Likes Likes:  2
Results 1 to 18 of 18
Thread: RPM skip in 5th gear only
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    Default RPM skip in 5th gear only
    I mentioned this a few weeks back and its still doing this.
    Running down the road at say 55 mph and in 5th gear. Engines doing 21 to 2200 rpm. Give it some gas rather then downshift and the engine skips a beat for a 100 to 200 rpm. Fells like its the clutch slipping. It only does this once in a while. Cant make the trike do it when I want it to. Does not do this in any other gear.
    FI miss maybe??
    28K on the bike. No engine services have been done yet. Other then regular oil changes.
    Its been doing this for the last say 2K miles or so.
    OEM plugs still look good burning right so is the gap.
    Any suggestions??
    Ive been using Aims oil JASO rated 10w-40 for the last 10K miles.
    10+ Posts SMOKENJOE's Avatar
    Jun 2018
    BULLHEAD CITY AZ USA
    You neve said what kinda trike but I had a harley road glide with a 96 ci in 6th gear did the same thing i put an extra plate in the clutch pack never did it again barnett sells the hole kit or get an extra plate
    750+ Posts tom w's Avatar
    Sep 2013
    poplar bluff mo
    Mine did it for a while. problem was not enough clutch. put in a 480lb AMI spring. fixed it.Then Put in a clutch ez and fixed my lt hand cramp.
    Nov 2012
    Quote Originally Posted by SMOKENJOE View Post
    Your right I absolutely forgot.
    Its a 2010 Gold Wing trike. 28K isn't even a warm up for its engine let alone to have a clutch issue so young.
    Might be a spring pack for a Wings clutch. But truthfully. This bike has needed zero anything since new. If it does exist. As a V twin guy I really don't know about it.
    What you did works well with my RoadStar clutch too.
    GW is a whole different animal.
    Nov 2012
    Quote Originally Posted by tom w View Post
    My issue too. Arthritic hands.
    Next time you ride it, after shifting to 5th gear, gag the throttle, if the RPM goes high and stays there for a second or 2 you have a slipping clutch IMO
    Nov 2012
    As I said in the OP I cant make it do it. Under any condition at will.
    Just rolling along at 55ish 2200 rpm give it a bit of gas and it gains 100-200 rpm for a split second.
    Riding along normally. I don't shift into 5th until 65 mph or so and it just chugs along fine from there.
    Mar 2011
    mountain home,ar. USA
    Quote Originally Posted by JaysGone View Post
    You say in gains 100-200 rpm. What do you feel the bike doing? Does it actually hesitate? Does engine sound correspond to rpm drop?
    Nov 2012
    Quote Originally Posted by mhgoldwing View Post
    It feels like a clutch slipping but for a split second.
    With a 100-200 rpm increase. No rpm drop. Then normal. For being in 5th gear at 50ish mph. When I know I shoudnt be. But Im going with traffic at this point. Steady rpm. Hit the throttle just a tad to keep up the speed. Accelerating lightly....feels like a slipping clutch for a split second, rpm increases then bike rolls along like normal.
    Almost like a burp.
    Now if Im accelerating lightly say in 4th at 45ish at 50ish put it in 5th and continue to accelerate it will pass right on through that miss point 2100 rpm like nothing at all is wrong.
    A Gold Wings hydraulic clutch is nothing like a V-Twins spring loaded at all. Quarter inch of clutch lever is all one needs to change gears. If I even use it at all upshifting.
    I have a bad habit left over from my road racing days.
    Clutch?? what clutch?? Up or downshifting.
    A lot of the time. The only time besides being at a stop or in 1st and shifting through neutral to second. I very rarely use the clutch once in 2nd up or downshifting.
    V Twin, Gold Wing. 400+ HP Z28 set up for racing.
    I do know how to shift. None of my vehicles has ever done this. I have had many a clutch go in 40 years.
    But then this GW is the 1st fuel injected anything Ive ever owned...... So if its FI related?? I wouldn't know it. Nor what or where to look.
    Mar 2011
    Almost like a burp.
    just a SWAG, but I think this is related to the fuel injection and sensor inputs. Way over my head. A really good GW mechanic might be able to sort this for ya. Good luck.
    Sep 2012
    Lakeland, FL
    Jay, maybe I missed it, what brand conversion?
    You may be on to something ... would make sense. Maybe a spark advance issue also ... trying to think outside the box.
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Just sayin. But the engine is mechanically hooked to the rear wheels, if in fact the engine raises 1 to 200 rpm without a road speed change well there has to to be slippage in the drive train. My old suzuki intruder has a hydraulic clutch. When the relief port gets clogged with contamination corrosion from dirty fluid, then running on the highway would cause the fluid to expand because of the heat. When the fluid can't escape back to the reservoir it puts pressure on the clutch causing slippage. Perhaps you have a similar problem. It didn't take hardly any movement at the lever to disegage the clutch.
    200+ Posts Hocky's Avatar
    Jun 2014
    Delray Beach, Florida
    Default RPM skip
    http://www.glriders.com/showthread.php?t=671&
    FI miss maybe??
    Any suggestions??
    Jun 2014
    Default RPM skip
    Here's another site that may afford advise. Good luck. http://justwings.com/
    80+ Posts Wingrider55's Avatar
    Oct 2015
    Kingston, Illinois
    I believe you said you are using Aims oil. Is it metric 4 cycle? If not the oil you are using will have friction modifiers that are not good for the wet clutch on a Gold Wing. Oil with friction modifiers will cause the clutch to slip.
    Quote Originally Posted by Wingrider55 View Post
    He said the oil he is using is JASO Rated....So no modifiers.....
    Nov 2012
    I ran the crap out of the bike. Gunning it at all speeds and gears.
    Then gave up and on the ride home 2100 rpm give it some gas to pass a car and it skipped a beat.
    Im almost 101% sure its an FI related deal.
    Might just be for those who are familiar with "Ghost Shifting" which my GW has also done in the past.
    Just one of those things Ill have to live with.
    Unless it becomes a more frequent "annoyance".
    Hondas do some strange things on their own occasionally. No rhyme or reason. Just is.
  1. gear rpm
    By Paul692 in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-04-2016, 02:44 PM
  2. Just curious / What speed for 5th gear?
    By rmrc51 in forum Honda Trikes
    Last Post: 03-08-2014, 11:41 AM
  3. vtx 1800 5th gear power
    By meredog in forum Honda Trikes
    Last Post: 10-06-2010, 11:04 PM
  4. 5th gear problem
    By trikeleader in forum General Discussion
    Last Post: 08-14-2009, 11:20 PM
  5. Question on TriGlide 5th gear
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 04-02-2009, 10:47 AM
