Parts for 08' staillion
Hello every one,
My name is Thor.
I just got an 08' stallion and the cd radio CDX-M60UI, does not work.
It acts as if it is not getting power.
I checked all of the fuses.
It is getting power and will intermittently come on and then go off.
it does not matter if it is in the mounting bracket or not.
Nor does it matter if you move the wires around.
If there is a fix for this please let me know.
Or if some one has a replacement for it also let me know.
2nd, the lights for the PSI and the volt meter don't work.
is there some one who has replacements for them I would like to know.
Lastly, can the air shocks be upgraded?
Any help will be welcomed.
Thank you
I would suggest there's an intermittent open in the wiring. This can be darned hard to find and correct. To correct, you may have to adopt what I refer to as the Columbus approach - seek until you find. Had a Goldwing with something similar. There was a poor connection between three wires that would make and break whenever I hit a heavy bump in the road. Just got lucky one day and touched the right place - rewired the connection and the problem went away.
Welcome aboard Thor. I copied this thread to the Stallion forum. People can welcome you here and answer your questions on the Stallion forum or both.
i would suggest there's an intermittent open in the wiring. This can be darned hard to find and correct. To correct, you may have to adopt what i refer to as the columbus approach - seek until you find. Had a goldwing with something similar. There was a poor connection between three wires that would make and break whenever i hit a heavy bump in the road. Just got lucky one day and touched the right place - rewired the connection and the problem went away.
thank you very much!
johear65
johear65
