Likes Likes:  1
Results 1 to 14 of 14
Thread: Leak
    20+ Posts
    Apr 2017
    Glenwood,Arkansas U.S.
    Default Leak
    Hey guys, I have a 2010 Trike. LOVE it. It has 9000 miles on it. The problem is I have a leak underneath the motor. I checked the oil level and it's fine. I think the leak getting larger. Any thoughts for the experts? Will it be hard to fix?
    Jun 2010
    Coram, NY USA
    You probably need to spray clean it and find specifically where the leak is coming from. I would start with primary cover. Maybe not as tight as can be. Assuming you are sure it is oil you are seeing drip. There is a gas overflow tube.
    200+ Posts Pooch's Avatar
    Aug 2017
    USA
    Is it oil or coolant?
    4750+ Posts
    Mar 2015
    Texas
    You need to clean everything to determine the source. But as was stated, check all bolts but don't over torque the primary. Another idea. Did you put any 100% synthetic oil in it. That can sometimes create leaks when regular oil won't. Just a thought.
    American Legion Rider
    20+ Posts
    Apr 2017
    Quote Originally Posted by Pooch View Post
    It is oil.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Don’t know what ya got, HD or ?
    Could be as simple as a drain plug O ring Clean it dry then check it out.
    Have you changed oil recently?
    20+ Posts
    Apr 2017
    Yes Sir, I changed the oil about 3 months ago. i appericate your thoughts.
    Aug 2017
    USA
    Have you looked at the oil filter? ran over anything in the road? Do you have a belly pan?
    800+ Posts Big Juice's Avatar
    Nov 2013
    Hot Springs Village, Arkansas USA
    Quote Originally Posted by 2010 trike View Post
    Did you put new washer on the drain plug? Best to put new ones on each oil change, for some machines.
    ​O J Miles - now riding "Lucille", a 2017 Spyder F3-Ltd. Roadster.
    When 2 wheels aren't enough and 4 are too many.
    Ahhhh, a hot cup of coffee and a good cigar, after a good ride.......
    20+ Posts
    Apr 2017
    Quote Originally Posted by Big Juice View Post
    No Sir, I didn't. Do you know the parts number by any chance? I have a HD Triglide Ultra 2010. Thanks so much for your thoughts.
    4750+ Posts
    Mar 2015
    Texas
    Is that where it's leaking? If not leave it alone. You can get by without replacing it but not too many times. Just no need to do it now if that isn't the source. I've not seen where you've identified the source. Maybe you have but I missed it.
    20+ Posts
    Apr 2017
    Hogcowboy, It is a oil leak. Just trying to figure out where it's coming from. I did tighten oil drain plug it was a little loose. Where can a feller get a correct washer for the bolt?
    https://www.amazon.com/50-Pack-Harle.../dp/B01DUTU9FS
    Here
  1. Clutch Cover / Cable Leak
    By trikes4ever in forum Harley Trike Conversions
    Last Post: 11-21-2010, 06:20 PM
  2. Oil leak at 3500 miles
    By sarge7882 in forum Harley Trike Conversions
    Last Post: 09-09-2010, 07:23 AM
  3. Air shock leak?
    By Big_Steve in forum Motor Trike
    Last Post: 07-27-2010, 08:11 PM
  4. Leak? On board compressor/air suspension
    By Mr.Wizard in forum General Discussion
    Last Post: 06-14-2009, 10:06 PM
  5. Constant Fork Seal Leak
    By dive328 in forum General Discussion
    Last Post: 09-30-2008, 12:18 PM
