ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  1
Results 1 to 12 of 12
Thread: Hood Allignment
    10+ Posts
    Jun 2018
    Polk City, FL
    Default Hood Allignment
    My hood has a gap on both sides. I have removed all rubber stops front and rear and also removed the 2 locking mechanisms and the hood will not lay flat. I assume there is an adjustment up front, but I’m not clear on what needs adjusted. I see no sign of any previous damage.
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Tom did this just happen? Or is the trike new to you and this is the way it was. Also which body fiberglass or plastic? The locking system is different between the 2. Just with what I see something is holding it from going completely closed. Leave a wrench in the way?
    10+ Posts
    Jun 2018
    Polk City, FL
    Default Reply
    I just got it and that is the way it was. No wrench in the way. I think it's ABS and not fiberglass, 494. It will lock in place when closed with no problem, it just doesn't look right. There is no damage or bent linkage up front, everything looks good.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    The front hinge with the hood open you should see 2 bolts on each side. And those will effect how it adjusts also. If you do mess with these, mark your hinge location with tape so you can use that as a guide . Your body will tell you plastic or fiberglass. Look on the side, fiberglass will be smooth and plastic will have a seam even to the back of the front seat.. Adjusting the hood is a LOT of trial and error so have patience! Tomg
    10+ Posts
    Jun 2018
    Polk City, FL
    Thanks Tom, but you lost me on the fiberglass/plastic comment and seam to the back of the front seat. Are you talking about the exterior? Here’s a pic if it helps..
  6. #6
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    I did mine a few months ago because it was rubbing on the coolant reservoir. I loosened up the left side bolts and slid it forward about 1/4" and everything is good now. I did have to move the hood locks back a bit to get it lock correctly. I don't think doing this will close your gap. It seems like the hood needs to come down farther. You would have to adjust everything and that isn't easy. There is a thread on this and some answers from Richard. Rick
    If you got to ride, ride in style
    Stallion #378
    Suzuki Burgman 650
  7. #7
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by truk4u View Post
    Fiberglass body. Tomg
  8. #8
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Now that I know you have a fiberglass body I will look tomorrow to see if I can suggest something.
  9. #9
    10+ Posts
    Jun 2018
    Polk City, FL
    Rocket, mine is also hitting the coolant tank. I think my next course of action is to loosen the 2 bolts on each site, remove the shocks and see if I can get it better lined up.
  10. #10
    Oct 2009
    Titusville, Florida
    This sure makes me wonder about the difference between the 08/09 years as my coolant tank is no where near the shocks so I'm a bit confused as to why you need to disconnect them. Tomg
  11. #11
    10+ Posts
    Jun 2018
    Polk City, FL
    The coolant tank is not near the shocks, I’m taking off hoods struts (shocks) to make sure they are not holding the hood from going down and mating with the lower part. Right now I have removed the coolant tank, hood locks and rubber stops next to the hood locks. The hood will still not set flush as seen in the pictures. It’s not hitting on anything I can see, so possibly the shocks are holding back the closure, may be the wrong size.
  12. #12
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Thats a possibility if they were changed out
  1. fire under the hood
    By ODDOMAN in forum Stallion Trikes
    Last Post: 07-03-2015, 08:05 PM
  2. 2010 stallion hood
    Last Post: 05-26-2014, 07:37 PM
  3. Ultimate Stallion Hood Ornament
    By Switchback in forum Stallion Trikes
    Last Post: 04-24-2012, 12:19 AM
  4. Lockaable Gas Cap and Hood
    Last Post: 10-22-2010, 12:31 AM
  5. Hood Adjustment
    By Silver Eagle in forum Stallion Trikes
    Last Post: 06-08-2010, 09:29 PM
