Likes Likes:  6
Results 1 to 20 of 21
Thread: ironhead with a servi-car rear end
    Jun 2011
    Newton, KS USA
    Default ironhead with a servi-car rear end
    I mated a servi-car rear end to my 74 sportster, it has a weird issue with 2nd gear. Has anyone that has combined these two have any problems?
    All gears work fine but when I'm in 2nd, the motor rpm's won't stay constant, it's as if I'm twisting the throttle back and forth, the bike jerks. Makes no difference what speed or rpm I'm at when I shift to 2nd the bike starts this jerking motion, the engine rpm's go up and down, I shift to 3rd and all is fine. It's not popping in and out of gear, it's like give it gas, stop, give it gas, stop, all the time while in 2nd.
    I have tried different drive gears, it now has a 19 tooth sprocket, stock rear sprocket.
    Any ideas?
    What happens if you keep pressure on the shifter?
    You could have a bad shifter dog on second gear from years of abuse?
    Jun 2011
    Newton, KS USA
    The transmission was rebuilt, new gears, sleeves, shift forks, anything that was questionable I had them replaced. I have taken the transmission to two other shops, both said it was fine. I have not tried putting pressure on the shifter because it does not come out of gear, or tries to.
    When it was a stock 2 wheeler I did not have this problem. That's why I am stumped. Could the extra weight and the gear ratio be the problem?
    Quote Originally Posted by don56 View Post
    I dunno bout that
    How is your primary chain adjustment?
    Also final drive?
    Jun 2011
    Newton, KS USA
    I dunno bout that
    Also final drive?
    Adjusted primary by factory manual, final chain has about 1/2" play.
    Interesting, sounds like the engine has a miss @ the RPM in 2nd gear under load, what happens if you pull the clutch in and give it some gas does it wind up good? Is this a right side shifter?
    Jun 2011
    Newton, KS USA
    Bike is a right hand shift, has electronic ignition. I have by passed 2nd and gone right into 3rd just to see how the bike will react, it will pull up through the rpm range with no problems, it's a little sluggish at first, but it doesn't cut out or miss.
    The ignition, could that be the problem? Could it be electric and not mechanical? If electrical why just 2nd gear?
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Any ideas?
    Have you found the cause of your issues with 2nd gear ??
    Jim Murphy
    Iron Butt Rider 2001
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    I think he needs a new clutch.
  11. #10
    Quote Originally Posted by Old Road Dog View Post
    I dunno, the OP said it shifts fine into third and does not seem to slip
  12. #11
    Jun 2011
    Newton, KS USA
    No I have not . I put a new clutch in about 50 miles ago. This problem did not show up until I turned it into a trike. This is why it's so frustrating. The rear end is an old mechanical brake set up from a servi-car, converted to disc brakes.
  13. #12
    Aug 2018
    Quebec City Canada
    Hi i,m new to this forum and maybe you can help. I,m up to get a rear-end of a servi-car an would like to do the same to my Ironhead but notice is on the left side and my Iron is on the right is it only a question of turning the axil 180 degress from left to right i don,t have it with me to chek before i buy your help and pics would be appreciated.Thks
  14. #13
    Aug 2018
    Quebec City Canada
    Chain binding have you tried lifting rear end and shifting thru gears with no weight on bike.!
  15. #14
    Jun 2011
    Newton, KS USA
    Quote Originally Posted by George65 View Post
    No I have not, I am going to try that. Thanks for the idea.
  16. #15
    Jun 2011
    Newton, KS USA
    Sportsters and servi-car drive chains were both on right side.
  17. DKCustoms postbit
  18. #16
    Aug 2018
    Quebec City Canada
    Have only seen on pics seem to be to the left don,t know if its mech. or juice brakes.
  19. #17
    If I remember right all the 45 Flatheads were rs chain including the KH models
    Guess that maybe why the MOCO left the Sportsters rs drive also
  20. #18
    Jun 2011
    Newton, KS USA
    I just put the bike on stands, it runs through all gears the same, no stumbling in second, no rpm change no lugging. Take bike off stands, go for a ride, go into second and it does it's jerking, and only in second. All chains are adjusted properly, new clutch, everything on this bike is new, all but the rear end. Any more ideas?
  21. #19
    Did you change 2nd gear ratio with a new gear?
  22. #20
    Aug 2018
    Quebec City Canada
    Try by loosing rear and primary a bit at a time up front is factory but rear isn,t maybe arc with some weight on it a couple of thousands of an inch can change the readings.!do you have any pics
  1. Disc brake conversion for harley servi car rear end
    By Downtown Cowtown in forum Harley Trike Conversions
    Last Post: 10-27-2021, 07:17 PM
  2. 1951 Harley Servi car rebuild
    By 1fangtooth in forum Harley Trike Conversions
    Last Post: 11-27-2014, 09:55 AM
  3. 1951 servi car rebuild - engine is done!
    Last Post: 12-17-2010, 06:47 AM
  4. 1951 servi car - tackling the clutch assy
    Last Post: 12-07-2010, 10:23 PM
  5. 1951 Harley Servi-car rebuild
    Last Post: 12-01-2010, 05:59 PM
