Likes Likes:  44
Results 1 to 20 of 36
Thread: Blackstone Oil Analysis Labs
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Default Blackstone Oil Analysis Labs
    I just took a sample of my engine oil and I am sending it off to Blackstone Labs for an analysis. I have 6,101 miles on my engine & 2,201 miles on the oil since switching to Lucas 20W50 Full Synthetic High Performance Oil. The CA HD dealer put in Syn3 at the 1,000 mile service & I kept it till I had around 3,900 miles, then switched to Lucas.​ Those miles were mainly highway from CA back to STL. I know switching to Lucas gave me better shifting & it was immediate.
    I have never done this before, but am curious to see how that oil is doing. Hopefully, this will tell me how that brand is doing & if I can go longer. I know I rode in several 95-100 degree days.
    Anyone try them & how were the results?
    Blackstone has a great reputation
    I have not used them, how ever the trucking firm my dad worked for used them when breaking in Mack diesels
    Blackstone strongly recommended @ that time they switch to Shell oil from the Penzoil they had been using
    Oct 2017
    St. Louis, MO USA
    I am curious to see the results.
    I hope they don't tell me the Lucas is junk, I have 2 more changes of it left. I have Quicksilver for the diff. & tranny this winter.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Don't know squat about Blackstone Labs, but I'd be leery of any lab that "steered" me toward another alternate product.
    Now if they were to compare my oil to at least a few different brand x offerings, and their molecular laboratory analysis/breakdowns, I might make a switch to a superior product.
    Bottom line: Buyer Beware...
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    I used Blackstone Labs to test four different oil samples over four oil changes on a new motorcycle about nine years ago. I did this to see which oil I preferred for the operating conditions the motorcycle would encounter.
    Blackstone will provide you with a side by side spreadsheet comparison sheet comparing for your each of your samples along with good recommendations for your consideration.
    I am still riding the same nine year old motorcycle today using the oil test results that were made back then. I have not changed brands and I am happy with the data presented from the oil reports. I have 110K miles on the engine and will continue to use the same brand of oil with oil changes every 4K to 5K miles.
    Last edited by David357; 08-12-2018 at 11:29 AM. Reason: Added wording clarification: with oil changes every 4K to 5K miles.
    Pete, the company had been using Penzoil, had the tests run side by side
    The Penzoil had more wax and higher sulfer content
    That was Blackstone's reason for switching the Macks oil
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by David357 View Post
    I am still riding the same nine year old motorcycle today using the oil test results that were made back then. I have not changed brands and I am happy with the data presented from the oil reports. I have 110K miles on the engine and will continue to use the same brand of oil.
    Now David, you need to give up the name of this oil. You can trust me, I won't tell anyone!
    Meme Master
    Jan 2014
    Farmington, NH USA
    Funny now that Pennzoil & Shell are one company.
    Wonder if their oils are now the same formulation???
    Oct 2017
    St. Louis, MO USA
    For anyone not familiar with Blackstone, you go to their website & request a collection kit.
    They ship in a few days & it arrives. It consists of a collection bottle, a oil absorbing pad & a bag to put it in. You then put the sample & the form you fill out in a black postage prepaid contaiiner & send it off via the USPS. They have a motorcycle specific form you can print out on their website.
    They want year,make, model, miles on the bike, miles on the oil. They recommend you ride for 30 minutes to burn of any fuel or moisture, but if you don't & take a cold sample, just tell them.
    They also want to know if you took the sample during an oil change or just drew some out, which I did.
    They request about a 3 oz. sample & the analysis cost is $28. I will try to post the results when I get them.
    Oct 2017
    St. Louis, MO USA
    Taco Bell, Pizza Hut & KFC are 1 company too!
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Michael, I'd be glad to share the name of this oil but I don't want to start another oil thread war.
    Anyway, this $14.95/gallon JASO MA rated oil will only work in "one hole" engines that share the same oil for the crankcase, wet clutch and transmission such as the Goldwing. The Blackstone Lab reports confirmed the lowest "wear metals" from both the upper and lower bearings and transmission gears.
    You could burn their waste oil in your diesel
    Oct 2017
    St. Louis, MO USA
    Anyway, this $14.95/gallon JMSO rated oil will only work in "one hole" engines that share the same oil for the crankcase, wet clutch and transmission such as the Goldwing. The Blackstone Lab reports confirmed the lowest "wear metals" from both the upper and lower bearings and transmission gears.
    David, Jack & I like oil threads! He's always asking me to start 1!
    Thumbs up
    Some times I learn the hard way
    Oct 2017
    St. Louis, MO USA
    Jack, I had heard years ago that Pennzoil had a lot of paraffin in it. That's why I never used it. I don't know if it has the same formulation now.
    1000+ Posts dannymax's Avatar
    Jan 2018
    Upper Hudson Valley, NY
    At the risk of venturing out on that thin 'oil thread' ice we used to refer to Pennzoil as "Pennsylvania paraffin based crude" and
    Blackstone's recommend to switch to Rotella in the diesel's was a good one.
    2017 Freewheeler
    Billet Silver
    Compassion for animals is intimately connected with goodness of character....and it
    may be confidently asserted that he who is cruel to animals,cannot be a good man.
    Sep 2012
    Lakeland, FL
    I am a Rotella fan, the dino kind, if I could determine that the synthetic is worth the price, then I'd probably switch. By the way, I'd not be concerned about naming a brand oil, Zook and his mods are pretty lenient on this forum, unlike the 'other' forum. I do not believe TT folks will 'jump you' unless the thread gets really nasty. That's why I like this forum, reasonable riders can have reasonable discussions and opinions without getting busted for every little thing.
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    Yeah.... I like their Pepperoni stuffed tortilla extra crispy chicken bits chipotle mozzarella chimichanga grande... I buy em by the bucket....cheaper that way
    Looking forward to the analysis. Thanks in advance for sharing. It will be interesting
    PS... I too am interested in the name of the nine year 110k mile mystery oil (reference to Marvel's Mystery Oil for those who remember it )
  19. #19
    Good stuff
    I use it in the gas and oil
    Dad had a oil injector on his pick up truck back in the early 60s
    Marsden oil injector feeding Marvel Mystery oil into the intake
    He was very cutting edge, growing up a self taught diesel mechanic ( note, there is a difference between mechanic and tech)
    The best lesson he taught me Keep it clean, oil changes with Marvel mystery oil before to flush out more crud, then add just a bit during oil change.
  20. #20
    Oct 2017
    St. Louis, MO USA
    Good stuff
    A lot of people do the same with Seafoam now.
  1. Questions.. Losing oil/funky oil pressure
    By classicfins in forum VW Powered Trikes
    Last Post: 10-09-2012, 04:31 PM
  2. Leaking oil after an oil change
    By trikerider55 in forum Harley Trike Conversions
    Last Post: 06-25-2012, 08:44 AM
  3. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
  4. At Last A Oil Filter That Actually Lowers The Temp Of The Oil
    By Helipilot in forum Harley Trike Conversions
    Last Post: 07-31-2011, 07:13 PM
