Results 1 to 3 of 3
Thread: Rear Tire PSI
    Apr 2018
    Locust Grove, US
    Default Rear Tire PSI
    I know the rear tire on my GL1500 should be around 41PSI. Is that still true
    if I'm running a trike kit?
    Thanks.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    If you are speaking about the rear tire on a Trike, then 41 LBS is WAY TOO HIGH. You will bounce off the thing. If you are speaking of a 2 wheeler, than 41 is still good.
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by inspectsir View Post
    Thanks.
    Rear tire pressure should be 22 - 25 lbs. Makes for a cushier ride.
    Nuc
  1. Replies: 45
    Last Post: 10-05-2018, 10:00 AM
  2. Tire PSI Monitors
    By bikerbillone in forum General Discussion
    Last Post: 01-04-2016, 03:11 PM
  3. Rear tire psi
    By GARYD in forum Harley Trike Conversions
    Last Post: 10-12-2015, 09:02 PM
  4. High psi in a rear on the front.
    By JaysGone in forum Honda Trikes
    Last Post: 11-14-2013, 07:29 PM
  5. Tri-Glide rear shock psi
    By motorman7 in forum Harley Tri Glide
    Last Post: 09-01-2009, 09:54 PM
