Likes Likes:  302
Thanks Thanks:  32
Page 16 of 16 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16
Results 301 to 312 of 312
Thread: Freewheeler "Chopper" Project
  1. #301
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    Quote Originally Posted by haute pursuit View Post
    Man, I haven't checked on your progress in a few months. That bike is SICK! Glad that you got it finished and are getting some seat time brother. Fantastic job!
    Thanks. I have started a new one....it has its foundations in a 2000 Twin Cam Springer Softail....an oldie but a goodie. As I tear into it I will post progress in the "Harley Conversion" forum
    Here is the traditional crappy photoshop of it... My Zero Trike
    Name:  FXSTS TRike Concept.jpg
  2. #302
    Dec 2014
    Grand Junction, Co. USA
    Quote Originally Posted by Free Bird View Post
    Not so crappy ... hoping you get the springer on this one ...
  3. #303
    100+ Posts haute pursuit's Avatar
    Aug 2016
    houston, texas, usa
    Well.... I had my first operational design issue. Since I put the fenders on I have not been above 65 MPH (just realized that when this event occurred) as I have been riding the quieter blacktop two lane roads and not the super slab.
    I was driving the bike to the saddle shop on a freeway and within a mile or two broke free of rush hour congestion and opened her up. When I hit 70 the fenders started a hard oscillation banging into and off of the tire. The sound scared the hell out of me at first as I thought the calipers had come loose or???? Then I saw it. The LH fender was trying to flap like a wing. I pulled over and inspected things. No breaks, cracks etc.... So I pulled off at the next exit. No problems. Got back on the highway and cranked it up. 50 MPH NP, 60 ..same... 65...same... 70? BANG BANG BANG....
    So, It appears as if airflow and/or nodal vibrations (harmonics) in the structural elements have an issue at speeds above 70.
    Good News - I can pull the fenders off and keep riding
    Bad news - Engineering a modification/repair likely means a re-paint for the fenders (Damn)
    One of my theories is the gap between the tire and fender (~0.250") is too tight and the fender is lifting off the tire. Think about how those tires shed water from the tread pattern... air is a fluid too... so at speed they could be creating an air flow that lifts the fender. The solution for that fix could be swapping the MT 29x18 R15 tires for 28x12 R15 tires. That would give me 0.500" vs 0.250 clearance and perhaps provide an exit for the airflow. I lose width but save the paint.
    It is just a theory though
    The other fix would be to increase the stiffness of support structure by moving from 1/2" to 1" round bar in the fender frame. Essentially rebuilding the fender. I would also have to thicken the bracket and beef up the attach points as I would move that bending load someplace else by stiffening the uprights. But I could also add the clearance of the smaller tire at the same time and retain the tire width I like ...
    So gotta make a choice
    First thing is to remove the fenders.... I will be able to think better when I am riding
    Just an fyi if you haven't already fixed this... I had to go with 1" flat bar on my trike fenders to solve the same problem. I get a little vibration at idle, but no problems at speed. We went with a welded grid pattern to make sure it worked the first time. You may not need as much support as I did though. Good luck!
  4. #304
    Mar 2018
    Saint Louis
    Thanks! It has the springer on it already... it is a 2000 FXST Springer Softail. I am cutting the frame front and back. Putting a Zero Style Dragon Neck on the front @ ~41-45 degree rake (trail will determine) and a rigid x-frame in lieu of the softail swingarm to accept the Independent Rear Suspension axle in the back
  5. #305
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Jeff, check that crank run out
  6. DKCustoms postbit
  7. #306
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Won at the KSHE (a St. Louis Rock Radio Station) annual bike show today. Hey Micheal! This one's for you!!! Get better man. (yes... the sign says 6-22... the event was postponed due to a fire at the original location and today was the re-scheduled event...)
    Attachment 76911
    Man, I've not been to this thread in a while.
    CONGRATULATIONS! Good to read you're out enjoying the wind on your sweet ride!!!
    Looking forward to your new build.
    www.DKCustom.com
  8. #307
    Mar 2018
    Saint Louis
    Looking forward to your new build. Kevin
    Thanks Kevin! There are several DK parts incorporated... Does this set-up look familiar? Works like a champ!
  9. #308
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yes! Very cool! Glad you're enjoying, and we are ALWAYS thrilled to see our parts on folks rides...especially Show Winning Rides!
    www.DKCustom.com
  10. #309
    1+ Posts JIMHALL_AZ's Avatar
    Apr 2019
    Queen Creek, AZ. USA
    Default Current Backrest
    Looks like a great project. The pictures with the tires next to the Red Freewheeler has a Backrest w/armrest. Where did you get it?
    Thanks.
    Jim
  11. #310
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by JIMHALL_AZ View Post
    Thanks.
    Jim
    Jim.............Welcome to Trike-Talk...................
    2019 Tri-Glide.......
  12. #311
    Mar 2018
    Saint Louis
    Jim, welcome to Trike Talk!!! This is a GREAT resource for info.
    That is a Corbin backrest that I use when my wife rides. Here is a link to the site:
    http://corbin.com/harley/triglide/hdfwdte.shtml
    Part Number: HD-FLH-9-ARM
    You have to click through the pictures to find it
  13. #312
    90+ Posts kwkride's Avatar
    Sep 2018
    Nebraska
    Yes... using same mounts as the OEM backrest. I have a Corbin one with armrests for longer rides and the sissy bar for around town. But they are both plug and play. I will post pics of it on the bike when it is back together.
    When you ordered the Corbin backrest/armrest pad, did it come with hardware for mounting it to the sissy bar?
    (I’ve emailed Corbin and asked, but they haven’t replied)
    Thanks!
    Jim
    MSF 27339
    2020 Freewheeler , 2005 FJR 1300
  1. chopper back brake drums???
    By uncleledbetter in forum Harley Trike Conversions
    Last Post: 04-19-2011, 06:43 AM
  2. Chopper Conversion
    By Freddy in forum General Discussion
    Last Post: 10-08-2010, 10:19 PM
  3. Honda Fury Chopper
    By skuuter in forum General Discussion
    Last Post: 09-22-2010, 10:53 AM
  4. Howdy from Santiago Chopper Specialties
    By SantiagoChopper in forum New Member Introductions
    Last Post: 09-06-2010, 06:27 PM
  5. Howdy from Santiago Chopper, FL
    Last Post: 12-29-2009, 11:31 PM
