Likes Likes:  18
Results 1 to 16 of 16
Thread: roadsmith rear tire alignment
    20+ Posts
    Mar 2018
    Hinckley
    Default roadsmith rear tire alignment
    I have a friend that has a 2007 gl1800 GW that was tricked back 2014 with a RoadSmith conversion . He is the second owner . when he got the trike back in 2015 the left rear tire was worn out on the inside side of the tire the right tire was in good shape so he replaced the tires with new ones he has 9500 miles on this set and the same thing has happened the left tire has worn down on the inside and the right tire is in good shape with a lot of tread left he is also running 32 PSI in the tires is there any kind of adjustment that can be done
  2. Roadsmith banner
  3. #2
    Mar 2011
    mountain home,ar. USA
    Quote Originally Posted by bluewinger2000 View Post
    Same answer as on the other board.
  4. #3
    This sounds like a camber issue
    I would contact Road smith directly first off
    Like some cars that offer NO adjustment for rear camber, I have made shims to adjust it
    Depending on the rear wheel bearing set up, if they bolt on you can loosen the bolts, slide in a shim and re torque the bolts
    You will first want to use a level on the wheels , get a measurement from each side ( on level ground)
    After you get your measurement you can figure how much of a change you need to make
    Always re check your adjustment and compare your final readings
    I hope this helps
  5. #4
    Sep 2012
    Lakeland, FL
    Quote Originally Posted by mhgoldwing View Post
    Mike, which board, didn't see it on the gl1800riders, and I'm interested in that post.
  6. #5
    Sponsor - Roadsmith Trikes
    TrikeTalk Sponsor
    Roadsmith Trikes's Avatar
    Mar 2008
    MN
    Being that your friend is the second owner of this trike, I can only assume he is not certain of its' history. Meaning, was there any type of accident, impact, pot-hole that the left side experienced that the right side did not? Assuming that is not the case, I would suggest looking for a shock or spring issue on the affected side, or the possibility of a worn wheel bearing. In any case, please have the trike's mechanic call 800-331-0705 and ask for Mike. Between the two of them, they should be able to figure things out. I would not start messing with alignment adjustments quite yet.
    Jim
    20+ Posts
    Mar 2018
    Hinckley
    I talked to RoadSmith today and got some real good info and my friend is going to call them tomorrow and hopefully set something up to get it in and have it looked at . thank you all for your replies.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I think you ought to talk your friend into joining TT . The best answer grape on the planet
    Mar 2011
    the one you didn't see it on.
  10. Roadsmith banner
  11. #9
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quiz: On what trike forum(s) can you get your technical questions answered by not only trike owners, but the manufacturer of the trike kit you own?
    correct answers get greenies
  12. #10
    Sep 2012
    Lakeland, FL
    Great point and well said.
  13. #11
    Right Here @ Trike Talk
  14. #12
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    +1
  15. #13
    Trike-Talk......Of'cause......
  16. Roadsmith banner
  17. #14
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I’ll take a 30 pk of greenies 🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺🍺 (Genesee Cream Ale )
  18. #15
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    The most awesome place on the planet of course.Right here.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  19. #16
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by Roadsmith Trikes View Post
    Jim
    Thank you Jim, for coming on with your answers, (although I really have no wood in this fire) I really like the idea of having the Roadsmith guys coming on and giving us their answers/suggestions....This is why I also own a Roadsmith model trike... Thanks Jim!
  1. Question on rear wheels alignment ...
    By Barry in forum Outrigger Style Trikes
    Last Post: 09-06-2018, 04:17 PM
  2. Rear Wheel alignment
    By bohica in forum VW Powered Trikes
    Last Post: 11-14-2015, 09:13 AM
  3. Tow-Pac Alignment & Darkside Tires
    By sgmdudley in forum Outrigger Style Trikes
    Last Post: 06-22-2014, 06:34 AM
  4. Belt alignment problem w/Frankenstein rear
    By buster in forum Harley Trike Conversions
    Last Post: 08-05-2011, 09:20 AM
  5. Alignment of a sidecar
    By cjmitch in forum Honda Trikes
    Last Post: 09-09-2009, 10:26 PM
