Likes Likes:  6
Results 1 to 20 of 23
Thread: Need Some Starting Advice
    400+ Posts mgwtrike's Avatar
    Nov 2014
    Loving the Southern Life in Central Florida
    Default Need Some Starting Advice
    My engine on my '12 Goldwing trike with 11,000 miles on the O/D, turns over just find but does not start,
    any ideas from the Goldwing wrenches out there?
    Cheers!
    Goldwing:
    A real butt kicking, wheel popping, tire burning old man's bike.
    MIKE W.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by mgwtrike View Post
    Cheers!
    Need more info....... what was done to it between the last time it ran and now ???
    Jim Murphy
    Iron Butt Rider 2001
    750+ Posts
    Jan 2010
    east windsor ct
    how long has it been sitting
    how old is the gas in it
    does it have compression
    does it have spark
    Feb 2008
    Shippensburg, Pa
    Cheers!
    if goldwings are anything like a Valkyrie, which I assume it should be. make sure the battery is fully charged. a weak battery will turn the engine over fine, but doesn't have anything left to give to the coils to fire the plugs. try jump starting it from a ( non Running Car.) which means, hook the jumper cables to the car battery but do not start the car engine. if your bike fires right up. then I'd say you have a weak battery.
    if you installed a new battery did you fully charge it before installing it, a trickle charger will not fully charge a battery, only maintain a fully charged one.
    200+ Posts Pooch's Avatar
    Aug 2017
    USA
    Use a volt meter on the battery and see if it goes below 10.5 volts when cranking, if it does, replace the battery. For some odd reasons, the battery in a Goldwing is the source of many problems. Keep us posted.
    May 2018
    Angleton, Texas
    Thumbs up
    Quote Originally Posted by Pooch View Post
    May 2011
    San Angelo
    While you are checking the battery cranking voltage see how snug the connector lug bolts are. I've found the GL1800 battery bolts have a tendency to work loose. If they do the battery will not charge well and that may indeed be your problem.
    2015 GL1800/Roadsmith HTS1800
    550+ Posts
    TwoBye's Avatar
    Feb 2014
    Washington C. H.
    Quote Originally Posted by 3W-lonerider View Post
    Good advice right there. Had a similar problem with my '99 1500SE trike and would blow the main fuse after cranking hard to get started. Replaced battery with a good one and "VOILA" no more starting concerns.
    ... Made the journey (from 2 to 3 wheels) now enjoying the ride ...
    Brad [TwoBye]
    Nov 2014
    Decided to use my towing insurance and get my Honda dealer to check for the season my engine turns over but does not start.
    I waited a day and called the dealership to check on if they found anything odd.
    The said when the tow truck unloaded my GL1800, it immediately started.
    They drove it in the service bay for a day and check out some codes and can't find nothing that would indicate trouble.
    They said they started it run it down the street, let it set for 1/2 day and it always started.
    Picked it up today, drove it home and now I'm really on pins and needles waiting for it to happen again.
    I do carry one of those pre-charged chargers so I'll try hooking that the my battery and see if that will make a difference.
    Thanks for all your reply's and solutions to try.
    Goldwing:
    MIKE W.
    Sep 2012
    Lakeland, FL
    You already know this, but no code and no failure, very hard to trouble shoot. Not what you want to hear, but I suspect you have to wait for another failure, that is up tight riding.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    A digital volt meter is your friend. After a overnight sitting the battery should be 12.5 - 12.7. Although you can still get good readings if the CCA is low. After cranking it over with out starting it , then check the voltage. If lower than the readings above it’s shot. If your in doubt of the battery age, start fresh with a new one as cheep insurance. JMOpinion.
    Just a note as I have jap 2 wheelers that will crank over but will not start unless the kick stand is up and brake is applied.
    Nov 2014
    Thanks, these are my thoughts also, cheap insurance is always good.
    Goldwing:
    MIKE W.
    All the Japanese's bikes have that interlock on the kickstand, And all Haleys, And Victory's for Export also have it.....But the bike won't crank...The starter is not energized..It works the same as a kill switch...
    When it acts up, is the trike in gear? Could be the clutch micro switch acting up. If it does it agin, try it in Neutral. Those micro switches aren't sealed and are famous for acting funky. Forgot you said it cranked.
    Nov 2014
    Thanks, something else I can try.
    Goldwing:
    MIKE W.
    May 2018
    Angleton, Texas
    Have you changed out the Clutch & Brake Levers? The Add-on Adjustable levers are known to do it. I had to clean up poor machining for mine to work.
    Read the reviews on the links below.
    http://wingstuff.com/products/36601-...ers-for-gl1800
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    In your original post you said the engine was spinning over but not starting. Does it not turn over or not start? Do yourself a favor and do some trouble shooting. If the engine spins over check for spark. If you have spark check for fuel.
    Nov 2014
    Wouldn't a weak bettery turn the engine over slower then normal?
    Is it possible the starter sounds the same but not giving off enough juice because of a weak battery?
    Would it start with jumper cables?
    Goldwing:
    MIKE W.
  19. #19
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    Does it still have the bank angle sensor installed? Perhaps it got stuck and rolling it on and off the truck unstuck it. I've had that happen on two-wheelers.
  20. #20
    Martinsburg, WV
    I had one several years ago that had a mis-fire and sometimes wouldn't get spark to start. Pulse Generator Assembly (30300-MCA-003) was the culprit. And WAPITA to get to and replace.
    Name:  GL1800 Pulse Generator.jpg
    Jim Murphy
  1. ARKIES....I need some advice
    By ferg in forum General Discussion
    Last Post: 06-27-2015, 11:44 AM
  2. Ok Need Some Advice from you Guys! Purchase!
    By seabiz in forum Harley Trike Conversions
    Last Post: 09-21-2012, 09:09 PM
  3. Need some advice!
    By Cybyrd1 in forum Harley Trike Conversions
    Last Post: 02-25-2012, 07:15 AM
  4. I need some expert advice.
    By bdn56 in forum The Gun Enthusiast
    Last Post: 11-26-2011, 12:33 AM
  5. Need some advice on installing Honda CB module.
    By Will in forum Honda Trikes
    Last Post: 10-14-2010, 11:52 AM
