ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  3
Results 1 to 5 of 5
Thread: Shifter
    Jun 2018
    Muskogee
    Default Shifter
    The shifter in in the way. lol how are you guys moving the shifter? i would like it to be just in front of the seat. which means it needs to come up a little and also forward a little. i'm new at this. and need help. is there a kit to move it or do i need a welder. anybody have any ideas.
    THANKS
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    With a cable shifter you could put the stick lever anywhere you want to.
    You can move a stock or standard type shifter a lot. As long as you can make the shift rod turn and go in and out. The more angle you put on that rod the harder it is to get it to work right. The dune buggy super shifter and universal joints work well, especially if you can not spend the money on a cable shift.
    Anything you do will be a custom set up and will require fab and most likely weld.
    Jun 2018
    Muskogee
    don't want to spend money on a cable shifter. a longer shifter would be ok. i have a empi 23" shifter in it now. but it's a little short. i also have a empi bus shifter. laying around. i was talking with a guy on facebook and he said that the bus shifter would work fine. just bolts right up. but the bug shifter has a pin coming out of the ball. the bus shifter doesn't. does it matter if the pin is there? can a bus empi shifter be used in a bug?
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    The stock shifters that were straight stems did not have a pin.
    The stock shifters that have a bend to the stem have a pin. It keeps it from rotating.
    The shift rod socket does or doesn't have a slot for the pin.
    A pin shifter will not go in a socket without the slot.
    A non pin shifter will go in and work in a slotted socket.
    That is about the only function difference.
    A long bus shifter just has lots of throw.
    Jun 2018
    Muskogee
    thanks that's what i needed to know. i tried to mount it but the bus shifter is taller. and would not mount. but last night i found a couple of diff spacers and longer bolts. they must have fallen out of the box the shifter. with the spacer it fits right in.
  1. question about pingle shifter
    By bobw in forum Honda Trikes
    Last Post: 09-12-2015, 07:19 AM
  2. Foot clutch and tank shifter
    By Bruce in forum Harley Trike Conversions
    Last Post: 12-27-2010, 07:13 PM
  3. Kliktronic shifter
    By pin-hi in forum Accessories
    Last Post: 12-04-2010, 09:06 AM
  4. The Making of a Reverse Shifter Extension
    By ultraboy in forum Harley Trike Conversions
    Last Post: 02-04-2010, 03:20 PM
  5. reverse shifter
    By chef@4 in forum General Discussion
    Last Post: 01-20-2010, 11:00 PM
