Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  10
Page 2 of 2 FirstFirst 1 2
Results 21 to 32 of 32
Thread: Steering dampers
  1. #21
    30+ Posts
    Jul 2018
    troy illinois usa
    [QUOTE=Lee H. Mann;597657]1987 and later do have the holes............... BTW, you need to run 20 psi in the rear tires.[/QUThanks l
    OTE]
    THANKS!!!! Lee I was running 18 in old tires the new tires which are BF Goodrich Radial TA sidewalls seemed softer
    so I decided to 24 lbs. But you think 20 lbs would be better yet?
  2. #22
    30+ Posts
    Jul 2018
    troy illinois usa
    Thanks for your help Lee. So yes I do have the holes in the triple tree, but there is a metal shield bolted to the two outer holes. Will it be okay to remove? and what is this for rain ? wind? or both. Does not look like I can put it back on once the stabilizer is in place .Will this create me any issues?
  3. #23
    30+ Posts
    Jul 2018
    troy illinois usa
    Default Not avialible
    Damper from bk rider is not avialible and they dont know if they will get it back in stock. problem with supplier communication they said.
  4. #24
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    There are two schools of thought for the relevance of the shield (deflector).
    One is that it keeps the engine cooler ???
    Two is that it re-directs turbulent air away from the rider ???
    Many have been removed and never re-installed.
    Jim Murphy
    Iron Butt Rider 2001
  5. #25
    30+ Posts
    Jul 2018
    troy illinois usa
    Quote Originally Posted by Lee H. Mann View Post
    Now I notice the one from BK biker is not available and it did look like it would fit any hints and universal ones along with brackets
  6. DKCustoms postbit
  7. #26
    750+ Posts
    Jan 2010
    east windsor ct
    do you have a low speed wobble around 30mph?
    didnt see it any of the comments.. may have missed it
    just making a guess here ...
    do you still have the stock triple tree?
    is so get a set off raked trees
    i should away with most of the wobble and you will think you added power steering
  8. #27
    30+ Posts
    Jul 2018
    troy illinois usa
    Default Little bit of wobble
    Quote Originally Posted by stacebg View Post
    Yes slightly new rear tires helped out a lot. Also set the tour pack back as far as it could go. Puts the passenger back further and puts my weight back a little bit further as well that helped out a lot . Got a new trach specific Avon front tire coming hopefully that will make it even better yet. But yes about 30 miles an hour when I’m just moving along if I accelerate no problem just usually when slowing down or just cruising about 30 miles an hour what would pressure would you recommend running the new Avon tire Would lower pressure be better for wobble or higher pressure
  9. #28
    30+ Posts
    Jul 2018
    troy illinois usa
    Also don’t wanna spend the money on the triple tree trying to keep it as economical as possible
  10. #29
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by toutlnone1 View Post
    ah understand
    that wobble at about 30 seems to be the nature of some beasts... with 3 wheels rather trike or sidecar... no explanation why that is....
    i dont believe the rear psi will make much difference...at least not on any that ive build
    a little lower in the front might... but if i remember .. low enough to help.. the tire is way lo an would over heat..the front
    i have had one sidecar and one trike i couldnt get rid of the wobble no matter what i did .. and gave up... got the best of me (i hate that)
    this is what i used...
    https://www.jbugs.com
    seach pn 113425021 or 113425021J
    there are several version i find these work well
    certainly more place even an auto supply would have them i ask for one for a super beetle 71-74 i just did a google searh to find u a photo
    you need a heim joint 3/8 i think for one end
    it should be as close to 90 degrees from the stem so it doent wear out the rubber bushing..
    and it can be quit a pain to get it in the right spot so you are using the full travel of the damper
    this was the side care obviously not a sliding front end but still a pain to get in the right place
    if you can afford it at some point go with the trees you will wish u did it sooner... steering is so easy
  11. #30
    30+ Posts
    Jul 2018
    troy illinois usa
    ah understand
    Yes I looked into a triple tree in the past and thought about doing it, but then I read that you have to change the ignition switch? Because it might interfere with the tank. So I have made a big improvement over when I got it getting the new trike tire mounted Wednesday and it’s in the Avon trike specific tire hoping that will help. I did play around with air in the back tires. The tires it came with were 235 wide put 215‘s on their road a lot better steer it a lot easier. But I notice if I play with the front fork pressure rear airbag pressure rear tire pressure and front tire pressure changes the speed at which the wobbling starts. I didn’t know if there was an ideal setting for each? But I currently am running 24 in the rear tires 42 in the front tire which is a front motorcycle tire, 10 pounds in the front forks and between 50 and 70 pounds in the rear as I am fairly Large About 450 pounds combined weight thanks for your help
  12. #31
    750+ Posts
    Jan 2010
    east windsor ct
    id keep experimenting.. can always go back
    interesting to see how that trike specific tire works
    might look into other brand of trees seems there should be some made without moding the switch
    papa zook could probably help you
  13. #32
    30+ Posts
    Jul 2018
    troy illinois usa
    Default wobble cured
    ah understand
    New Avon Bias Ply Trike Tire did the trick. I can now take my hand off the bars at any speed and no death wobble
  1. GL1800 Handlebar dampers
    By Cool-A in forum Honda Trikes
    Last Post: 06-27-2011, 01:42 PM
  2. Tri-Glide Steering Damper
    By Tonyd in forum Harley Tri Glide
    Last Post: 03-15-2010, 12:47 PM
  3. Steering Stabilizer
    By crzrlou in forum Harley Trike Conversions
    Last Post: 01-04-2010, 12:20 AM
  4. Steering dampner
    By ROAD DOG in forum Harley Trike Conversions
    Last Post: 03-23-2009, 08:13 PM
  5. Steering Wobble
    By Pushrod in forum Harley Trike Conversions
    Last Post: 01-21-2009, 07:57 PM
