Likes Likes:  24
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: losing all power
  1. #21
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by LadyonaMission View Post
    I had to have part 31 replaced on my Freewheeler while I was out of town. The service tech told me that would not have happened had my dealer checked the shifter during the service which was done less than 1,000 miles prior. I now take it to another dealer and I do check the shifter frequently.
    They have been known to fall off after the pinch bolt falls off
    https://www.betterlever.com/product/better-lever/
    This solved the problems on the 5 speed, I see no reason it could not be adapted for the 6 speed gear box
  2. #22
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    I repaired a bunch of those type shifter levers on ATC's And once on my 11 Tri-Glide...
    I would replace the bolt with a new one, Then file the opening in clamp part to make the slit wider then the clamp will tighten more on the shaft...The lever is made of softer medal [AKA sacrificial medal] than the harden spine shaft......If the lever gets too lose the harden shaft will eat the clamping part up, Better than if the lever was harden and then eat the shaft ....And then the tranny has to be opened up..
    2019 Tri-Glide.......
  3. #23
    1000+ Posts dannymax's Avatar
    Jan 2018
    Upper Hudson Valley, NY
    There doesn't appear to be any way to lube #31 without pulling bolt #1, yank out the shift levers #13 and buttering some white lithium
    on the shaft....would be a jim dandy spot to drill/tap in a zerk fitting, yes?
    Lola, did you happen to notice if there were o-rings on either end of where the shaft fits inside the casting?
    2017 Freewheeler
    Billet Silver
    Compassion for animals is intimately connected with goodness of character....and it
    may be confidently asserted that he who is cruel to animals,cannot be a good man.
  4. #24
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by dannymax View Post
    I drill and tap the primary where the shaft runs thru, I grease it each oil change
    Or look here
    http://www.pingelonline.com/harley-d...fter-shaft.asp
    Another note, if your shifter rattles you can shim the shaft with wave washers
    HD has gone cheap, baggers used to come from the factory with grease fittings for the shifter shafts and neck bearings
    I guess the bean counters saved the MOCO a few dollars
  5. #25
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Or look here
    Think about it. Jack......You sell 230 thousand bikes, And then a dollar here and a dollar there soon adds up to real money...
  6. #26
    Dec 2013
    Clarion PA USA
    Or look here
    Jack a little pricey but it sure is nice I installed one (grease-able shaft) this spring. Notice the crud everywhere these were taken before the Stator and regulator repair oil everywhere. Fred
Size:  160.9 KBName:  DSC00724.JPG
Size:  162.0 KBName:  DSC00725.JPG
  7. #27
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Thumbs up
    Good job Fred
    I drilled and tapped my rear brake pedal also
    It gets lubed now also
    I have too much time on my hands so I do what The MOCO should have done
  8. #28
    Jan 2018
    The MOCO sure did drop the ball with that design, course as Bob mentioned, they're catering to the stock holders way more than the buyers/riders. Sux but that's the way of the world now. That's OK, we get to make them our own this way.
    2017 Freewheeler
    Billet Silver
  9. #29
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Cant argue with that, just disappointed the MOCO is going backwards at the owners expense
  10. #30
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    The part the service tech showed me was metal only.
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
  11. #31
    Jan 2018
    Yeah, that's the way it appeared on the fiche also....pretty much highway robbery the way they designed that.....sell lots of shafts and every once in awhile a case, nice!
    Thanks Lola.
    2017 Freewheeler
    Billet Silver
  1. Replies: 11
    Last Post: 11-06-2014, 05:35 AM
  2. Questions.. Losing oil/funky oil pressure
    By classicfins in forum VW Powered Trikes
    Last Post: 10-09-2012, 04:31 PM
  3. she is losing her shine
    By adaptolife in forum Harley Trike Conversions
    Last Post: 08-11-2012, 09:13 PM
  4. Power...Power, I need more power
    By SJR in forum Harley Trike Conversions
    Last Post: 08-14-2011, 10:37 AM
