LD-Ordie1LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  3
Results 1 to 13 of 13
Thread: Life of rear tires on lehmans monarch II LLS trike
    20+ Posts
    Jul 2018
    Montrose
    Default Life of rear tires on lehmans monarch II LLS trike
    Hi- Just getting ready to change rear tires after 30K miles-Is that the average life of rear tires on lehman independent suspension trikes--
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Hank View Post
    Hank, 30K is pretty low mileage for the rear tires.
    What kind of weight are you pulling or loading and what air pressure are you running ?
    Are the tires worn evenly ?
    Jim
    Jim Murphy
    Iron Butt Rider 2001
    20+ Posts
    Jul 2018
    Montrose
    Default tire mileage
    Hi- Out of 12 K a year 800 of that pulling a trailer with no mor than 30 lbs tongue weight- With 2 up at 340 lbs. plus 20 lbs. cargo -- tire tread is 3/32 in. outside 2/32 in. center and on far inside no tread---
    20+ Posts
    Jul 2018
    Montrose
    I'm running 22 lbs of air in tires
    Martinsburg, WV
    Just by the measurements you have given in the tread depth, sounds like you have a negative camber situation. And given your complaint about ride height, it sounds like it is sitting low and causing negative camber.
    Jim Murphy
    20+ Posts
    Jul 2018
    Montrose
    Thank you Jim- I thought that with A arm suspension if its riding high or low the camber doesn't change. I must be wrong in my thinking and by adjusting the shock with more tension on the spring it should bring up my ride height and provide me with the right camber all-though my ride will be rough- Would this be something I should try?
    20+ Posts
    Jul 2018
    Montrose
    The shock is turned out 5 turns now--
    Martinsburg, WV
    Hank, turning the pre-load outward is lessening the spring tension and allowing the suspension to be softer and lower.
    Name:  LLS Spring Adjustment.jpg
    Jim Murphy
    Apr 2010
    Shenandoah Valley of Virginia
    On a independent suspension with unequal length A arms, arms swinging through different arcs as suspension works, lean tires in at top under compression, and straighten the tire up or even out at top on extension as a means to lessen tire wear due to side scrub at the contact patch.
    Hows the ride now … rough or smooth?
    You might want to look closely at the spring itself, occasionally a coil will sag or break.
    Apr 2010
    Upon further reading, I see your problem / fix above.
    20+ Posts
    Jul 2018
    Montrose
    What I meant to say on the red colored shocks is I have compressed the springs from min. compression to 5 turns in to compress the springs thus putting more outward pressure on the shocks-so is the suggestion to compress the springs even more to bring camber into alignment which will raise rear and create a rougher ride--
    20+ Posts
    Jul 2018
    Montrose
    Thanks for the suggestions ---I will try compressing the shock springs to see if that corrects the proplem
    Martinsburg, WV
    Hank, I don't know if you bought the trike new or from a previous owner so I don't know what has been done other than what you have explained.
    I don't know how far you can go with the spring compression before the ride totally deteriorates.
    I have only run adjustment from the stock position up 3 turns to achieve what I was looking for.
    I really can't help here other than repeat that it should not be that low.
    Perhaps the springs are shot !!!
    Jim Murphy
  1. Monarch II LLS Bottoming out
    By Moneypenny in forum Lehman Trike
    Last Post: 07-16-2018, 07:18 AM
  2. OK ride for older lehmans with solid axles?
    By tbird71 in forum Lehman Trike
    Last Post: 05-29-2018, 10:58 AM
  3. Renegade LLS belt adjustment
    By =Stangas= in forum Lehman Trike
    Last Post: 03-03-2016, 07:47 AM
  4. Lehmans Heavy Duty Shock
    By dogman513 in forum Lehman Trike
    Last Post: 12-05-2015, 08:15 AM
  5. Lehman Renegade LLS
    By OldFart in forum Harley Trike Conversions
    Last Post: 10-11-2015, 05:21 AM
