Likes Likes:  4
Results 1 to 20 of 36
Thread: Cooling My M8 Wet Head
    20+ Posts
    Jun 2017
    Great Falls, MT, USA
    Default Cooling My M8 Wet Head
    Having issues getting the temps down on my 2017 TriGlide. Normal temperature for highway riding, (70-80MPH) runs in the 290-305 degrees, (hot to me). Ambient air riding temps are in the 80-95 degree range and we are at approximately 3400 feet of elevation.That's with approximately 500lbs of two up with gear riding. Have done several add-ons in my attempt to cool the trike, (the following is my setup). Have installed Love Jugs mighty mites, DK Customs 1 1/2 deluxe tank lift, DK Customs cooling deflector wings, DK Customs hi flow 606 air cleaner with EBS, removed left side thigh protector, power vision tuner and V&H trike deluxe slip ons. Been throwing a good bit of money at these high temps in my attempt to get them to a manageable range, (no luck so far). Looking for further advise on my setup. Is it possible I have a problem with my power vision tune? Next on the list will probably be a DK Customs oil filter relocate and oil cooler. I'm not sure adding them will drop the temps to a much safer range (230-270 degree). Guess you can say I've made improvements but nothing that has dropped the temps significantly. Looking for much needed recommendations or advise in my endless pursuit?
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Cookr21 View Post
    Is your reading of 290-305 the "ET" read off the Power Vision or the "CHT" read?
    If it is the ET read, yes, that is too hot, and it would seem that something is awry.
    Adding the oil filter relo and oil cooler will drop the oil temps about 35*, which is significant and important. It will only drop the ET 5-7 degrees.
    As I am typing, I think that must be the CHT read...the ET being that high is almost impossible with the Twin Cooled M8...unless no liquid cooling is passing thru the heads.
    www.DKCustom.com
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Once you've done all the suggested mods + tune there's not much more that can be done.Folks I remember when 74" was a big motor.These engines get bigger every year yet we wonder why they are hot.Start up your car or pickup truck, open the hood and climb up there and sit on the motor-burned your arse didn't you?
    20+ Posts
    Jun 2017
    Engine temps reported are from the Power Vision display. I'm not sure how to proceed or what to do next. Any suggestions are welcome?
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yes, but the Power Vision display has 2 different engine temps that it can display, they are titled:
    ET
    HeadT
    These numbers will be very different, sometimes as much as 100* difference. When you look at the PV display, and see the 290 number (or whatever it is), what are the letters to the left of the number?
    Need to know that in order to know how to proceed.
    www.DKCustom.com
    20+ Posts
    Jun 2017
    ET
    HeadT
    Kevin, I'm home for lunch and went to the garage to check. Power Vision shows ET in (Fahrenheit).
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    That is not good at all. Something is wrong. Even bone stock in 100* ambient temps, you should not be getting that much heat.
    It could be quite a variety of things, but the first thing I would do is ride it a bit, to get it warmed up, then pull the lower fairing cover on the right hand side and see if the coolant in the reservoir is hot. If it is not, that lets you know that the coolant is not circulating thru the heads.
    With all the things you've done to cool it, it seems almost impossible for it be that hot, even if the coolant is not circulating. Do you have full power? It is not sumping, working against itself? Are the radiator fans kicking on? It could be any one or combination of those things.
    There are just so many things it could be, but I would check the coolant first, and also see if it is throwing any codes.
    If that is all good, then I would check the tune...but even a horrible tune should not be able to make it run that hot...but I would still check it.
    Then I would check and make sure the anti-knock system is working.
    If you need any assistance in checking any of the above, feel free to call.
    I hate to say this, but if it were my bike, I would not ride it long enough to get it that hot, until whatever the issue(s) are are resolved. The ET is measuring the temp of the liquid cooled cylinder head, the rest of the engine is even hotter.
    www.DKCustom.com
    20+ Posts
    Jun 2017
    Trike appears to have plenty of power to me. I will say that at speeds above 65 the trike does not have much power when passing other vehicles. That's comparing it to previous Harleys I've owned. When you say sumping is this in regard to oil migrating to tranny? I've been checking engine and tranny fluid frequently and see no evidence of either being low or excessively full. Fans do kick on and run most of the time. When engine is shut down after a ride the fans continue to run for some time.
    I'm new to the PV and tuners but I'll check and see if I can figure out how to tell if codes are being thrown. Will take a small ride this evening after work and check to see if water pump is circulating through the fluid reservoir. No idea what anti-knock system does but will do a little research to see what I can find out about it.
    Rather frustrating this heat issue, (I was wondering if this was somewhat normal for M8 motors) appears not to be the case. Any chance of somethin faulty within the PV?
    I'll report back when I check the recommended items above.
    Appreciate the suggestions and keep them coming if you have others.
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Sumping is different than the migration issue. It occurs when the oil pump does not scavenge all the oil out of the bottom of the engine, and then the flywheels have to work their way thru that oil. It does cause a loss of power, and excessive heat. You should have good power above 65, it could be from the heat (which robs power) or it could be also from the flywheels working thru the oil (if it is sumping).
    There are a few threads on here that give the procedure for seeing if the bike is throwing any codes. Here's a good one-
    https://www.triketalk.com/forum/thre...-trouble-codes
    Yes, there is always a chance that the PV is faulty, more likely the the temp sensor is faulty though.
    Over the next few days I am not going to be on the internet much...just wanted to let you know in case it goes awhile without me responding.
    www.DKCustom.com
  11. #10
    Richard, Sumping is NOT the same as the oil migration problem
    If your engine was sumping you would most likely be way down on power, possible throwing codes
    The sumping takes place in the crank case, too much oil dragging on lower end, oil not returning via oil pump to the oil pan. this could definitely cause the engine to struggle and run hotter.
    My 17 Freewheeler ( oil cooled heads) has a PV tuner
    It runs just a tad under 300 degrees on 90 + degree days
    I have checked heat with an infra red gun and found the readings to not match the PV by quite a lot, I dunno if the placement on the M8 engines of the heat sensor now being in the rear head is causing these high readings.
    Check your oil temperature just for grins IMO a Twin Cooled M8 should not be running as hot as you are seeing unless the PV is not accurate on the M8?
  12. #11
    20+ Posts
    Jun 2017
    Checked the PV and it has no codes found on DTCs screen. Will not get a chance to ride it tonight but will tomorrow and I'll check to see if I can tell if coolant is running through the reservoir. Thanks for the help Kevin.
  13. #12
    20+ Posts
    Jun 2017
    Thanks for the explanation Jack. Your temps appear to be in the same range as mine other than the fact you are air cooled. Does the PV have oil temp as an option for display? Looks like I need to print out the manual for the PV user guide.
  14. #13
    10+ Posts Luvtofish's Avatar
    Aug 2017
    Louisburg, KS, USA
    This thread has me a little concerned with my own setup. My 17 triglide runs an ET reported by my fp3 of between 287-292 @ 70+ mph in 90+ air temps. I too have a 2” tank lift, cooling deflector wings and a canned tune from an FP3. I’ve assumed this to be normal for the twin cooled M8?
  15. #14
    Quote Originally Posted by Luvtofish View Post
    Dan, IMO the temperature gets reported to the ecm via a sensor in the back head behind the air cleaner instead of like the Twin Cams. They took their reading off the front cylinder, so the M8 will read engine temperature a bit hotter .
  16. #15
    I believe it does have an option for oil temp
  17. DKCustoms postbit
  18. #16
    20+ Posts
    Jun 2017
    Thanks Jack. I'll dig around in the PV and see what options I have for the display. No work tomorrow so I'll do some checking on the PV display and do a couple of the suggestions Kevin provided.
  19. #17
    Here is a response I got from Dynojet a few months back about Engine Heat on M8s
    Thank you for your inquiry. We appreciate your interest and support of our products.
    The engine temp that can be displayed on the Power Vision screen is read directly from whichever temperature sensor the ECM looks at. It is NOT an exhaust temp. Depending on where you’re located, those temps are not all that uncommon for a big twin in the summer. Out here in the deserts of Las Vegas, when our ambient temperature is 110+, it is not uncommon for me to see temps as high as 350 or so in stop and go traffic. I checked with one of our HD experts, who told me to only be concerned if the temp gets to 380… At which time, they recommended to pull over, shut the bike off and let it cool down.
    If you have any questions, please feel free to contact us... We're open Monday-Friday, 8am-5pm Pacific time.
    Scott Webster
    Technical/Sales
    Training Coordinator
    Dynojet Research, Inc.
  20. #18
    20+ Posts
    Jun 2017
    Scott Webster
    Technical/Sales
    That's some good to know information. Still want to get this trike cooled down as much as possible. I mentioned it earlier but the trike does not appear to have much get up and go when passing at 70mph or above. It will do it fine but you are not going to quickly move around a semi. Trike does great at holding speeds going up mountain passes. Definitely has much lower end grunt than my 2010 trike did, not so much on the higher end. I'm guessing but assume that has to do with the gearing. Hoping its not a heat issue that could be retarding it at the higher RPM's.
    In a previous post you recommended checking oil temp. In your opinion what do you consider a safe zone for oil temp?
  21. #19
    220 would be nice, mine checks in @ 250 with synthetic oil
  22. #20
    250+ Posts
    Feb 2016
    Pelham AL USA
    Default Hmmm ?
    OK, are you saying that the Power Vision can now read the engine oil temp on the M8 bikes? That is great if it will. I have never been able to find it as an option on my PV for my 2016 TC. I guess the PV is not able to get that from the ECM on the 16 and back models. Anybody else getting oil temp from the TC with a PV? I am going to check my PV menus again, but I don't think it will do it.
    NOPE. I just hooked my PV up and checked for oil temp reading. It is not available for a gauge under the Advanced or Basic gauge options. Sure wish it was.
    Last edited by MDF48; 08-02-2018 at 10:33 AM. Reason: To check PV for oil temp gauge.
  1. Wet Head pump
    By jc1300 in forum Harley Tri Glide
    Last Post: 01-28-2018, 04:45 PM
  2. BMW goes head to head with ???
    By Lee H. Mann in forum General Discussion
    Last Post: 10-13-2016, 08:02 PM
  3. Class Action Wet Head Suit
    By msocko3 in forum Harley Tri Glide
    Last Post: 09-03-2014, 07:54 PM
  4. Wet T-Shirt Contest
    By americanbadass in forum General Discussion
    Last Post: 02-27-2013, 01:09 PM
  5. wet road handling
    By motor256 in forum New Member Introductions
    Last Post: 11-18-2010, 09:12 PM
