Likes Likes:  3
Results 1 to 16 of 16
Thread: Limited slip diffs
    Jun 2018
    Leighton buzzard England
    Default Limited slip diffs
    Which diff is best for a bike trike? My last trike was a Suzuki 850 ,I was told the axle was either a Suzuki swift or SJ 410 ,what ever it was it scared the ****e out of me!
    Going round bends at 70 was not pleasant,even on gentle dual carriageway bends (freeways to Americans) the awkward heap of junk wanted to visit the other side of the road ! Took a lot of effort and slowing down to get it at steer away from the central barrier..okay it still had normal front tyre and comparatively narrow bars.
    I don't remember my Yamaha trike being that bad but it was twenty years ago.
    Found out later the previous owner of the Suzy came off the thing and died !
    Now the question is ,what type of diff gives lighter steering?
    I always thought limited slip was invented to allow the outside wheel to turn faster in a bend than the inner ,thus facilitating the turn and reducing wear on the tyres. So I figured it'd allow quicker steering ? Am I wrong. Any advice welcome.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    A limited slip diff would try to keep you going straight ahead.....not a good thing. It may be possible to disable the springs/clutches etc. that make up the limited slip function, and go back to an open rear end.....others will know more...Welcome to Trike Talk!
    Jun 2018
    Quote Originally Posted by LarryA View Post
    Thanks Larry, so no Jag or BMW axles then?
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I think you're confusing the the two. A differential is what allows the wheels to turn at a different speed in corners. All cars have differentials not all differentials are limited slip.
    Apr 2015
    Batesville, AR. 72501
    Here's a basic explanation of the two diffs: https://www.speedwaymotors.com/the-t...rentials/28854
    I'd suggest that you take your trike to a auto recycler (can't remember Brit term even after watching Wheeler Dealers)and see if they can identify the differential from experience, casting numbers, etc. Then you will know exactly what you have.
    The thing about LSDs is that their clutch loading is calculated for the weight of the vehicle among other things and you are definitely lighter than the original vehicle. Once you know what you have, if it is LSD, then you might look up a driveline shop for some expert advice about modifying your diff.
    Also, Pictures....We love pictures.
    Jun 2016
    milnor n.d. usa
    just jack up rear of trike with both rear wheels of the ground....turn 1 wheel forward... if other wheel turns forward also...you have a limited slip or a locking type differential....if the other wheel turns rearward, you have what we call an open differential. You may be confusing an independent rear end setup...jag, corvette etc. with a limited slip...apples and oranges, Independent rears, or rigid housing types of rear ends can be either limited slip or open.
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Frank67 View Post
    it is possible you have too much trail..
    but do like larry said ... figure if it is limited or open diff.... i am betting it the front end..
    Jun 2018
    Thanks for your reply,sorry I took so long getting back,I have since seen a video on this subject and understand a bit better. Obviously my last trike was LSD , previous owner thought it came from a Suzuki four wheel drive, which explains the straight lining.
    Limited slip is just like a regular differential in normal driving....It only comes into play if one wheel is on ice sand or on a slippy surface,..IE; When only one wheel starts to spin it transfers power to the stationary wheel ....Almost all pick-up trucks and now most cars have some from of limited slip...And they all track straight, I think some are confusing a Locked axle for limited slip....Two different animals,
    750+ Posts
    Jan 2010
    east windsor ct
    in a manner of speaking i suppose it puts power to the stationary wheel... but it really ties the two wheels together
    Yes, But with a clutch inside the differential so the axle isn't locked when both wheels are finally spinning at the same speed........
    Jun 2016
    milnor n.d. usa
    to put it another way.....on a limited slip differential both wheels are tied together by the friction of the clutchs and their springs....during a turn, the clutch plates must slip while the spider gears are rotating around the side gears. the clutch friction, developed by the springs and clutch plates, determines how much the rear axle will resist deviating from straight ahead travel.
    Dec 2018
    Melbourne, Victoria, Australia
    OK. I stumbled upon this thread (thankfully) because I am now looking at my first trike build. I am starting at the back end first I guess but this is crucially important.......so.......
    "Can a limited slip diff be used in a trike build or must an open type diff be used"?
    I would have thought that limited slip types are OK but if they are specifically set up around the vehicles weight then that will mean they need mods when installed on a trike.
    There are a LOT of LS diffs around which means more choices...or does it?
    Can anyone clarify the whole LS vs open thing? Thanks.
    Quote Originally Posted by kwikas View Post
    Andrew......Welcome to Trike-Talk...........And see posts 9 to 12...
    750+ Posts
    Jan 2010
    east windsor ct
    guess i cant explain it much better than already done.... bottom line imo is open diff on a trike other wise you will be working harder to make it turn.. course there are many factors to be considered.. how long is the trike, why do dont you want to use an open diff, you looking to ride on the beach, tooking to do two wheel burnouts Andrew it may sound this is directed at you personally. it is NOT .... i use "you" in a general sense
    Dec 2018
    stacebg/rhino 2.
    All good...I just couldn't quite figure this LSD/OD matter out. What was being explained just seemed to be a bit ambiguous so was seeking some clarity. Thanks for your responses.
    OK, so open diff it is......
  1. Slip-On Recommendations For My 2011 Tri Glide Ultra Classic
    By joeychitwood in forum Harley Tri Glide
    Last Post: 10-03-2011, 03:27 PM
  2. How do you remove the slip-ons on a 2011 Tri Glide????
    Last Post: 10-01-2011, 10:11 AM
  3. Dispose of stock slip-on pipes
    By Kansas_Trike in forum Harley Trike Conversions
    Last Post: 07-16-2011, 06:58 AM
  4. Cobra Slip-Ons
    By Smoken'JOE in forum Honda Trikes
    Last Post: 07-12-2010, 04:14 PM
  5. triglide slip-on mufflers
    By roadkill in forum Harley Tri Glide
    Last Post: 07-12-2009, 04:20 PM
