Likes Likes:  1
Results 1 to 8 of 8
Thread: FL light
    20+ Posts
    Mar 2018
    kimberling city
    Default FL light
    Light came on yesterday after 100 hundred miles, no difference in power or the way trike was running, 20miles more stopped 2hours! started trike light went off, came back on after30 miles, stopped shut off engine to put on jackets, restarted engine no light 80 miles to the house no light! Could it be a bad sensor, dirty air filter, or is this normal before the fuel system shuts down?2003honda goldwing 1800! butch
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Ed, any of those is possible, but it could also be a glitch in the ECM.
    Jim Murphy
    Iron Butt Rider 2001
    20+ Posts
    Mar 2018
    kimberling city
    Default FL light on
    Thank you, any and all advice is appreciated! butch
    20+ Posts
    Mar 2018
    kimberling city
    Default FL codes
    Found side stand switch turned it so the light went out then flashed 1 long 5short so15is the right code now trying to find what this one is.if anyone has code I would appreciate it!ed
    Martinsburg, WV
    Quote Originally Posted by Edward Watkins View Post
    Try this link
    http://www.awingaway.co.uk/GL1800%20FI%20Codes.pdf
    Jim Murphy
    20+ Posts
    Mar 2018
    kimberling city
    Default Find code
    I want to thank both of you for your help so it looks like the#4 injector wire.this gives me a place to start looking! Again thank you very much!ed
    20+ Posts
    Mar 2018
    kimberling city
    Default #4 injector
    Going to try sea foam but will check wiring for loose connection or broken wire.Now have a really Stupid question, setting on the bike which side and going from front to back where is the#4injector located??ed
  1. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  2. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
  3. Blackpool Light Parade In The Uk
    By Papajoe in forum Honda Trikes
    Last Post: 10-19-2008, 11:29 AM
  4. First Light Show In Scarborough England.
    By The Wolf in forum General Discussion
    Last Post: 10-07-2008, 01:59 PM
