Took a while to do this. Made a couple mistakes along the way but it didn't turn out too bad.
Added a little over 3" to the length.
Looks good to me, where did you get the material from, always thought about it myself instead of a mud flap, never could find the material that is shiney and if I did it was to thick to use.
All for now Trampas
I ordered from Stainlesssupply.com
It is 304 Stainless Steel Sheet #8 Mirror 22G (.0293")
Width 6 3/8", Length 14"
Cut type Shear
Grain Pref: no
It was a custom order so I did not have to cut anything off the length or width.
I cut the rounded corners with a dremel using the old skirt as a pattern to mark them.
I had a piece of wood that my dad was turning on his lathe to make a goblet or something like that, it fit the bend in the old skirt just right so I use it to bend the new one by hand.
then I used the old skirt to figure out the holes to screw it to the fender, as you can tell I made an error with that and had to drill a couple more holes.
Took me about 8 hours total but I would do a step then think about the next step for a couple days.
I used information provided by Kevin to figure it all out along the way. Especially on how to mount the emblems.
Thanks Kevin
It turned out better than I expected.
Bob
This may be a stupid question, maybe I just haven’t had my trike long enough, but why do you need a longer fender skirt?
2018 115 anniversary Tri glide, 2 +2 narrow sweepers, DK comfort lift, DK tour pack relocation kit, pro action shocks, power vision, fuel moto air cleaner, s and s mufflers
Stupid question number two,will it clear the ground if the tire goes flat? Probably just the angle of picture.
I live on a gravel road and had a rock or stick get into the belt and wore a groove in it. When it costs $900 (insurance covered) at the dealer to replace a belt I thought I would try something to help keep it from happening again.
I thought this might keep the rocks from going that far plus it will keep some of the road spray off the front of the engine.
I measured on my basketball court and the rim is roughly 3 3/4" off the ground with air in the tire, the fender skirt is roughly 3 1/4" from the ground.
I don't think it will be a problem unless the tire comes off the rim.
Bob
I did the exact same thing last year but only extended mine two and a half inches , it keeps the spray , rocks and mud from front tire off of the water pump cover and engine . Works very well ! Ebert
Looks like your trying to publish it from your hard drive.
You need to upload it.
Check out this thread for help.
https://www.triketalk.com/forum/thre...Post-a-Picture
Bob
Love the idea and it looks nice! I drive about 1 mile of gravel before blacktop. I wanted to stop any debris from pounding the front of the engine etc. I went with a mud flap that I glued to the inside of the stock fender skirt. It seems to work great and the motor stays super clean.
Looks very functional to me , luvtofish ! I was planning the same thing but couldn't find any rubber that satisfied my liking . Ebert
2018 Tri Glide ,Vivid Black ,relocated tour pak ,power port in tour pak ,front fender extension , Harley adjustable backrest , LRS 10 " Flat top , DK 2" tank lift , DK discreet breather system , Harley Chrome rear bumper
