Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  2
Thanks Thanks:  2
Results 1 to 14 of 14
Thread: Front End
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Front End
    Hello, I'm thinking about getting a new front end for my trike. I have an '84 1000 Virago on it now. I don't want to change the neck because that is where my VIN is. I want a wider front end with a bigger tire, about the size of what was on my stock Nomad. Any ideas where to look or recommendations of builders that may be able to build a springer, gurder, or triple tree to fit my neck and get the rake and trail right?
    Thanks for your time.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Almost everything aftermarket is for a Hardley.
    A small small amount for the most popular of metrics.
    There is quite a bit of mix and match that can be done with stock type yokes and hydraulic forks.
    I built mine to go into the Honda bottom yoke.
    I suppose any custom builder could do the same.
    Typically what I see done is a Hardley or other used springer/girder/ect front end with the pivot cut out of it, then the metric one cut from the stock yoke and welded into the aftermarket yoke.
    Basically take most anything and turn it into one for a metric.
    Oct 2014
    Thanks Rex, Any ideas on where to find someone that can do the cut and weld, right?
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    No.
    I do not know of anyone here near us.
    It is incredibly difficult to find anyone that can do anything with their hands anymore.
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Its difficult to find people to do these things because of the liabilty,not because of the lack of talent. At least around here. If you remove the front end so you can measure your bearings, sometimes you can mix and match. I put a honda front end on a harley without any machine work.
    Oct 2014
    Hello, I can understand the liability part when you figure you can sue someone because your stupid or clumsy, ie. spill your coffee and sue a hamburger joint. I wish I had the knowledge and skill to do the measuring and swapping needed to figure it all out, but I do other things pretty well. But if I can find someone within 1000 miles or so I'm willing to travel. It would be a good excuse to do some camping and fishing and I've got lots of free time.
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    allballsracing.com for conversion bearing sets(metric to metric).
    https://www.kiwavmotors.com/en/faq/a...ube-size-chart
    Fork tube size chart. Google Motorcycle fork tube dimensions and Motorcycle front axle sizes for more charts and information.
    I built my front fork with a '83 Honda GL1100 neck, GL1500 raked (EZ Steer) triple tree, '99 Honda CBR900RR tubes and calipers, and a 2003 Harley V-Rod front wheel and disks. I built this entirely with hand tools in my back yard. It is a stout front end with 45mm down tubes and a solid front wheel.
    As an alternate, you can get a Harley springer and find some tapered bearings with the correct ID for the HD stem and OD for your neck races. A trip to the local bearing store with the dimensions will probably fix you up.
    As a Last Resort, you can probably carefully grind the weld on the bottom of your lower triple tree that holds the stem and press the stem out of the lower tree. Do the same thing to the new front end. Then figure what kind of shim/spacer you need to weld your stem into the new front end. Do this carefully and you should be able to find a welding shop that will weld it back together. There still a lot of us old farts out there that can do the job. Do you have any dirt track/drag racers in your area? Might take a little "socializing" to get the job done.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    don't know if this will lead anywhere.....but i am noticing in chopper magazines, people are chopping and customizing sx650 yahama bikes along with harleys....maybe the sx 650 custom forks would fit your headstock?????
    20+ Posts gospicker's Avatar
    Jun 2014
    Azle Tx USA
    Default Front end
    This Winter I am having a shop; do my front end and he is going to cut the upper and lower bearing cups off and weld on Harley cups so I can use any Harley front end,.....springer, wide glide, etc. This way I keep the neck with the numbers.
    Oct 2014
    Hello Bigfoot, I tried to send you a PM, but it said I couldn't do it. So, would you give me the name and number for the shop or a website please? Thanks for your time
    Jun 2014
    Azle Tx USA
    Chop Shop Motorsports
    5750 Texas 76244
    817-271-7576
    Jun 2014
    Azle Tx USA
    Default Front end
    5750 Park Vista Circle #120
    Keller, Texas 76244
    817-271-7576
    Oct 2014
    Thanks, I'm gonna give them a call.
    Jun 2014
    Azle Tx USA
    Default Front end
    Quote Originally Posted by sonny8l3 View Post
    I didn't get it done this winter, but I am taking it in on Tuesday for the job. We have all the parts now and he is going to cut the metric cups off and weld on Harley cups and I am putting on a beautiful wide glide with a 21" wheel. The place is in Fort Worth, Tx and it is called Chop Shop Motorsports. The guy's name is A.J. I will post a pic when it is done.
  1. Trying to decide on whether to rake or not to rake front end
    By Lil Red Hen in forum General Discussion
    Last Post: 02-15-2021, 02:55 PM
  2. Replies: 45
    Last Post: 05-15-2019, 03:41 PM
  3. Photos of your rear end —. Not THAT rear end !!!!!!
    By Snickers1948 in forum Harley Tri Glide
    Last Post: 11-04-2017, 02:07 PM
  4. Traxxion front end...
    By mpolissky in forum Honda Trikes
    Last Post: 04-05-2010, 09:33 PM
  5. Raking the front end
    By spiritdream in forum General Discussion
    Last Post: 10-22-2009, 03:40 PM
