14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  4
Results 1 to 14 of 14
Thread: alternator
    250+ Posts
    Dec 2010
    oly,wa
    Default alternator
    good afternoon, i need to replace my alternator, how many others have changed theirs. did you replace it with a standard amp, or did you get a bigger one. how hard or easy to change.
    Thanx
    Dragon
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Sorry I can’t help. Good luck
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    sorry also have not had to do that.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    I would call Richard at TMS and ask him for pointers on the repair. Probably more time will be spent removing the protective rock guard than working on the R&R of the alternator but I also have not had to make this repair. Tomg
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by Dragon View Post
    Thanx
    Dragon
    How many miles on your Stallion? Is it an '08? I think I have only seen only a couple that replaced alternator. A standard '07 Ranger should work.
  6. #6
    250+ Posts
    Dec 2010
    oly,wa
    Thanx
    # 146 2008. 66k.
    it all started when I replaced my digital readout. volts always read 14.4. and I could not get air to work correctly at all, I had engine buzz in stereo. but then all of a sudden the volt meter started showing low voltage, not charging and then charging when you only rev engine, engine noise really bad in stereo. those are my problems. it is not like you can raise the hood check battery, pull off wires inspect them all that, all ranger videos show battery and alternator right there for checking . they don't show somebody standing on their head with their arm stuck up in the engine just to find the alternator let alone test it. I am getting too fat for this phew. let you know what happens
    Dragon
  7. #7
    Oct 2010
    Standing on my head makes me dizzy
    Sorry I can’t help
    Good luck
  8. #8
    200+ Posts
    Feb 2017
    Arp, TX - USA
    I'd stick with an OE replacement. No real need to "upgrade" to a higher output alt unless you've got a LOT of electrical add ons that are pulling the system down currently.
    I would check voltage output @ the alternator @ idle and on throttle, be a little easier than pulling it to have bench tested. As far as removal, the worst part is the accessory belt. Easy enough to get to it from the top, unbolt the a/c compressor & lift up and out of your way and you can get to the alternator from the top side. It is tight, but very doable & not much different from a lot of vehicles out there today overall.
    Have you added any aftermarket speakers, amp, etc? I would also check & double check both positive and negative connections both at the battery and @ the alternator. As intermittent as your issue seems to be I'd almost expect to find a loose wire to be the culprit.
  9. #9
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    Thanks for the information Richard. output is fine digital readout does not show what is really happening with system charging.
    Dragon
  10. #10
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Good morning
    Dragon
    My voltage readout was erratic a few years ago and the battery cable was loose. If you haven't you can look through the left wheel and check it out. Hope you find a solution.
  11. #11
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by trikervet View Post
    Loose cables #1 destroyer of electrical
    Causes HUGE voltage drops and spikes, this fools the regulators eventually causing over heating JM2 cents
  12. #12
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default Amen
    Amen, to loose cables taking out an alternator, happened on the car yrs ago. forgot to tighten the negative cable....smoked the regulator!
  13. #13
    250+ Posts
    Dec 2010
    oly,wa
    Hello
    I have been through the wiring ground system added grounds and made sure they were all good. alt checks good. my digital readout reads 14.4 volts all the time, rarely changes, goes to 14.1 sometimes. air pressure gage will start off at say 10 psi, 2 blocks down the road it could read 25, another 2 blocks it could read 0. gremlins, asked Richard no help with this problem. new digital readout, new transducer, new dump valve, new air lines.
    Dragon
  14. #14
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Alternator seems good. Mine with fluctuate between 14.0 and 14.2. As for the pressure, mine starts at 15, I pump it up to 25 to 30, it will drop down a couple of times and I'll pump it back to 25 until it stabilizes at 25. Then it will stay there for several hours if not all day. Rick
    If you got to ride, ride in style
    Stallion #378
    Suzuki Burgman 650
  1. Alternator whine
    By Konrad in forum Honda Trikes
    Last Post: 11-04-2013, 08:21 PM
  2. Need Alternator for 2002 GL1800
    By bayoudave in forum Honda Trikes
    Last Post: 10-10-2012, 09:27 PM
  3. quick question about converting to alternator
    By classicfins in forum VW Powered Trikes
    Last Post: 07-31-2012, 03:56 PM
  4. '03 GL1800 Alternator Drive Gear Failure
    By TrikerMimi in forum Honda Trikes
    Last Post: 07-16-2012, 01:48 PM
  5. Alternator Problem
    By holdthepickle66 in forum VW Powered Trikes
    Last Post: 07-25-2011, 10:31 AM
