Results 1 to 14 of 14
Thread: front end woble
    20+ Posts
    Sep 2015
    BAKERSFIELD CA
    Default front end woble
    can anyone tell me why the front tire wobbles when i go slow
    Sep 2012
    Lakeland, FL
    I have ideas, but I'll let the experts handle this.
    Bobby it has to do with Rake and Trail. A very detailed subject. do some forum search on rake and trail and you can get educated. Some times to much air in the rear tires will cause it. Try running 22 to 24 lbs and see if that helps. Most likely though your trke does not have a rake kit installed that MIGHT cure it. If it is onlkt at low speeds and you can handle it and the steering effort above that is acceptable then just don't take both hands off the bars and ride on.
    750+ Posts
    May 2011
    peru,in,usa
    Default hurricane
    how did everyone survive the hurricane? heard it was real bad down there.
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by bdmartin123 View Post
    if you have a set of stock trees and its only at low speed... (usually about 30 it goes away)... i wouldnt even bother checking or changing anything..
    get a set of raked trees the wobble should completely go away an you will think you have power steering
    100+ Posts steamer's Avatar
    Jun 2011
    romulus ny,usa
    your steering head bearings need to be tightened. This is a very common problem.
    20+ Posts
    Sep 2015
    BAKERSFIELD CA
    Default wobble
    Quote Originally Posted by steamer View Post
    thanks for the info
    bob
    750+ Posts
    Jan 2010
    east windsor ct
    it might be the problem..but not for sure
    other things it might be
    rear tires out of balance
    stock trees
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    What kind of steering head? What kind of trike? I just yesterday solved the less than 45mph "head shake" in my homebuilt. I checked wheel beargs, rotor trueness, float on the calipers, steering damper, and tire pressures. I did one at a time because I wanted to know what the cause was. It wasn't any of that. My steering post sets on taper roller bearings and there was a full turn of excessive slack in the post nut. I'm still running it a tad loose, but I can now engage cruise control at 40 and safely take my hands off the bars. So I'd suggest that you check the steering head slop. It's free and easy.
    Actually on trikes the steering post nuts should be tighter then on the same bike only with 2 wheels. Like on a HD the swing test is 2 or more swing throughs center on a 2 wheeler. On a trike it is only one swing through.
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    I joined TT for comments like this. The little details are priceless.
    What kind of bearings are in the HD steering head?
    Quote Originally Posted by rodekyll View Post
    Timken tapered like this
    1000+ Posts dannymax's Avatar
    Jan 2018
    Upper Hudson Valley, NY
    A low speed wobble (35 mph or less) can almost always be cured by snugging the steering bearings. Not sure on a trike but it the bearings on a 2-wheeler are over tightened the bike will wander and be difficult to hold in a straight line.
    Another solution may be a steering damper.
    2017 Freewheeler
    Billet Silver
    Compassion for animals is intimately connected with goodness of character....and it
    may be confidently asserted that he who is cruel to animals,cannot be a good man.
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by dannymax View Post
    generally a wobble is from to much trail... nature of a 3 wheeler a trike or a sidecar if the bearings are sloppy loose absolutely snug em down but if they are snug to tighten them to the point this stops a wobble is not a good solution,, bearings are meant to turn not stops from turning...short of reducing the trail the damper is the best bet but may not
    completely solve the problem
  1. Trying to decide on whether to rake or not to rake front end
    By Lil Red Hen in forum General Discussion
    Last Post: 02-15-2021, 02:55 PM
  2. Replies: 45
    Last Post: 05-15-2019, 03:41 PM
  3. Photos of your rear end —. Not THAT rear end !!!!!!
    By Snickers1948 in forum Harley Tri Glide
    Last Post: 11-04-2017, 02:07 PM
  4. Traxxion front end...
    By mpolissky in forum Honda Trikes
    Last Post: 04-05-2010, 09:33 PM
  5. Raking the front end
    By spiritdream in forum General Discussion
    Last Post: 10-22-2009, 03:40 PM
