Likes Likes:  2
Results 1 to 9 of 9
Thread: Mirror Advice
    Jun 2018
    Polk City, FL
    Default Mirror Advice
    My right mirror glass will not move up far enough and all I see is the rear fender. It moves up, down and side to side freely, just not enough “up”. The mirror appears mounted same as the other side and after searching for prior posts, I’m not clear if removing the mirror will be of any help.
    Sep 2016
    Kent, washington, USA
    Default mirror
    Those leave a lot to be desired.. I am going to try a bubble to see if that helps.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by truk4u View Post
    I've had mine off and I sure couldn't find any other adjustments. Tomg
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    How tall are you? I'm vertically challenged (5'7") and it's OK for me. I do sit on an Airhawk to try to make sitting on the plywood more comfy. As you probably know by now, there isn't much padding in the seat. Rick
    Stallion #378
    Suzuki Burgman 650
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    try parts store near you for spot mirrors they make onr with a swivel that works well , i have the small square ones on mine...
    100+ Posts
    Sep 2017
    Clinton Township Michigan usa
    Quote Originally Posted by rocket1lf View Post
    What is the Airhawk? Is that a replacement seat or something you placed on top of the seat?
    Greg
    Quote Originally Posted by Greg336 View Post
    Greg
    Its an inflatable seat cushion/pad........That you place in your present seat...
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    LOVE our AirHawks.
    Have both styles - the original full seat and the Gentleman’s cushion (which has an open track in the middle for comfort for the gentleman’s genitalia).
    Warning: It doesn’t take but a LITTLE bit of air to make them nice and cushy. You’ll need to experiment with that for the “just right” preference.
    A tad pricey but cheaper than trying to find a full replacement seat.
    Nov 2010
    Newbern Tenn.
    Default mirror
    I went to a glass co. and had a mirror made the same size and I use Velcro to get it in the position I needed and it work very well.
  1. rear view mirror
    By Ed Hobgood in forum Stallion Trikes
    Last Post: 06-22-2012, 08:16 AM
  2. Mirror
    By rgc in forum Harley Trike Conversions
    Last Post: 06-30-2011, 05:30 PM
  3. Baker Mirror-mounted Air Deflectors...???
    By skuuter in forum Accessories
    Last Post: 09-01-2010, 12:53 PM
  4. Mirror for trailer?
    By Spirit Warrior in forum Trailers / Campers
    Last Post: 04-23-2009, 06:33 AM
