Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Results 1 to 11 of 11
Thread: Heater servo valve
    20+ Posts
    Sep 2015
    Olney, TX
    Default Heater servo valve
    I don’t think my servo valve is completely closing the flow of coolant to the heater. Where do I look for it? Or where would be the best place to install a manual cut-off? Any suggestions or experience with this on the Stallion would be greatly appreciated.
    2008 Stallion
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by Ployboy View Post
    2008 Stallion
    Haven't got a clue on this one ! I recommend you call Richard at TMS on Monday morning. Remember they are on central time. tomg
    Not sure but I would look first in the rear behind the rear seat back. I believe the heat exchanger is in that area.
    20+ Posts
    Sep 2015
    Olney, TX
    Thanks, guys for the replies. I’ll look behind the seat. I thought possibly it was back there. I was hoping it wasn’t behind the dash area somewhere (too congested).
    John
    2008 Stallion
    This is a typical Ford heater control valve
    It will be in 1 of your heater hoses before the heater core
    Most often the valve will either leak or stick
    300+ Posts
    Signal Mountain Tn
    It is probably a good idea to cycle it through during the warmer months so that it doesn't freeze up.
    I dunno what your heater/ AC box looks like
    If it is based on a Ford design, they were notorious for having blend door problems
    20+ Posts
    Sep 2015
    Olney, TX
    I haven’t looked at it yet. But I know it was made by Vintage Air.
    I am truly getting old ... LOL.
    I never thought I'd be reading a thread on a Trike bulletin board about AC and Heater problems. Technology is a wonderful thing.
    I did actually purchase heated riding gear a couple of years ago ... gotta admit, I'm at that age where I like the comfy feeling ...
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Pretty close. The heater valve on the stallion is more of what I call a butterfly style (doesn't have the actuator like the one shown). It's located on the top of the hvac box under the right rear wheel, can also see it by removing the passenger seat back. It'll have a plastic cover over it that snaps on & off & like others have said the heater hose can be your guide to it.
    I'd also make sure the heater control knob & control on the dash isn't your issue. The knob should turn almost a full 360 but stop just short of; if the knob will spin all the way around & keep spinning the set screw is backed off & the knob isn't actually turning anything. You'll need to remove the cover plate to access the small allen set screw that secures the knob to the control.
    20+ Posts
    Sep 2015
    Olney, TX
    Quote Originally Posted by trike tech View Post
    Trike tech, I think my control knob is working correctly as you described. I’ll look for the controll valve as soon as I get a chance. Thanks for the description on its location.
    John in Olney, TX
  1. **** TBW - Throttle Servo & Bracket Covers****
    By DK Custom in forum DK Custom Products
    Last Post: 02-22-2017, 04:51 PM
  2. Replies: 1
    Last Post: 06-25-2014, 10:55 AM
  3. Heater From Trike
    By hotsyman in forum Harley Trike Conversions
    Last Post: 06-05-2012, 02:16 PM
  4. Oil Valve: Quik Valve
    By Konrad in forum Honda Trikes
    Last Post: 08-05-2011, 07:34 PM
  5. Heater in Stallion
    By molinoman in forum Stallion Trikes
    Last Post: 09-13-2010, 02:27 PM
