Likes Likes:  8
Results 1 to 14 of 14
Thread: battery
    Jun 2018
    Muskogee
    Default battery
    where is everybody hiding there battery?
    May 2018
    Angleton, Texas
    Default Sorry but I just have to do it
    Quote Originally Posted by vinman View Post
    The Battery Box.......
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Not hidden. Just hanging out on the frame rail.
    Jun 2018
    Muskogee
    just need to take the body off to get to it.
    what size battery is that looks small in the pic.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I dont have a body so this is just out in the open.
    Left side battery, right side tote bag.
    That was the smallest size of std lead/acid car battery that wal mart has. I can get you the number size off of it if you want, but dont remember it right now.
    Sep 2016
    Springfield, Mass. USA
    Is that two carb's on each side of your trike that I'm seeing ??? Very cool machine 4 sure!
    450+ Posts
    Mar 2018
    Fernley
    NO pic yet, but my battery box is left side in front of and welded to the left torsion tube. It is hidden and the easiest way to in and out access is to left the body up off the trike frame some.
    Only a few inch's, but it is needed room if one want's to take the battery in and out.
    Really like how Rex's is set up, just one sweet ride for sure.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    No it is not carbs.
    That is fuel injection.
    It has it's own thread at the top in the stickies.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Have you looked at hot rod car stuff?
    I remember seeing battery boxes that load from the bottom.
    Ahh....I remember....lowered little trucks.
    Jack up high enough to get under. Lift battery up into holder frame. Then swing the bottom shut. Then a couple safety bolts to make sure the bottom dont come open.
    Jun 2018
    Muskogee
    Isn't you forks facing the wrong way?
    Or is the motor in backwards?
    Nice trike
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Engine is in backwards....
    Battery box for underneath.
    https://www.summitracing.com/parts/sum-430021
    Jun 2018
    Muskogee
    Sure is a nice trike. love to see a pic of the side. so i can see the motor.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    It is on top of the page. "Anyone Else?" Thread.
    Lots and lots of mechanical hooha.
    Jun 2018
    Muskogee
    Nice work. i'm not so mechanically inclined. i'm kinda hit and miss sometimes
  1. Old Battery vs New Battery
    By Baldy_54 in forum Honda Trikes
    Last Post: 12-05-2023, 10:15 AM
  2. Battery Access Modification
    By symplysimon in forum Stallion Trikes
    Last Post: 09-02-2021, 08:26 PM
  3. Battery life and battery purchase
    By pcombe in forum Harley Trike Conversions
    Last Post: 02-21-2019, 05:53 PM
  4. When to change battery?
    By North of 49 in forum General Discussion
    Last Post: 07-04-2008, 12:18 PM
  5. Gel Battery
    By docb in forum General Discussion
    Last Post: 03-17-2008, 02:44 PM
