to task of the heavy,wide tires when new,especially since they've aged. I'll see if my wife can help with getting a pic on here if it ever stops raining in Ga. I'll check with my bike shop to see if he has any HD take-off air shocks that I can try. Any model of air shock should I look for? Trike,Ultra,etc? I need the rear brakes adjusted and the rear end gets high-speed grease.... any tips on those or they straight forward do-it-yourself things?
    May 2018
    Byron,Georgia,USA
    Default Thanks for replys
    Yes Jim, 20 psi and middle setting; not low profile tires. I'll try to get pic posted. Thanks everyone for welcomes and replies. I'll see what my bike shop has laying around in H.D. take offs, any type prefered? trike,ultra, etc? I'll try adding more pre-load; as I started at lowest. I've read most threads on Lehman trikes and am impressed with Jim's knowledge and kindness. Im getting a lot of bounce now with passenger. I dont think shocks were ever up to job of the big tires...too bad Lehman has not been of any help!
    Martinsburg, WV
    A little over two years ago one of the T/T members had an issue that was similar. It turned out to be one bad shock. Since you have a non-flexible swingarm, it is difficult to determine which shock it actually is. I would continue to increase the pre-load and if this does not improve the ride, it could very well be a bad shock or shocks that are too short (less than 13.25").
    You could replace the pair with another set of coil-overs or get a set of air-rides from a Harley-Davidson Ultra. The H-D part number is 54565-97C (13") and you can find them USED for sale on eBay relatively inexpensive and fully functional. I just checked and there are over 50 listings right now. Try to get a set with lowest mileage, with air lines and fittings and change the fluid before installing.
    Jim Murphy
    May 2018
    Byron,Georgia,USA
    Default Many thanks
    Jim, I think we sorta figured out the pic thing...I really am thankful for advice on shocks, I'll sure use it. thanks
    Click image for larger version.
Name:	rons newbike.jpg
  1. Looking for quality control switches!
    By CaveManDave in forum VW Powered Trikes
    Last Post: 07-26-2016, 07:11 PM
  2. Trike ride quality question on CSC IRS....
    By bamaboy in forum General Discussion
    Last Post: 09-03-2013, 08:38 PM
  3. Charter Arms quality service is back!
    By Jimsjinx in forum The Gun Enthusiast
    Last Post: 11-24-2011, 12:20 AM
  4. champion road star kit quality?
    By allanintexas in forum Miscellaneous
    Last Post: 04-27-2011, 09:17 PM
  5. Ride quality?
    By Carbon_One in forum Stallion Trikes
    Last Post: 06-29-2010, 11:08 PM
