14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  2
Results 1 to 12 of 12
Thread: CB550 Wild, Wobbling and Bouncing all over the place.
    5+ Posts
    Jun 2018
    UK
    Default CB550 Wild, Wobbling and Bouncing all over the place.
    Hey guys, So I bought this trike project to give a go and I've gotten to the test ride state and it's positively awful. In it's life it's been on he road for several years before holding up so i'm hoping it's nothing catastrophic w/ the chassis.
    The build;
    1983 CB550sc Nighthawk bike frame and a reliant rear diff w/ wheels off a mini (I think).
    The problem(s);
    The handling on it is truly terrifying, It's heavy to turn the bars and on corners and the slightest bump/dip in the road has the front end feeling light and the bars wild while the back end bounces all over the place. In it's life it's been on he road for several years before holding up so i'm hoping it's nothing catastrophic w/ the chassis. If you hold the front wheel and try and shake the bars the bike part of the frame will wobble/almost twist where it should be solid.
    Problem solving;
    - I've replaced the headstock bearings and adjusted those so that there's no forward/back movement and the bars move freely either side.
    - I ratchet strapped the back end down (Theoretical hard tail) and that removed all the back end and chassis wobble but the front end steering was still light and a lil wild. So i'm thinking the rear shocks are shot and i'm just looking at what shocks to put in there place.
    - I've replaced the fork seals and oil (10w, 375 ml as per manual) but there's ~2 inches of travel on the forks. I increased the preload by maybe an inch to see if that helped and i think it did slightly, so i'm thinking maybe worn main springs or just knackered forks in general?
    - Have boxed it up w/ chalk and the tracking on the back looks good.
    I'm sure there are things I've forgotten to mention but i think that's most of it. Basically, it handles like a potato and i'm not sure why. Any help would be appreciated Name:  WP_20180227_10_38_07_Pro.jpg
Size:  767.4 KBName:  WP_20180227_10_38_14_Pro.jpg
    Dec 2014
    Grand Junction, Co. USA
    Sounds like shocks and springs would be a good start. Also, you might play around with the rear tire pressure see if lowering it helps. There's almost no weight on the rear.
    Welcome to the Gang from Western Colorado.
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    I'd try the rear tire pressure. From the pic, it looks like the tires are riding pretty high. Most trikes usually have 22~24 lbs in the rear.
    Brother Mike
    5+ Posts
    Jun 2018
    UK
    Wow, quick response.
    I've just lowered the rear tyre pressure to 24 psi (Was set at 40).
    Any suggestions on what shocks to go for? Will any new shocks work? Also, i've got like a wooden frame w/ an army ammo box i'm working on to go on the back and cover the diff and give me a bit of a boot, that should add some weight to the back end.
    Thanks guys.
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by Freak_Hybrid View Post
    Thanks guys.
    After viewing the pix, I would run 18 - 20 psi in the rear tires. Start the suspension on soft and work your way up one notch at a time to improve the ride.
    Jim Murphy
    Iron Butt Rider 2001
  6. #6
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Welcome to Trike Talk
    Looking @ the photo I see the rear shocks @ a pretty severe angle
    The rear ride height is TOO high, that throws the front fork out of whack causing hard to steer and high speed wobble
    IMO get the rear end down, move the shocks closer to the wheels if you can
    Lowering the back should give you better steering and less wobble
    JMO
  7. #7
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    JMO
    I agree!
    Move the shocks from under your butt to under the passenger seat, the rear is much to high.
    Please fix it before taking it out on the road.
    God bless,
    Ride safe
    Gideon
  8. #8
    5+ Posts
    Jun 2018
    UK
    Edit: A quick google says I should aim for 15 - 20 degrees, I think mine are closer to 45.
    Thanks again guys. Is that change the angle of the shocks or just move them further back? (Maybe both?) There's a bar going across further back i should be able to reinforce and weld some mounts for the shock, then just try and attach the top end further up by the sides of the grab rail.
    (Ignore the scattered wiring, I was in the process of wiring the back lights)
Size:  510.0 KBName:  WP_20180518_07_49_46_Pro.jpg
  9. #9
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Moving the shocks back will set them at a better angle in affect lowering the back end
    However you may have TOO long of shocks also
    Too long will keep your rear ride height to high, you want to drop it down to let the front end take control whilst you ride ( may have to get shorter shocks eye to eye and different springs)
    I hope this helps and makes sense
    The only other and expensive option is cut your neck on the frame and change the front rake kicking the front wheel further out to ease the steering and make the ride more stable
  10. #10
    5+ Posts
    Jun 2018
    UK
    So, I've just opened up the back a lil and there's a nice bit of chassis i can drill a hole and weld a new mounting point for the shock. I've also had a look online and there's a host of shorter shocks i can fit for a reasonable price. I was just wondering how much you'd recon i should lower the shocks by. I think the stock ones on there are 340mm (Currently compressed to 310mm but i think they're knackered) and the shortest I've found so far are 280 mm. Before i buy any i'll retry my current shocks w/ the new mounting points and see how much that lowers the back end and how much it affects the heavy steering (A bit of rough trig says the back end should drop by about 20 mm).
    Once again, thanks for all the help.Name:  WP_20180612_12_17_54_Pro.jpg
  11. #11
    Dec 2014
    I think I'd wait before moving the rear shocks until you see what the wood rear does to the geometry. THEN make shock adjustments. The wood will be heavy and lower the rear quite a lot.
  12. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Look @ mounting your shocks @ the sissy bar bolt, that looks to be a pretty good angle
    Try a level on your seat, I bet it is WAY off, if you can drop the rear of the trike so the bubble shows level from what I see in the picture you could get a pretty close idea of your rear shock height JMO
  1. Mexican joe's to wild west
    By Phill Griggs in forum Trike Travel
    Last Post: 03-26-2015, 08:54 PM
  2. Hog Wild
    By Hog Wild in forum New Member Introductions
    Last Post: 11-14-2013, 03:57 AM
  3. wild and wavy speedometer needle 1800.
    By trikezone in forum Honda Trikes
    Last Post: 05-11-2012, 04:13 PM
  4. Hello from Wild Wonderful
    By Cruisinthe34 in forum New Member Introductions
    Last Post: 06-14-2010, 07:42 PM
